Everything posted by fastwgn286
if you ever cross the border next season, i'll take ya on in a celebrity wagon:brow:
tire size ?
fastwgn286 replied to pBIIKS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
jack up and try it out. if you cant get them on, they dont fit...... if you can, jack all wheels off ground, car in neutral, and spin to see if they rub. wheels are as diverse as tires, so some 16"s may, some may not. -
biggest problem is that the all the halfshafts and drivelines are designed to accommodate a small portion of the engine power. converting to rwd you would probably want new axles that can handle the power of the engine. modify the engine any and you would need these. besides, why? rwd trucks are pointless. and i remember reading that scc article. and iirc, they needed to do the above (it was in one of those box thingys). one of the japanese drift squads runs rwd wrxes, but they use skyline rear diffs and beefier axles too.
yeah, it is! $700 at the dealer, because they drop the engine. (my mom has one) mazda cx-7 is available with awd. the cx-9 is the 7 passenger one, though (also available with awd). i haven't been back to my former employer to drive one yet... mazda mpv is dead. it was nifty though, roomy and comfy. 1st gens had awd. but the ones with sliding doors never had it. mazda 5 really doesn't have that much space, and getting to the back row will take off your kid's head. although a frat did use one as a party shuttle before. that was hiliarious...
hondas resale higher than subarus? since when? (seriously, kelley blue book has a lgt limited beating an accord ex v6 with same options) ok, back to your concerns. the turbo will add some value to the car and will help make it resell a little easier, but it won't offset the cost differential in the long run. and if you are just gonna drive it like a normal car, you're better off with the na model. no premium needed (the turbo requires premium, no bypassing that), no worries about sacrified reliability, maintainence is similair to the one already in your driveway...it's the wiser of the two
thats what i thought when it happened the first time. balanced front tires, and still rough vibrations:mad:. before this point, i rotated the tires so the offending one was in the back. turns out, once i took off the wheels one night trying in desparation to find out why the vibrations were occuring and started to roll them along the pavement, one started to hop. the tread was peeling off the belts in one spot (looked kinda like a blister or a hernia). in fact, i still have one on the car, waiting for sears to get a replacement in...
I bet you a package of cookies that its a tire. this has happened twice on mine (michelin weatherwise). Its a front tire. here's what you do.... 1. jack up car 2. remove a front tire (i start with driver's side) 3. replace with spare tire 4. unjack car and drive around the block. let go of steering wheel to see if it pulls in any direction. repeat for the other tire if the shimmy and pulling to one side is still present. unfortunately, you will need to dish out for another tire unless you still have receipts
well, the ej25 would be a wiser choice in two regards. a) the aftermarket for the ej25 is larger than the aftermarket of the ej22 (for the obdiis at least) and with your plans of engine swapping, you could theoretically buy one with hg problems for cheap and toss the engine ^ and its only 3155 lbs dry wt.
i'd keep it 4wd, as those tracks can be a bear to find traction on (va state fair is horrible, hopefully y'all use clay and not sand) and hopefully they class you to face the other four bangers (aka the "bumble bee" class) and you should own them (you're hosed if you face anyone with a crown vic or a 70s caddy)
New Legacies
fastwgn286 replied to ctoth's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
judging by the grille and headlight eyelids, the owner debadged it to confuse you... what everyone else said... -
you can go to a trusted dealer (if you can find one you trust) and order one from them. the used car managers go to mega auto auctions and use wholesalers to get cars on the lot, so if you really want one, they will get in the first one they see... you might not be able to get all of the spec you want, but they can get an xt for you
wagons are great for that stuff. when my dad and i remodeled a house, everything from wall studs to sheets of plywood and drywall where tied to the roof and jammed inside and away we went. great moving vans too (fit a recliner and coffee table in the outback, couch strapped to roof, 100 miles later in the apartment)....
doubt it. did a quick search and all i can find is 8x6.5. most old-gen subarus are 4x140 (5.5 inches) so the lugs won't line up. and you might need to find some special lugnuts, since the hole diameters vary (if you can find a 8x5.5 rim)
