Everything posted by The Beast I Drive
is it possible for 5 speed swap in gen 1
The Beast I Drive replied to nevbrat's topic in Subaru Retrofitting
5 speed d/r, or 2wd? the dual range you will need a lift or some custom metal work on the trans tunnel or it wont fit. Also you would need a fat case EA71 ebgine bellhousing or a modified(?) EA81 engine bellhousing for the trans to mount to the motor, as well as custom tranny crossmember, driveshaft, and linkage. Doing a 5 speed/EA81 swap in a 80 Brat right now, 3 inch lift in the front, 6+ in the rear. The 2wd 5 speed was available in that body style, would be a bolt in I would imagine, you'd just have to dump the rear 4wd stuff. -
Wagon Stopped Running
The Beast I Drive replied to Robert M's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sounds like a timing belt, has happened to me many times I dont know about the starter though... -
Need more engine swap advice
The Beast I Drive replied to carfreak85's topic in Historic Subaru Forum: 50's thru 70's
I saw a red 81 Brat, it had an EJ22 in it, from Idaho, came and picked up a topper from me, I got to drive it he made cut outs in the framerails to make it fit right, was really nice! -
Electrical gremlins.... voltage related
The Beast I Drive replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
oohhhhh I see, I guess I should start running one of those in the Beast, my amp and my 100 watt offroad lights do draw a lot of power, especially running together. I want to do an alternator swap as well, but Im kinda lazy, and Ive only had to swap 1 alternator... -
Why the yellow top? I like the red tops myself... If I recall, the Blue ones are deep cycle for marine use, but what was special about the yellow ones? I forgot :-\ -
Amazing 85 GL in tough truck competition
The Beast I Drive replied to Gloyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I saw a EA82 Sedan at a monster truck show, musta been about 2000 or earlier, it was hilarious cuz this car was doing things even the tuff trucks wouldnt do, and it was stock! The funniest part though, was when they announced it was a Subaru, it was pretty quiet in the stands and all you could hear was this one guy yell at the top of his voice WHOOOOOOOOO SUBARUUUUU!!! I got a kick outa that -
now its time for a lift (hint hint )
I wonder, who here knows if the components inside Nissan rear axles are the same or close to the same as the Subaru diff parts, cuz if they are, many doors start to open...
I believe Suzuki commisioned Subaru to build the Justy under contract, but thats just what I have heard... Most of the Justy has almost nothing in common with other subes though.
Diamondplate steel, havent had a problem yet, and it has taken some abuse since that pic
Great stuff to know! Thanks for prompt replies guys. Im going to be leaving it independent supension, just because I have had a hell of a time trying to find solid axles that I can afford, and like I was sayin, its kinda a side project. I will be doing custom A arms for the front suspension, but I am leaving the geometry alone (lift the struts 9 inches, lift everything else 9 inches) so I dont worry about hyperextension. As far as welding the diffs, I wasnt planning on that, I am going to leave them open until I can get a hold of a pair of 3.9 LSD diffs. I wonder if there would be enough demand to commision Randy's Ring and Pinion or a similar company to start making high strength diff components? I figure if you upgrade everything just a little bit you can still expect the usual culprits to fail, just not as often as usual. So with 33's and medium trail use, with open diffs, I can prolly expect about 3 months or so from my axles?
Hey there all you big bad off roaders, I am wondering just how well the axles on EA series cars hold up to the quadrupled or more torque being sent through them due to the addition of a transfer case and oversize tires in excess of 30 inches. Also, I would tend to believe that more axles break on welded diffs than on open ones. What I am doing is a 9 inch lifted EA car with an EJ motor, nissan T case, and I plan on running 33 inch tires, and I want an Idea of about how many times I will have to replace an axle on the trail Also, has anyone looked into custom axles with U joints instead of CV's, or just stronger CV's? Lookin to make it as capable as possible, but cost is also a big factor here, this is more of a side project while I wait on some parts that I need for my Brat... Any and all information is greatly appreciated! Thanks -Bill EDIT:Oops, I meant this to go in Off road:banghead: Sorry Mods
use FWD transaxle as rear transaxle?
The Beast I Drive replied to Uberoo's topic in Subaru Transplants
more like a Saabaru 944 -
T-case lift FAQ (transfer case questions / answers)
The Beast I Drive replied to bushbasher's topic in Off Road
Indeed, Great thread, this is very helpful as I am building a T cased EA car as well... -
Single exhaust port EA63?
The Beast I Drive replied to Kostamojen's topic in Historic Subaru Forum: 50's thru 70's
Maybe an EA63 with EA71 heads? is that even possible? -
HELP!!!!!Homemade 2" lift in front***pics added***
The Beast I Drive replied to bigo1966's topic in Off Road
you could extend the lower control arms, but then I would be worried about over extending the axles -
WCSS 10 Logo Picked!
The Beast I Drive replied to WCSS's topic in Meet n' Greet. Your USMB Welcome Center
When can we enter for the logo contest for WCSS11? -
How can i lift my 86 gl sedan
The Beast I Drive replied to foxracer45's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes, your sedan can be lifted... -
Look what I did
The Beast I Drive replied to The Beast I Drive's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it works really well, and the box is fully removable, so If i need more room for say a large package I can always take out the box and I have all the hatch available (minus the 12 inch sub of course) I am gonna try installing side boxes in place of the little plastic compartments on my next project, so we will see how that works out -
nothing earth shattering, but since I have decided to use my wagon as my work/weekend warrior, I decided to install a tool box in the back, quite simple and tidy, and i still have a small smuggler's hatch, and the box itself is completely removable.
Question about early '80's
The Beast I Drive replied to cd45's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hey any chance it has the walnut 5 spd shifter knob? and if it does, would you be willing to sell it to me? -Bill
