alt.autos.subaru suggested I post this here as expert help is needed!
My son decelerated to a stop light and then according to him, when he tried
to accelerate the engine started missing and would not go at all. When I
towed it home, I removed the r/h timing belt cover to find a shredded belt
which I replaced along with the other side. The motor behaved to the best of
my recollection, about the same as it did the night we towed it home. Had a
mechanic friend come over and we did compression checks (ok), timing
re-checks (ok), all of the things one would normally think of (ok). The
distributor was a little loose so I replaced that with no change at all. The
symptoms are:
a.. rough idle (or none)
b.. starts up as though it's flooded (full throttle needed)
c.. vacuum oscillates wildly at any speed (it uses the full gauge) except
when fully loaded and then it's at near zero
d.. backfires through the carb. at all times except when fully opened up
e.. changing ignition timing while running make very little difference
Does this sound like a blown head gasket and if so, how does one diagnose
that? (the compression check showed between 120-140 on all cylinders.
Thanks in advance,
Peter
