francis
Everything posted by francis
  1. Thanks qman, that helps. what if people reply to my messages and I am not able to see them? sucks but thats the case... i dont want a useable subie going waste.
  2. how can that be? i have been a member since december 2003!
  3. bill see the pictures here : http://pg.photos.yahoo.com/ph/fpulipati/my_photos Decent car, 110k miles, runs good, has check engine light on code 34(no problem however), needs a newer y-pipe (jeff titus has a part available), power most options. 4wd works. minor rust damage. but interior is super clean.
  4. did i break some forum rules? it says its been moved and I cannot access it anymore. its about a 1990 loyale for sale in NJ before i donate it.
  5. Larry, Where is the sensor located? is it the one located near the thermostat with a black knob (looks like a knob) and some electric and vaccum connections to it? let me know if you find a minute. thanks, Francis.
  6. Guys, I posted earlier about my ac problems. AC was working fine till I tried to reset ECU code 34. I checked the fuse, and relay both are fine, is there any vaccum connections behind the HVAC controls which is preventing AC power up, the fan, compressor under hood wont start. But blower works. any ideas? what i should be looking into? its muggy and hot out here in NJ the after effects of hurricane Frances.
  7. thanks for the input guys, i will check it out and let you know of the status.
  8. guys, its my first post! got a 1990 subie loyale auto 4wd. 1. Check engine light has been comming on and off and now is on constantly, code on the o2 sensor light says '34' EGR solenoid valve. question: where is this valve? can i replace it? any diagrams or help? 2. AC was working till last week, i tried to clear the above code and connected the test plugs near the firewall, now AC not working (compressor wont engage) is there a fuse for the AC unit? no fuse for ac listed in the fuse box.. any help? thank you so much.
