Everything posted by The Beast I Drive
Ahh, the wonders of Fuel Injection... Very safe :-\ -Bill
Dust leaks rx/rs type body?
The Beast I Drive replied to Txakura's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Instead of taping over the trim panels, how bout removing them and then using that foam tape on every joint where they overlap? Then you wouldnt even be able to tell you did anything... Also +1 on sealing all the vent holes, make that baby air tight! I get a ton of dust that comes up through my door seals on my black Brat, mostly on the passenger side but that side got T-boned a while back and the repair isnt exactly top-notch. I also have a few holes in the firewall it comes through. Ill get mine all sealed and water-tight when I redo the interior and wiring, but thats a ways off... -Bill -
Get some 4.44 gears in there and you'll eat those deep mud holes! Bad rump roast man!!! -Bill
i want a UTE (MORE PICS LOOKIE )
The Beast I Drive replied to subaruguru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Welcome to the board! Nice photoshop, Ive seen 2 rigs actually done like that, one came out very well done, the other one, not so much... The ony drawback of starting with a wagon for this chop is the small doors and the window angle is all wrong. This time, by starting with a Coupe, we will get a much nicer overall finish and things will be more proportional. -Bill -
The front U joints are staked in, they aren't really replaceable... Unless you have some special tools. Its not like on a Ford or Chevy where you pull the springclip, there is no clips on theses... -Bill
From what I can remember off my head, thats a 2.2 with a Holley 390 cfm 4bbl carb. IIRC the crank is bent in that motor, but he was building a new one with new parts to have it ready by WCSS 10. From what i heard before the crank went bad, the car had huevos GRANDE!!!!!! Said he pegged the speedo needle in 3rd gear and was still going... it has a 5 speed D/R swapped in and custom 14" rims with like 27" AT tires. Modified Jeep roll bar, dual exhaust with stacks which sounds pretty sweet, onboard air, Peterbilt airhorns, working cyclops light, custom bumpers, 4" lift, and I could go on... I have not seen the Dual carb setup yet, but I have seen what those carbs will be sitting on... And it will "blow" your mind... -Bill
I also dont see how your rig can be chewing through tires any faster than Jeff's rigs, seeing as how you guys are using the same setup... Unless you have something bent or installed backwards/upside down... Have you had Jeff look at it? -Bill
Another Newbie with '82 Subie (Brat)
The Beast I Drive replied to SueBee2's topic in Meet n' Greet. Your USMB Welcome Center
Thats a sweet lookin Brat man! I would say keep it stock, it looks cherry! -Bill -
Two more to the stable
The Beast I Drive replied to The Beast I Drive's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I dont actually, I just sold it a few weeks ago... I have an EA81 that ran good when it was pulled, its a longblock right now, no manifold or disty... Its a hydraulic lifter motor too -Bill -
Those rims will look excellent on that wagon! Here's a tip for doing the rear fender clearancing, dont cut anything! Just beat it with a sledge to start with, then go in with like a 12 oz ball-peen hammer to finish it, that way you wont cut into the double walled section, instead you just roll the eadge into itself on the inside of the fender arch. I learned the hard way when I cut the rear fenders on the Beast, but I tried out the hammer method on a different rig, and I got the same amount of clearance, but it looks cleaner and I didnt have to cut anything at all:banana: Also, if you want, some time when you get it finished and you still want the shifter back to stock, we can work on that, maybe bring it to me or I can work on it next time im in Spokane Wouldnt take long. What size tires are on those wheels right now? -Bill
1989 coupe to Brat project
At the moment, the rear wiper doesnt work, I took all the wires out of the hatch before I tacked it in... Im pretty sure the plan is to remove the wiper motor though, the rear window is so diabolically huge in comparison to what the bed will be when its done, we talked about blanking out the stock rear window with sheetmetal and making a new opening fitted to a stock Gen 1 Brat rear window that I have layin around, which will also allow for the installation of a slider in the future.... The remains of the hatch will get cut off just below the wiper arm, and Im going to graft in a section of backwall from a 70's F-250... I still need to build up the bed sides as well, Im planning on recreating them to fit Gen 2 bed trim on, as I have a good set that would definitlely complete the look of this rig and really make it into a Brat. Im using a Miller 35 wire feed machine (mig) for the welding, I would be using my dad's Miller 135 machine but its at work, and I dont want to go get it... Its nice not having it here cuz there is that much more room... From the pics you can see how cluttered the shop is, and that was after I cleaned it... Unless you are really good with a stick welder and have 1/16" rods, I would not attempt something like this with a stick machine. Robbie did on his first attempt, and anyone who seen it can tell you it was NOT pretty... Looked like someone threw a bunch of oatmeal over a piece of swiss cheese... We also talked about a 4" lift and bigger tires, I think 30" Big Horns would look damn straight on this rig, or maybe some TSL Super Swampers on black 6 lug Blazer rims, but thats a ways off yet... -Bill -
Bad U joint at the 4wd output shaft is what it sounds like, replace that thing ASAP! -Bill
Ideas for unusual mods
The Beast I Drive replied to casm's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Oh forgot to add that all my off road lights are 4" farm implement utility lights 4" 100w bulbs are more focused and brighter than 6" 100w bulbs :banana: -Bill -
Lookin good man, when I did the shifters in my wagon, I had to re-make the bar that connects the shifter bracket to the trans, like an s-shape, and I had to make some funky bends in the other linkages to make stuff clear, but it all worked... On Robbie's car I made the shifter bracket bolt to the trans tunnel instead of the trans, and that made enough clearance to make straight extensions... That all kept the shifters at the stock location in the tunnel, changed the shifting feel but it works great. I hope your setup works as good or better! -Bill
That D/R is definitely on my list for one of these bad boys, I have a 76 SR tranny that *should* have the factory 4.11 gears, so Im going to try to build a 4.11 D/R 4 speed Im thinkin, if you could bring it to Evans Creek I could bring some money for it.... -Bill -
Unusual mods huh... Well I swapped an EA81 into the Beast for reliability (87 wagon, originally with an EA82 motor)... Ran with a Ford 2bbl carb for a year cuz it was layin around and I didnt have money for a Weber... Replaced my rear window with Lexan after I busted out the first one... Oh I made a sweet setup in the rear floor hatch so I could have my toolbox fit and still have a little trap door... I put lynch pins in the door hinges so I can take the front doors off at a moment's notice... Had a Craftsman screwdriver as a low range shifter lever, but it got in the way one day so i broke it off... Used 70's Ford F-series side marker lights for turn signals in my tube bumper... Found out the little side pockets in the floor in the back are just the PERFECT size to fit a gallon of oil where it wont spill... I attempted to make decent fender flares out of a plastic 55 gallon drum, but they ended up folding on me and look like crap now... Thats most of the more unusual mods ive done to the Beast.... -Bill -
As to your strut problem, I have a pair of Legacy struts here with EA81 top hats on them, I didnt do the swap so I dont know what was done or how well it will work, but just throwing that out there cuz it might be easier than modifying the strut towers... -Bill
Well, Robbie brought his rig out to the shop tonight, and I made quite a bit of possitive progress on it. First off, it is going to end up being the 3rd gen Brat that Subaru never made, but should have, I was able to convince Rob that the Brat look was a lot smoother than the Ute idea he had... So far we got a Wagon hatch tacked in as the back wall, but the window is HUGE in comparison to where the bed sides are gonna end up, so the glass is gettin tossed and the back wall will be modified to fit a Gen 1 Brat window I had layin around.... The work to actually make it look like a Brat is about 30 percent done, but the actual fab work to make it nice is about 10 percent done... It wont be finished by the show, but it will be there Rob has some pics that Im sure he will post soon... -Bill -
I wish I could say I was wealthy... Unfortunately thats not the case.... What little I make typically goes right back into my hobbies within a few days of recieving my paycheck, after the bills are paid of course... If I were smarter, I would save up more and buy nicer rigs, but I just cant pass up deals like these! Ive got 21 Subarus if I count all the parts cars, 1 has been my baby sibce I got it and modified accordingly, several are in various 'project' states, and a few others are diamonds in the rough awaiting their turn in the shop... One of the biggest advantages of living on the Yakima Res, they do not care how many rigs you have as long as you are far enough away from the main highways Eventually I need to build my own shop, even if its just a small 1 bay building, so I dont have to clutter up my dad's shop anymore... -Bill -
Dont make me bust out the all Subaru line-up pics -Bill -
lol I ran out of parking spots in the Subaru section... I dont think there is a cure for what I have... Hopefully I dont find it for a while -Bill -
Well, got a call from Jerry on friday night, turns out a farmer not too far from me had a pair of Gen 1 Brats for sale that were mostly complete... Obviously I couldnt refuse! the tan one has a title, although the vin number on the dash is not matching the vin on the firewall :-\ and the title has a brand code on it, so Im gonna have to see what thats all about. Other than that it just needs the radiator and the fuel pump installed to run The blue one is a bit rough, its been wrecked and re-built, and I dont know if Ill be able to get the title from the junkyard, but if I can, it is salvageable. The gas tank appears to be full of some kind of tar-like substance, which has clogged the whole fuel system, but once that is fixed, it will run. They were both driven to where I picked them up, been sitting for a year or so. I got 4 BRAND NEW studdles snow tires with a beefy tread, brand new in the box clutch kit, brake rotors, pads, and shocks, and both have minimal rust. I plan on making the yellow one a driver for sure, but the future of the blue one is still in the air atm. My red Brat is down for a while, after this happened. I can repair it, but damn it sucks. I had to drive it out of the woods like that. -Bill
