Everything posted by The Beast I Drive
My address is 763 meyers Rd. Toppenish, WA 98948, easiest way to get here from Yakima is take the freeway and get off at the Zillah/Toppenish exit, turn right and stay on that road. You will cross the railroad tracks, then Highway 22, and my place is the one on the left with a row of Gen 1 Brats out front and a white 48' semi trailer in the driveway. Gimme a call 391-5903
-Bill
I can try to have one built by then, but Ive got a lot on my plate right now, but I think I can make it happen. A 3" lift is $250, and a 4" is $300. I'll get workin on one asap if you are interested, thanks
-Bill
Anytime after 5 on week days or random times on weekends works for me, if you cant get it to run right I might be able to come up there and see if we cant get it running better there, my number is 509-391-5903
-Bill
I will have a couple ready soon, I'll let you know, hopefully this weekend
-Bill
If you want, bring it down sometime, I have a ton of stock carbs in my stash, and Im sure we can get it running right
-Bill
There are a couple things you will need when you are getting ready to swap the auto for a 5 speed.
-Pedal box from the 5 speed car
-speedo cable for the 5 speed
-shift linkage
-front half of the driveline, as the driveline for the autos is shorter
-clutch cable
-tranny, clutch, flywheel, pressure plate, and the crank bolts for the flywheel.
-5 speed crossmember and mounts and body bushings/bolts, as the auto mounts completely different from the manual
-interior trim. Just the upper half of the shifter consol with the boot.
The swap itself really isnt that hard, and could be done in a day easily. Personally I like to pull the motor to swap trannies, but it would be just as easy in this case to drop the tranny for this swap. Its all pretty straight forward, the only part thats a little tricky is wiring for the manual, which still isnt that hard.
-Bill
