Everything posted by The Beast I Drive
Red Sedan Build , solid rear axle
The Beast I Drive replied to Scott in Bellingham's topic in Members Rides
If it was a good runner, I can prolly swing that... Any chance you could hold it for a month or so, I need to get a trip planned to go up that way and swap parts with Jeff anyways.... -Bill -
ATTN Bill Omlin
The Beast I Drive replied to RAugur33's topic in Meet n' Greet. Your USMB Welcome Center
Depends on what kind of lift you have. If you have the struts and crossmembers lifted the same amount, you need 12-23 degrees, but if you go 1-2" higher on the struts, you need 15-16 degrees or so. -Bill -
Radio Shack has some cheap (like 60 bucks) 40-channel units, which arent bad. Hook it to a bigger antenna and you can get plenty of range. I find its the antennas that break the deal for me, a new fiberglass whip is like 60 bucks with the coax cable.. I got my 15' whip on the Beast off a old-school Van at the junkyard for like 15 bucks Cobra makes good CB radios as well, huge selection from super simple little 40 channels to uber-fancy ones with a billion adjustments. -Bill
Ok. Kiwishooter has offered to collect, pack, and ship up to 10 D/R EJ transmissions from New Zealand to the US, for a Very reasonable price at that. I can understand why he doesnt want to spend more of his time than he has to for little to no profit. Regardless of what gear ratios will be sent here, Im sure there will be buyers. As for figuring the gear ratios, quickest easiest way would be to look at the tag on the rear diff. Typically, the rear diff ratio is a pretty good indication of what the trans gear ratio is (as Kiwi has already stated, the trannies are still in the cars) Also the door jam tag might have that info as well. As far as arguing and bickering and picking at one another, grow up people. GD if you want to argue over opinions, nit-pick at everything Kiwi says, and mar and slander every one of these EJ DR threads, feel free to do so. You have proven you can. But I and Im sure many others would appreciate it if you would stop. Its childish and stupid, if you have a problem with Kiwi or his merits/methods/reputation, take it to PM where it belongs in the first place. Good luck to all on this deal, if I was into the EJ vehicles Id be in on this deal, but Im an EA faithful... -Bill
Quick question, did the 1600 have the side mount starter? If it did, how much would you want for that motor? -Bill -
I am running 31" tires with an EA81 and it works just fine, and Im still using the stock Subaru drivetrain, no T-case. Its a little gutless on steep hills, but with the extra gears you have that wont be a problem. -Bill -
Idk, Ive heard different responses to that idea from several places, some say it would be non-interference becasue of the Phase 1 EJ22 heads, others say it would still be intereference becasue of the stroke on the 2.5 block... I honestly dont know... -Bill
ATTN Bill Omlin
I do compensate for camber, so it should all line up like stock for the EA81's though you will have to do a little hammer work on the inside of the strut towers, there just isnt any way around this... On the EA82's there is more clearance in the strut towers and hammering is not required... -Bill -
ATTN Bill Omlin
Checking Pm's... Ill be making some strut blocks this weekend to pass the time while I wait for Earl to come up... 4" for EA82? Or EA81? I keep forgetting which one it is... Also, anyone else interested in camber correct, 1/4 thick steel, strut blocks, please let me know ASAP and I will try to get them all done this weekend, just let me know if they are for EA71/EA81, or EA82. They will be $40 a pair no matter what size. Thanks, and sorry RAugur, Ive been dragging my feet on this really bad and Im sorry if I've irritated or frustrated you in any way... -Bill -
5 speed conversion
The Beast I Drive replied to lonnie's topic in Historic Subaru Forum: 50's thru 70's
send a Private Message to Bratsrus1 here on the board... He makes a kit that will allow you to bolt in a 5 speed with little to no modification... Even uses the stock levers inside. -Bill -
He's running a 390cfm Holley 4 bbl... You can get that damn near anywhere, or have it ordered in next day... -Bill
What timing belt did you use? Im assuming the EJ22 Phase 2 belt... I have been collecting parts and knowledge to build one of these myself, but Im going to be using Phase 1 EJ22 heads instead of Phase 2, and Ill but running Dual Weber IDF 40 carbs... The main thing I havent figured out yet is what timing belt to use, I figure the EJ22 belt, but I would like some clarification... -Bill
Rear half shaft replacement
The Beast I Drive replied to autobob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you are trying to replace a front axle, do just what Monstaru said. If you are trying to replace a Rear axle, put the brakes and the crown nut back on. The rear axles slide onto a stub at the wheel just like they do the diff, all you need to do is drive out the roll pin, and slide it off the stub. You might have to loosen the 2 nuts that hold the diff on the mustache bar to move it around some to do this, and you might need some penetrating oil (apparently Auto Tranny fluid works pretty good... Or get some PB Blaster), maybe a BFH and possibly a torch, if it doesnt want to slide... The stub stays in the hub and you don't even need to take the wheel off! -Bill -
overnight battery drain....arrgghhh
The Beast I Drive replied to monstaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I found a 100 amp Chevy alternator that fits perfect, all you need is one of those curved alternator brackets from a small block chevy (available at any auto store) The part number is 7290-9, I think thats a USA Industries part no., and I forget the application but it has the same case as a regular 60 amp alt for a 73 Chevy pick Up... -Bill -
I have a 86 GL wagon with a hitch that bolts up where the towhooks go as well as to the floor of the storage hatch... I built a tow hitch for a GL Coupe that bolts up using a bracket that slides in between the bumper mounts and the body and then wraps down to the towhooks, but Coupe bumpers mount totally different than the wagon bumpers.... -Bill
Motor Swap Done! Wiring gremlins
The Beast I Drive replied to hardtail_pride's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If the car the motor came out of had an oil gauge, then it has a different sending unit than the motor from the Loyal with the idiot light. You need to swap out the sending units and that should solve the problem. -Bill -
I actually have 2 other 85's, and the mirrors are the same as all the other GLs I have... I think theses were just a random option, or maybe a "sport" option or something of the like... As for the harvester, I dont have any good pics ATM, but its a hop harvester and is pretty much only used in the NW, the Europeans pick hops with a different method... Ill try to get some pics up after work tomorrow... -Bill
It is D/R 4wd, 5 speed, the mirrors are just like the ones on Jeszek's Loyale, I guess they were some kind of option? They are still power mirrors, but they are different from the ones on the other GLs and DLs that I have... The color is close to the original color, but it has been repainted once... -Bill
80 Brat problem
The Beast I Drive replied to ampsoma's topic in Historic Subaru Forum: 50's thru 70's
Did you charge the battery? If you drove it home with the alternator disconnected, it was not charging the battery, and your ignition was being powered solely by the battery's charge. It should be dead as a doornail and will need to be charged... Then try it again. -Bill -
I didnt get nearly as much done this weekend as I wanted to. I wanted to do the heater core in my '80 Brat, as well as install a CD player. But that didnt happen because I need foam for all the heater doors in the unit... So then I decided to work on this When I got it it would not move under its own power, both the front and rear driver side hubs were stripped out. So I replaced those hubs and now it drives It runs like crap ATM though, massive exhaust leak, disconnected lines/hoses everywhere, etc... I wanted to fix the exhaust leak at the least but had to go to work to fix a harvester.... At least I got it to move on its own though. Eventually I will fix the exhaust and put one of my Weber carbs on it, maybe clean it up a little (wont matter much, it has almost as much rust as Rusty) and replace the bumper and broken corner light. -Bill
My new 1981 brat!!!
The Beast I Drive replied to Pooparu's topic in Historic Subaru Forum: 50's thru 70's
Make sure you have good weather stripping, window seals, and vent seals, it would suck to have your brand new interior get ruined by one good heavy rain... -Bill
