3
Everything posted by porcupine73
True, maybe set your tire pressures per the door plaquard. Then when you get the chance measure the circumferences. The AWD and LSD rear diff are completely mechanical on this vehicle. Do you know which differential was replaced for the previous owner? (rear or center)? The center isn't really a 'differential' on this vehicle but sometimes people do call it the 'center differential'. Front diff is in with the manual trans.
Hi. I think that part is 803926070 CRUSH RING FOR FRONT DIFF DRAIN PLUG. The correct size copper sealing washer from the parts store should work. Reusing them usually works but Subaru does say they are a one-time use only item. I have some of these at home, I think it says the size on it or I can measure it. I have all auto trans soobs though, but I think it's the same drain as for MT"s. I did read on some site this person says you can re-anneal the copper by putting the washer it on a brick and heating it with a torch until it glows and then letting it cool. Not sure if that actually works or not.
Especially look at your rear tires. I'm pretty sure your soob has the VLSD viscous limited slip rear diff. If the rear tire circumferences are different by much, it may be heating up the silicone oil quite a bit at high speed driving, thus sort of locking the rear axles together, and causing rumbling/wheel hoping/etc from the different tire circumferences?
I think a discharged battery especially if the electrolyte is too high on the water side (not enough acid), then it can freeze. Maybe that's why yours looks buldged. Right on if you need the alt right away to make the vehicle driveable then whatever the local parts stores have may be your only choice, though parts store alts aren't the greatest. You could check with your local Subaru dealer (if you have one locally), but dealer prices on walk-in sales is usually pretty high. Also, I would suggest as you are doing your testing, etc., to put your battery charger on the battery on its lowest setting (ie 2 amps or whatever) to keep it charged. A low/weak battery you want to slowly bring back up. If the battery is dead/discharged when you put in the new alt its going to charge it like crazy and may reduce battery and alt life.
Sounds good! Main suggestion is to use a large phillips head screwdriver that fits it well. You ideally don't want to strip out that plastic thing. It's not expensive but if you damage it, it can be hard to find a replacement. Also I don't know if it's a good idea but I like to put a little bit of silicone grease on the threads and gasket of this plug when reinstalling.
Right on, make sure you got the california timing belt. For that vehicle, always give your VIN# to the dealer when getting parts and make them look up the correct part # for that vehicle. I'll look up the timing belt part #'s in a second so you can see which one you got. Also there is a good article on http://www.endwrench.com for 2.2L timing (not necessarily california specific) that I'll look up and post. edit: I see sea# 3 already got it! If you got to http://www.endwrench.com, click archives, and search for 'timing' there's several articles).
Right on, get the correct OEM Subaru reman alternator from a dealer. You can look up the OEM part # on such sites as http://www.subarupartsforyou.com just so like nipper said you don't get given an impreza or some other alt. Also right on, many warning lamps get their ground through the alternator field circuit so you may see flickering and such on other lamps when the alt is getting ready to crater. Also I think the ABS monitors voltage and illuminates its lamp if it sees it out of tolerance.
Hi nipper. Spring work indeed! Subaru fever. You probably already have seen the endwrench article about using the slide hammer puller method http://endwrench.com/images/pdfs/WheelBearing.pdf I think hohieu has done it with the hub tamer gadget. harbor freight sells something like the hub tamer but not sure if it has all the right size adapters and such. Getting that big lateral link bolt out in the rear always seems to be a issue (not sure if that's necesary if using the hub tamer/slide hammer method) See I didn't even post any pics in this thread yet
hehe, well I don't use the gallery either; I use a host that I have a bunch of other stuff on, as it is more convenient. I think the basics of picture posting are 1. crop - if your pic has lots of grass and sky or other irrelvant stuff, crop it out 2. try 'auto correct' - if the pic is too light or dark auto correct (if the pic editing software supports it) may help. If it looks worse just undo it. 3. resize - typically no more than 700px wide is best for forums. Some people (ie me) are running still running a relatively low 800x600 resolution. Yes there might be a few still at 640x480 but you can't make all the people happy all the time. 4. use the right format - jpg is good for pictures. gif works nicely for diagrams or computer screenshots.
Hi Skip yes that software looks pretty nice! I've been using ms office picture manager it seems ok for basic tasks. Another nice free one though it is a little clunky to use is irfanview. Does photobucket and such places have a time limit on how long they serve pictures? The nice thing pics as attachments to posts or links to the gallery here is that they are always available with the post.
need help
porcupine73 replied to Pebbles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Wow I hope you weren't hurt. Sorry about the soob. That's a nice one.
