Everything posted by myles
Saab-aroo
myles replied to f15xxx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I'll bet Saab has pictures of it! -
Mobil One
myles replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
It'll likely still slap with Mobil1 10w30 (mine does). I'm going to try Mobil1 15w50 once it warms up a bit outside. Anyone try this vis.? -
A couple of things to keep in mind. The intake tract for the Phase-II (SOHC) 2.5L is different than that for the Phase-I (DOHC). To be more specific, the Phase-II has an air inlet just above the passenger-side head light (woo-hoo, factory cold-air intake!), and a resonator chamber just behind the ABS module. It's actually very well designed. As for the pulley, don't forget that it acts as a damper as well. Its mass may serve to cancel some crankshaft harmonic. I'll check the factory service manuals when I get a chance.
You have the redesigned clutch. No worries. Keep with the OEM air filter. K&N and its ilk yield little or no increase in output at the expense of allowing more wear-causing particles into the engine. If you want to increase output of a naturally-aspirated engine, cams are your best bet. To expensive? Perhaps a freer-flowing cat-back exhaust will get you a few more ponies. Don't bother with a cold-air intake. You already have one. I've not confirmed this with dyno. runs, but my '02 Legacy (same mill as in your Forester) feels more powerful when run on premium unleaded. Remember, this engine has a 10:1 compression ratio, which seems a bit high for gasoline with an AKI of 87. Perhaps the ECU is allowing more advance when I'm running with the premium fuel. I could confirm this if I had some wiz-bang OBDII software and an interface cable.
If you're looking for a trend (oil consumption in this case), you need to be consistent. You must check the oil level under similar conditions each time. Either check it after a fuel stop (while the engine's at operating temperature and the oil's had however long it takes to fill the tank to drain into the pan) or check it in the moring after the car's been sitting all night. Otherwise, you're comparing apples to oranges. Again, you're looking for _precision_, not accuracy. You don't need to know _exactly_ how much oil is in the engine (accuracy in measurement), you need to know how much the level dropped since the last measurement (_precision_ is important here, that's why you need to check the oil under the same conditions each time). Let me know how you make out with the clutch. Mine's been acting up since new, and the dealer claims she can't reproduce the problem, and by the time I arrive, the clutch is warm enough that it doesn't "chatter".
As for the chattering clutch, be prepared for the dealer's inability to reproduce the problem (denial is the word of the day). Later on I'll post a copy of the TSB for this issue, if you like. It may help your case (I didn't in my case). As for the oil consumption, my '02 Legacy (same mill as in yours) burns as much oil as your ride does when I drive it hard (frequent trips at WOT to the red line). If I drive it like the proverbial "little old lady", it uses hardly any. What oil are you using? I'm running Mobil1 10w30, but I'm going to try Mobil1 15w50 as soon as it warms up a bit.
