Everything posted by Hocrest
School on Sat, AX on Sun...
hmmm...I was going to register this afternoon, but now that I think about it, I'm gonna wait till the 27th...:-p And Scott, don't worry about anything, your family and their health/welfare should definately be your priority...
And I'll bring the corn and banana's:banana: (where's the dancing corn smilie????) Someone want to bring some meat? or should we just visit a local pasture??
I broke the nipple on the end leading to the cannister.
It leads to the evap cannister. So, if it doesn't work, the cannister doesn't get purged and the vapors vent off??? Or are there other problems? I fixed it by cutting off a short piece of tubing that fit inside both plastic pieces.
Looks like the one on the right.
I was changing the thermostat on the '89 3-door coupe today, when I was reconnecting the vacuum lines, I broke the plastic nipple on the valve/sensor/switch?? directly behind the thermostat housing. It has the 1" long "L" shaped vacuum line going to the branch mounted to the thermostat housing and proceeds to the canister by the radiator. It has a wire going to it, and another vacuum line running towards the back to the trans with a line T-ing into the intake manifold and another T-ing into the ball vacuum reservoir on the passenger strut tower. It also has what looks like a knob or button on the side. I have it temporarily patched for now, and she’s running normal. I’m just wondering what oddity's to blame on this thing till I pick one up from the yard???
Mid April: Eastern PA Yard Run (Maybe More)
Hocrest replied to the_bard's topic in Meet n' Greet. Your USMB Welcome Center
That is the weekend of the Reading SVX Meet, so that will rule out a couple of us "locals" and there is an Autocross in York on Sunday. -
Not sure exactly what it is, but here ya go... Ebay
To use it, you just need to find the fuse holder in the engine bay marked "FWD" iirc it's near the passenger strut tower?? It is not meant to tow your Soob, it's only real purpose is if you have one or more tires of a different size (spare). Other than that there is no real benefit to running in front wheel drive unless you want to impress the chicks by chirping the front tires:rolleyes:
If it is going to spend it's life on the highway, you'll see a fuel savings. Around town, I think the lack of power from the EJ22 will burn more fuel pulling away from stop signs and lights???
Actually there are aren't any other Soobs that you can get stuts from without some major modifications. The rears aren't too bad, you need to grind down the spindle where the strut attaches. The front would require the same grinding as the rears as well as welding tabs onto the strut to attach the sway bar.
I've personally experienced both... It can be a pain, the way to check is to mesure the depth difference between the flex plate and the surface where the bell housing mounts on the engine, then compare that measurement to the distance between the bell housing and the mounting tabs on the TC. It will end up taking a combination of wiggling, lifting, rotating and pushing and then it will just sort of pop into place... edit; I just saw that you're in Allentown, I work down there, if you want me to swing by some evening to take a look, send me a PM with your phone number.
Are you reading this Ben??? sounds like a challenge to get your "project" done by May...
Unless you are the father as well as the uncle:eek: I see no reason why you can't come to Carlisle. I plan to be there, hopefully one of my cars will be running at the time
How many have you meet and greeted.
Hocrest replied to ezapar's topic in Meet n' Greet. Your USMB Welcome Center
DAMN YOU!!!!!! Don't be stealing our Moose!!!! -
LeakingOil Benebob moosens svxpert dennisex trogdor wagons only bucky92 beerheart nkx subarubrat Subeman90 Kingbobdole Cutie-ru X35 (Stevebsy) Cole98 Stupidru Tappermannor Huck369 Myxalplyx Avatar Skip Kecksnext Ettev Subbyluvr2212 Seahag Subafreak Randy MtSmith EJ Bluebaja Phatbrat Zadok MrWhirly That's about all I can think of that post on USMB, there are a few others from XT6.net that I've met that aren't known over here. And probably another 20 or more from subaru-SVX.net Additions; GravelRX Akira Mattocs RallyKieth -
If it's that tight, it probably wouldn't be a bad idea to grab a spare. It will sit nicely out of the way in the spare tire untill you need it. I seem to recall it costing about $14 at the dealership????
Attention East Pa Subaru Owners?
Hocrest replied to cole098's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah, they're on 61. Cole is already familiar with them though... Joe, which direction are you thinking, there is one down near Ephreta that Matt "Subeman90" deals with "Orbachs" or something like that. There is also that shop on 209 in Tremont, I know nothing about them, but everytime I drive by the lot is full of Soobs.
