Hello all, This is my first post over here. I'm a regular to the tech forums on NASIOC under the same name. I know gobs and gobs about the newer subies, but the old stuff is beyond me and I'm looking for a new project. I'm sorry if there are already 100's of threads on the questions I'm about to ask, but I need to be getting to bed soon and I want to throw these ideas out there before I get to sleep.
I have a '98 impreza that has been through 4 engines ranging from the stock 165 hp to the current 470hp. Not much is stock chassis wise either. Basically I have an entire garage full of parts in boxes and nothing to dump them into. A little voice in my head was whispering things about a brat. I think I have already sourced a clean donor vehicle, but I would like to seek the advice of those more knowledgable than I on the old stuff. With the parts I have in the garage I will be able to slap together a good running EJ engine doing about 260hp naturally aspirated.
Now for questions as to what I will need:
I know the EJ engines will drop into EA applications without TOO much difficulty. I'm a master mechanic that can weld/cut so not much scares me. However I still don't know EXACTLY what needs to be done. If there are existing threads on the topic can somebody point me in the right direction?
I would like to use the 5mt case out of a WRX I have sitting on the floor, it should hold up to the power I will be making without any complaints. I realize the CV's will be vastly different than the transmission that comes out of the car. I'm not too worried about this, which brings me to my next point.
Is it possible to use either impreza or legacy hubs/knuckles without too much headache in these cars? I have a very nice set of fixed caliper wilwood brakes and rotors that I would like to donate to this car, along with all the other advantages of the newer style hubs (larger bearings, better wheel selection, etc.)
Rear differential... Do the brats come with the standard R160 diff? Something else? Can an R160 bolt in? Will I need to fabricate a rear crossmember for this purpose?
If using the newer style knuckles is completely out of the question, does anybody make adapter kits to use impreza/legacy calipers with a 5 lug hub?
Thanks in advance.
