3
Everything posted by porcupine73
Hm...your best bet, if you haven't done it yet, is to double check the timing after looking at the relevant parts of the article: 2.2 Liter Single Overhead Cam Timing Belt Replacement If it still looks good, you might want to try a compression test to see what numbers you get. I believe the article tells what values are normal and if one or two teeth off how much it drops. I think it says one tooth off it should still start; two or more no start. Fortunately your engine is non-interference, so even if the timing is way off there is little risk of damage (though if you get backfiring, etc that is not relaly too good).
Like with spark plugs, I believe the subaru service manual says if antisieze is used to reduce the torque by 1/3. It all depends on the torque spec. Like for the crank pulley bolt, the procedure is to apply engine oil before torquing; so no need to reduce the torque there. Other fasteners the torque spec is for clean dry threads. In that case applying antisieze or oil and then torquing to the clean&dry spec may result in over tightening.
Wow that toothed idler wanted to get out of the timing cover something fierce! For the red single row vs black double row idlers, yes when I ordered those OEM idlers earlier this year for my '96, I received two double row/black idlers. The black/double row can handle more load than the red/single row. The upper idler definitely appears to have more load on it; the lower idler not so much. I don't think the red/single row idler is capable of withstanding the load of being in the upper position long term. It is kind of hard to tell from the pic if the upper idler is red or black. Unless the red idler were replaced with black at some point in the engine's life, or came from the factory with two black idlers, then it is reasonable to figure the upper idler is red, since a black one is definitely in the lower position.
Plus it is a great excuse to pick up some tools (i.e. mityvac ) Sometimes on the rears (on the newer multilink rears anyway; not sure about the earlier ones) the lower caliper bracket to bearing housing bolt can benefit from like a 60 deg. offset wrench as there is no way to get a normal wrench on it or a socket (flex socket can get at it but seems awkward to use there).
Right, most front rotors these days are at least vented. The brembo blank rotors there are a good value. The hardest part I have had in soob brake jobs is getting the caliper bracket to bearing housing bolts out, especially if you live in a rust/salt belt area and/or if they haevn't been removed lately or were overtightened or some combination thereof. Other than that it is a pretty straightforward job; a Haynes manual is adequate for this. Just their brake bleed order for soobs is wrong.
Right on, if the wheels are 5x100 you should be good. Some newer soobs especially STI's have 5x114 or something like that; those would not work. If you use oil or antisieze or anything on the lugs, you need to consider that most OEM torque specs are for clean dry fasteners. Typically with antisieze you need to reduce torque by up to 1/3. Hi 86BRATMAN!
If you're looking for aftermarket parts, possibly the kits on eBay. At that mileage, if you're planning to keep the vehicle, I'd replace all the idlers, tensioner, definitely the water pump, the cam seals, crank seal, reseal oil pump and replace o-ring, make sure oil pump screws aren't backing out (on my '00obw three or four of the screws were very loose). I'd compare the cost for OEM vs aftermarket; for this job it might be a couple hundred dollars more for OEM but in my view if you're keeping the vehicle for another 100,000 miles very worth it for the peace of mind of oem components.
