Everything posted by The Beast I Drive
Try mixing 1 part auto tranny fluid with 1 part Kerosene, then pour that on the bolts and let it set for a couple days, adding more fluid about 3 times a day, then use an air impact gun and power the bolt both directions, until it breaks loose. Automatic transmission fluid is pretty much one of the best penetrating oils Ive ever used.
-Bill
I disconnect the sway bar always, its worthless on road and a hinderance off-road, I disconnect it and remove it. Nothing else gets modified, just slap in the blocks and its good to go.
-Bill
yeah I havent really taken any pics of what I do, but Ill take some pics of the next ones I do.
-Bill
Check out the thread
http://ultimatesubaru.org/forum/showthread.php?t=109409
Basically I convert Subaru 4x140mm hubs to 6x5.5" so you can run any 6 lug wheels, stock or aftermarket, even fancy alloys
-Bill
You have a couple options for rims, you can redrill 2 holes into a 6 lug Chevy/Toyota/Nissan wheel, or drill 4 holes in the Subaru hubs and add 4 studs to make them 6 stud, or find Pugeot wheels. I redrill hubs and install new studs for $60 with cores right now, if you are interested...
-Bill
I will try my hardest to have plans to send to you this weekend, Sunday night at the latest. Im terribly sorry for the delay
-Bill
Looks pretty good, 3/8" should be more than enough strength. What size tires are you gonna be running? I will be looking forward to pics with the lift installed.
-Bill
Id be more than willing to help you out, get some posts in the forums accumulated so you can send and recieve private messages, we can work out a deal.
-Bill
For 2" and 3" I bend the plates at 30 degrees, for the bigger lifts I use 2 45 degree bends.
-Bill
I dunno man, it has to be a certain size I know that much, let me check to see if I can remember how to do it
-Bill
Um, I cant really remember, but I think if you go to edit profile, then edit profile picture, then you can paste a URL for it. I think.
-Bill
I dont have any EJ stuff here to play around with really right now, other than a trashed Outback, I dont know if the strut tops are the same or if the angle of the towers is the same... If you could give me some info on that I could prolly make something happen
-Bill
Yeah I just use all the stock suspension along with my lift blocks. Works great, never had any real problems
-Bill
