Location
where at again
Interests
paintball and fabrication
Occupation
gm technicain
Biography
I am the penguin what
Vehicles
subaru rx
thepenguin's Achievements
Member (2/11)
10
subyrally's annual frederick cookout!!!
thepenguin replied to subyrally's topic in Meet n' Greet. Your USMB Welcome Center
does that mean no timmy for the tourny.. makes me sad going through withdrawls:slobber: -
I won't be able to make it up until the weekend of my good man. acts is comming to my home field.http://www.coastalpaintball.com/acts/currsked.html you should come down man we got a team teogher its going to be some kind of sweet. if nothing else I have a running bet on weither I can make it to snake off break agnist smithvegas. if you can make it down come on and anyone else who wants to come out and try your hand at acts speedball your welcome to join as well:banana: :clap: -
Other cars/Vehicles we own
thepenguin replied to DJtheGOD's topic in Non Soob Cars and Bikes Discussion
wow ok 1986 jeep comanche 2.5 4 speed daily driver 1984 jeep cj-7 4.2 5 speed 1977 jeep cj-7 v-8 auto 1968 camaro 327, powerglide 2 speed, 10 bolt 1947 willys army jeep 1952 willys pickup 1997 chevy tahoe 5.7 auto 4x4 1966 chevelle 396 turbojet, 700r4 12 bolt 1700 stall converter 1988 chevy camaro 383 stroker, stage 2 jasper 700r4, 12 bolt pose 1982 k5 blazer 350, 3 speed 4x4 1977 dodge w300 318, 2speed auto 4x4 full time and 1 1985 subaru rx is at my home, soon to be titled to meself, right now other owners car -
ok I am still at work. it doesn't matter what plug I pull. I am going to scope test the fuel pump make sure it has a cisp signal and power feed. I know its an electrical issue now the problem what electrical feeds both injector banks and does not set a check engine light. I will let yall know if I find anything more but my heads starting to hurt from beating it agnist the wall I going home
I got a 91 corvette in the shop.. this thing will not dile for crap once it warms up. its got 42 psi of fuel pressure on a hot soak and 32 while running. it has a oem distributor new fuel filter, plugs and wires, and even a new crank sensor.. still running like crap.. exhaust isn't clogged. mass air flow is working, iac working fine baros good ect is good the only thing I got to go on at this point is when you unplug one injector on either bank it smooths out.. it has two injector driver modules on two seperate circuits. they don't even share a common ground which I checked on both. I am at my whits end on this thing I really want to unplug an injector and give it back to the customer. please help:mad:
I have a subaru rx now butI started out as an old school jeep guy an I all alone:eek:
Best Demolition Derby subaru????
thepenguin replied to SuperBrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ok didn't read to the last post so don'tsmack me if I'm off topic. but the best thing I found for dd is a 1968 cadilac hurse with a big block 500 -
I may have an issue man the psp tourney is next month and the feild is required to have a certified air tech on hand. so if its the same weekend I sorry suby I may b able to I have to look at the date -
hun before you start working on paint colors and such you may want to think about correcting the cancer in timmy and the brat.. but I will get up there as soon as I can mabye bring my welder up to see what we can get done about the lift points
by the way congrats you have blood and time in the car now it is truly your project and his
hun it won't be the death of you itll be the death of tim and my sanity. of well to late. anyways I can come up there after the psp tournment at the feild. then I can evaluate and comence to drinking
yes I have started the unnoffical poke the timmy thread good luck man I hope you can get it worked out because theres no way I can offord to bring the trailer up there this weekend
I had a problem with the connection to the computer at one point on my 84 cj check and make sure the terminals are making contact and none of the tabs are bent down if you can get by with that look fora ground if you have both and you said the cam sensor is new then I would start check for signal going to the pcm using a old school scope. nothing says this is your problem like looking at the wave form when it goes. put put scrump
ya I am pretty sure its the same car minus the wheels and tires and a semi questionable engine.. but its a good start yes I am just poking at the timmy
