About ryry46d9
- Birthday 01/24/1978
Contact Methods
AIM
ryry6d9
MSN
doc_ryry@hotmaill.com
Yahoo
ry46d9
Location
pasco
Vehicles
86' GL
ryry46d9's Achievements
Advanced Member (3/11)
10
why not pull a jerry and mod a hatch (hatchbrat) seen his and loved it
love the bus!
are you useing photobucket?
Im about to replace HG any tips?
ryry46d9 replied to flyjum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
GOOD IDEA :clap: :clap: :clap: -
i use to have a 81' jetta with that set up i thought is was cool a buddy had a rabit same year but had a small pin-hole it the boot on top and that thing would idle but couldn't handle a load (took a few day to find the hole) other then that i like the way it looks i would like to see the setup pics when your done (trying to picture the injector setup) what block are you doing this to?
making a vibrationless 4x4 wagon
ryry46d9 replied to bgd73's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if you girls are done ........................ you stated "Also, I took driver side rear apart, taking hub off- all looked normal no chunks missing, and yet again eveidence of hardly any grease." drain your rear diff and fill it back up with what ever weight is rated for your weather im betting since the hubs where dry, that the diff haven't bein changed in years !!! its getting cold the viscostary its probley broke down and for my experience you will get that "winter buzzin" intill the grease/oil gets up to temp you old farts got years on me and not once did i see that talked about this is supposed to be a place to help each other out, not to have a cock fight!!! resolve it between your self or STFU ryry -
The Final Cut. And Thanks
ryry46d9 replied to robertwheeler's topic in Old Gen.: 80's GL/DL/XT/Loyales...
funny you dring that up my sister just gave me a 87' accord and my hatch is going to scrap also ryry -
86 hatch had to run 92 or it would run like it looks and ping under a good hard load around 260 miles per tank average ohh 1800cc NO-A/C NO-P/S 13" tires 4 speed D/R one time i drove to spokane from kent and forgot to fill up in cheany (?) town before Spokane any ways the gas gage was in the BLACK and i got 296 miles out of that tank and im sure a little dirt ryry
CV Joint - boot keeps ripping
ryry46d9 replied to washakie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i taking this as its the inside boot? i didnt have a boot problem but i did have a joint problem infact it was both at the same time some how the driver side motor mount boilts fell out and the motor was binding the joint look over the next one good before leaving the store try to lightly slide it off you got a life time waranty? in time you will have it down doing it in thier parking lot Kragen/shucks does sale "CHEAP PARTS" or as i used to say competivly priced when i worked for al's auto ,but rember your getting what you payed for got a NAPA around? got both mine for $125 exchanged and have put then through some painfull moments -
it does it all the time when it rains? my moms boyfriend was working on a customers car for almost 2 weeks (even drove it home couple of nights trying to find out what was going on) every time they came to his shop it was fine and showed no codes turned out when it rained the map senser would freak out telling the computer lies dont rember what caused it but i think it was a tare in the freash air line probley not your case but i thought i would share this crazy case ryry zzz
No idle after choke shuts off
ryry46d9 replied to chainman31's topic in Old Gen.: 80's GL/DL/XT/Loyales...
after it is warm will it idle? and also when the choke is on what are the RPM's ? -
do you got a towdolly? i got a 86 hatch i'll donate but its over here in pasco great parts car needs pass head
