Everything posted by Hocrest
This got put on hold when the engine died. I needed a working car and swapped the engine and trans in two days. I had the 4EAT that we pulled out of the racer, and needed the car on the road... If I keep the car, I still plan on swapping it. But as of right now I'm looking for a cheap 5-spd wagon for me, and the auto sedan can go to Melis's daughter. As for hyd/cable it was going to depend entirely on what I found at the yard. :cool:
Last night I had a dream that while driving the 3-door coupe, I found a knob on the dash that allowed me to adjust the camber while I was driving. I could keep the tires straight up for take off and braking traction, then crank the knob to grip through the turns. It was incredible, that coupe on stock tires was handling better than the SVX Racer on 12" wide tires. Unfortunately I woke up before I was able to get out of the car and find out how it worked
I ordered about $70 worth of parts for the Brat, Legacy and SVX :D
2005 XT owners
Hocrest replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I thought they stopped making XT's in 1991 :-p -
You can get them on EBay also, search "subaru camber bolt". They're not too bad, but you need to hold the bolt and the tab in the proper position while you tighten up the nut. The nut is crimped so that it doesn't come loose, but that means that you can't turn it on by hand, you need to wrench it the whole way. Also the Subie stock bolts are all 19mm heads, these are different sizes, so a two tool job becomes a 4-6 tool job. Minor things, but still a PITA.
You can use camber bolts in place of the rear strut bolts. Summit Racing IEC-I-81260 Generally you use one bolt on each corner. They're a pain in the rump roast to use, but they are effective. Just make sure you crank them tight. For even more adjustment you can use two on each corner. Ideally if one of the control arms is bent causing the problem, it would be a good idea to replace that.
Stay away from the smallcar kit. I have heard more bad than good about their 5-spd kits. TomsSVX puts together a kit that will eliminate any of the fabwork for the pedal assembly, linkage or the crossmember. It is what we used to put a 5-speed in the Racer. If you can do the fabwork yourself, you can follow Huck's instructions to do the swap for under $1000 depending on the trans you can find. For more details, definately go to http://www.Subaru-svx.net
Last time I was there, I don't remember seeing any ea81's. Ea82's are still plentiful. Gen 1 Legs are becomming commen and Gen 2's are starting to show up more often. John, there are at least 4 ea81's of various flavors down at New Ringold. If you've never been there it's probably about 30 minutes south of Harry's.
Alcyone ( XT XT6 SVX ) Dragon Meet News
Hocrest replied to Bucky92's topic in Meet n' Greet. Your USMB Welcome Center
Yeah, it was nice of the County Courthouse to give me a recipe to make it. I've been out of a job, and I have some extra room in my basement and I got A's in highschool Chem Lab:cool: That pic^^^ was taken by Melis on the way to the courthouse with Connie in tow. -
hehehe.... We were on our way down to the group photo by the dam. I was running hard and Aus was keeping up. Right before the campground entrance a bike dumped, it was over in the grass, but one of his friends was standing out on the road waving to slow us down. I slowed down, the problem is the biker's friend was standing right by the crash, rather than up the road a bit. With that turn and the way that the "friend" was standing right next to the crash, Aus didn't have as much of a notice as I did. I hear screeching and quickly look up to see tire smoke and Aus's eyes in my mirror . I wasn't quite stopped yet, instinctively I got off the brake... I lost sight of his bumper, he says he got as close as 6"....
Here are the others that were taken before the battery died.... Link for PICS
