Everything posted by The Beast I Drive
Yeah I just use all the stock suspension along with my lift blocks. Works great, never had any real problems
-Bill
I space the crossmembers down with blocks, on a 4" lift I use 3x4" blocks, on 6" I use 3x6" blocks, etc. to keep all the geometry the same as stock. I make strut towers for the front out of 4" pipe and 1/4" plate, in the back I bend and brace a piece of 1/4" plate to bolt the coilovers to.
-Bill
Get some more posts or donate or something so I can send you Private messages, then I will send you some pics of what Ive done for my lifts.
-Bill
Depends, "best" is a pretty general term. Jeff and his buddies run 30's on 2" suspension lifts and get around just fine on some hard core trails. Ive seen those rigs do things that a 10" lifted Hatchback with T-case and a host of other mods couldnt do... I can show you parts that I have made and used for my 6" kits, from there you should have a pretty good idea of what you need to make any lift you want.
-Bill
You aint gonna be able to wheel with 35's very long, not with stock axles and a stock drivetrain. I know 2 guys on the board running 35's, one is rollin a Legacy with STI diffs and axles and a Samuri transfer case, the other has Toyota axles and a Samuri T case. I wouldnt run anything bigger than 33's unless you plan on running a T-case and stronger diffs/axles. Ive made 31's fit on a 4" lift with no rubbing, so you could prolly make 35's work well with about 8-10" lift, but you will need a subframe if you want to run an extra T-case.
-Bill
