The Beast I Drive
Everything posted by The Beast I Drive
  1. My RX had that switch too, but somebody had hacked the wiring under the dash and disabled it, and removed the foglights -Bill
  2. Got my fog lights installed somewhat properly (had all the right switches, lights, relays, wire, but all I had for splices was thumb screws ) I ran the positive wires through the pushbar (talk about a PITA) and ground wired to the mounting points. They work great Then I set up my PB start system. I have done this to 3 or 4 rigs now and I like it. The idiot light and switch closest to the seat are for the fog lights. I mounted everything on the center console for now, because I dont have a radio consol in the car yet. Eventually I will build a roof consol to mount all the extra gizmo switches in, but for now, this works, Ill just have to get a boot from McBrat to cover the wires Tomorrow Im gonna work on lift kits, so there prolly wont be any more progress on this until monday or tuesday... -Bill
  3. Wanna do it this year, or in the spring/early summer next year sometime? Doesnt matter to me -Bill
  4. The front bumper is pretty much done! I still need to get a 5000lb winch, and make a small skid plate that will go from the bumper to the rad. support, and paint of coursed, but its pretty much done! When I did the lower radiator support, I also re-routed the wiring below the rad. to above it Im heading back out in a few minutes to install these And replace this With a pushbutton start setup. -Bill
  5. I was the guy with the rusty, red Gen 1 Brat... I have a platform to start with, and I have a car to test my first kit on. The ones I have will be for Gen 1 and Gen 2 Legacy/Outbacks, I dont know if the 01's are different or not... -Bill
  6. No, it looked like a banana though :-\ Someone at one point must have made a crash landing on a good size rock... Before After Now I have a straight one, and I also gained about a foot of clearance by cutting the towhook BS off at the bottom of the framerails, and making my new rad. support out of 1 1/2" x 3" tubing with a notch cut out to fit the radiator, as well as nuts welded in to mount a skidplate. Im just about to finish the front bumper, so Ima go try to do that before it gets dark, then Im gonna wire in a push button start setup so I can stop using the screwdriver -Bill
  7. I will be getting set up for EJ lifts over the course of this fall/winter, Ill let it be known when I am ready to sell them -Bill
  8. I like it, lets do it! Where in Ellensburg would be a good place..... Might have to talk to Robbie, he lives there... -Bill
  9. Ive made a little more progress this morning, just finished the lower radiator support Now Im going to eat, then Im going back out to put the frontend back together and finsh the front bumper. -Bill
  10. Indeed a good lookin hatch... A lift would be a good addition -Bill
  11. Got the rear bumper built tonight, its pretty much done, eventually Im going to build a swing-arm that will mount to it to hold the spare and a gas can, but other than that and paint it is done! Also replaced the tranny mounts, which turned out to be more of a PITA than I had expected, but it made the car feel like a totally different rig. Here's where I welded the hinge back to the tailgate (both bolts broke off, and the tailgate is F****, so I dont care, I just wanted it to work) Tomorrow Im going to tackle the lower radiator support and build the pushbar for the bumper, then sometime in the next week I will get the skidplate made. -Bill
  12. I will be making this one this year I hope, can't see why I wont -Bill
  13. Pics from this morning The bumper is about half done, still need to make the pushbar portion of it and replace the lower radiator support. This bumper was a PITA to make, lots of angles, there are like 4 compound angles on each side. If I ever offer this style for sale, its not gonna be cheap And my temporary mudflaps, Ill make new, nicer ones when I make the rear bumper More to come when I get more done -Bill
  14. Yes, I was hopin I could pick that up while I was in the area -Bill
  15. A guy in DC was going to put a Jetta TDI motor in his GL-10, even made the adapter plate for the trans and everything... Concluded that in order for it to fit, the car would need a 6" lift as well as a fairly hi cowl-induction style hood, or some other way to make the hood close. This he did not want. The other thing, the gears in Subaru trans are so low compared to the TDI gears, that he would have to run 31" tires just to get a semi-reasonable gear ratio back. TDI motors rev to like 4000 RPM redline or something like that, and for an old Subie, thats just the halfway mark... Perfect if you want to do this for off-roading though, tons of torque, low speeds, great crawling. Here's the thread, idk if any of the links/pics are still good, but its a good read and might be able to ask him some questions http://ultimatesubaru.org/forum/showthread.php?t=94908&highlight=diesel -Bill
  16. Scott, You lifted a Gen 1 Legacy Sedan. I think you know how big a tire you can put on there But in all seriousness, I have no clue. Im not into the Legacy/OB stuff yet. With some wheel spacers though Im sure you can get around that spring perch issue... -Bill
  17. Check to make sure you have 2wd rear struts, someone may have replaced them with 4wd ones at one point. The 2wd struts are about 2" longer than the 4wd ones... Otherwise I would suggest trying some wagon springs or RX springs... -Bill
  18. If the FWD fuse is in the holder, it is in FWD. Take it out, and it *should* be in AWD... Try taking out the fuse? -Bill
  19. The purpose of the dual E brake setup is to aid in offroad situations, its a separate lever for each front wheel, so when one wheel comes off the ground and I lose traction, I lock the spinning wheel with the E brake, which transfers all the power to the other wheel It could also be handy for drifting/rallying, but I wont know until I try, I dont know of anyone using this setup for that purpose... -Bill
  20. Well, decided NOT to take this to Walker Valley on the 7th, its just not going to be ready, and the beast is already setup... So I dont have to rush/half-rump roast anything. Finally got my shocks sent back and am awaiting the correct parts, as well as my exhaust bends so I can rebuild the exhaust. I have done a little work on it lately, but I dont have any pics :-\ Got the front bumper about half made, just needs the pushbar part built now Welded the bad hinge that broke off the tailgate back on to the tailgate, and bolted it back to the Brat. Tailgate works right again! Lengthened the headers to just past the trans xmember, so I can drive it without worrying about dropping a valve Its Waaaaaaaaaay too loud, but it sounds awesome. Put some half-rump roast mudflaps on the back (no bumper yet) so I could drive it around. I also figured out what Im going to do about the lower radiator support, and Im going to be able to raise it about 3" or so when I fix it Pics will come tomorrow -Bill
  21. Im gonna tow it up on a trailer, I plan on headin up the night before so I dont have to get up at 3 to be there on time Id drive it over, except it would prolly take me 10 hours and this way I know I can get home (hence I can have more fun ) -Bill
  22. Ive decided to take the Beast instead of the Brat, I dont think Ill have the Brat ready by the 7th, and the Beast is already all set up, just need to tweak a couple things on it and it will be ready to go Happy Eric? -Bill
  23. DO NOT DRIVE IN 4WD ON PAVEMENT!!! Its NOT AWD, its 4WD just like any 4WD truck, ONLY use it on loose/slick surfaces. When you engage the 4WD, it locks the transfer gears and sends 50/50 power split to the front and rear diffs. its NOT AWD, there is no center diff or viscous coupler, and it was not designed to be driven in 4WD on pavement. -Bill
  24. Here are my offerings for 2" lift kits This is the Stage 1 kit. 2" blocks on all the body mounting points, 2" blocks on the front and rear struts. This one is $200 +shipping w/mustache bar core, $250 without a core And here is the simplest, quickest, easiest way to gain clearance on your EA82/Loyale, the Stage 3 2" lift. This is $100 +shipping The front blocks are cut at 18 degrees, so you should have no camber issues. Available in any solid/common color you want. Thanks! -Bill
  25. Probably not, but I want to get the more important parts done... things like the rear disks and some of the plating/reinforcing can wait... -Bill
