Chris W.
About Chris W.
- Birthday 01/13/1962
Contact Methods
Website URL
http://
Location
Boise County
Interests
Family, Fly fishing, Subarus, Telemark Skiing.
Occupation
Technician
Vehicles
93 Loyale, 84 Vanagon.
Chris W.'s Achievements
USMB is life! (4/11)
10
Just my .2 cents..... I replaced the rear window in my 87 wagon.....Total PIA! I'd rather replace an axle or my timing belts, than have to do that again:dead: As GLoyale stated, use the wire cutting meathod works the best IMO. If you havn't already started, be really careful with the trim pieces, those little button/connectors bust too easily. Cheers Chris
I'm getting around 32 mpg from my 93 Loyale, and thats with a stuck lash adjuster, and a Yakima rack It's got around 177K on it.... Love my Loyale, Chris
1991 ej22T into 1984 vanagon taking place!
Chris W. replied to SuperRallyRoo's topic in Vanagon Conversion Discussion
Thanks for the Tach info/ideas:) I met a guy in Boise that had a kickin Vanagon with an EJ25, He said a VW Mechanic in the Valley "Dougs Bugs" did his conversion, and set it up with a speed sensor. I'll try to investigate. Also found a VW web site that has a huge Vanagon section "TheSamba.com" Lots of conversion information. This web site (IMHO) is right up there with USMB Cheers, Chris -
That is one Sweet Vanigon!!! It's even the same colour as my 84! Please keep us posted on your progress! So....Doe's your 84 have a Tach? Do you (or anybody) know if a later model Tach/cluster will retro into the 84? I am already sick of the clock that doesn't keep time..... Thanks much for the pics, and good luck! Chris -
Welcome! Did you bring enough "White Russians" for all of us? Cheers, Chris
EA81 4 door sedan questions
Chris W. replied to newsoobdude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Several to be seen in the Boise Area, ranging from hardly running to cherry! Cheers, Chris -
Finally a Vanagon in the family!
Chris W. replied to Chris W.'s topic in Vanagon Conversion Discussion
Shawn Thanks for the reply/tips! I am sure down the road I'll be asking more questions.... Cheers, Chris -
Just brought home an 84 GL It has 169K, the body is straight, and best of all the Wife (and kids) love it! It runs like a champ, so we'll be able to drive it while gathering up all the necessary goodies to convert it to EJ22 power. Cheers. Chris
Nipper I think you might be on to something! I've had very little time to check on things...(already worked 50+ hours this week). I did check to see if there was any voltage getting to the pump, there wasn't If there is a relay, it isn't doing it's thing..... So, can you tell me where the realy is, and can it be checked? Oh, BTW, the car does have spark. Thanks much, Chris
The car was resealed and tuned up at 220K, so she's gone a little over 20K since. I don't know how handy I am, but I've managed to change my timing belts (twice, along with seals, oil pump rebuild etc.) and hange an an axle on my Loyale. Tomorrow, I'll have daughter turn her over while I check for spark Etc... Thanks again, Chris
Thank you all for the response! After reading my first post, I realised I wasn't so clear The car does indeed crank over, so I know the starter is doing it's job. It acts as though is't not getting fuel or spark, I don't smell any gas after turning it over? What is the best way to check for spark on EJ motors? What is the best way to check fuel delivery? The car also has 243,000 miles Thanks again, Chris
This morning Daughters 93 Impreza wouldn't start... Tried to jump it, no go. Put in a known good battery, still no go... Check engine light is NOT on (so I assume there are no codes to read?). Checked all the fuses, all good... I can not hear the fuel pump when I turn the ignition on? (the fuel pump on my Loyal is obvious). I did a search, and found that fuel pumps rarely fail (but can). sensors can go bad, but no check engine light? What should I be looking for??? I've realized how simple my EA82 is..... Thanks much, Chris
Sounds cool! Where are you going to mount the radiator? Front or Back? I'd be interested to hear how cool you can keep the engine? I've always thought an EA81 would do well in a "Bay Window" Bus:headbang: Cheers, Chris
After reading about SPFI conversions to EA81's, and thinking that would be cool....The thought came to me, why not replace my very tired and ticking EA82 with a fresh EA81??? Yes I have given much thought to an EJ22, but since I'm mostly intersested in milage and reliability, I thought the EA81 might be the easier swap? Please, feel free to give your opinion. Thanks much, Chris
