3
Everything posted by porcupine73
Here are the most common Subaru oil leak locations with pics: Front cam seals (especially the earlier black colored seals; the newer brownish colored ones hold up better) (pics from an EJ22): Front crank seal (esp the mid 90's 2.2L's and some others where the screws on the rear case of the oil pump tended to loosen, letting oil out the front crank seal and sometimes even pushing the seal right out) Also there is an o-ring between the oil pump discharge and block The valve cover gaskets, and for engines where the spark plug tubes penetrate the valve cover, the spark plug hole seals. EJ22's also have an o-ring at the LH rear and RH front of the cam's: Also rear main seal, especially if the vehicle had a plastic rear main seal retainer/oil separator (an OEM upgrade to a metal retainer is available).
Hi and What head gasket issue are you having? I would go with a new OEM timing belt on that job too. It has to come off to do the head gaskets anyway; and it's maybe a $65 part which is small compared to the cost of the rest of the work. The price on that amount of work is sure to vary widely, i.e. local shop, dealer etc., so I would guess $1200-$2200.
I don't know exactly what model years this bulletin applies to, but it may be of interest (may only be applicable for US spec soobs too) NUMBER: 09-34-96 DATE: 09/13/96 APPLICABILITY: LEGACY, IMPREZA, AND SVX WITH EGR SUBJECT: FUEL INJECTOR REPLACEMENT If you should receive a customer complaint of a Legacy, Impreza, or SVX being difficult to start, after a long cool down period (such as overnight) under extremely cold temperatures and high relative humidity, it has been found that under these conditions ice may build up at the tip of the injector and cause a no start or hard start condition. OBDII equipped vehicles will illuminate the MIL and exhibit trouble codes, P0301, P0302, P0303, P0304 (P0305 and P0306 for SVX). A newly designed injector is now available to prevent the condition. All injectors should be replaced with the newly designed injector as a set of 4 (6 for SVX).
I've done it depressurizing and without; now I just open the gas cap some and wrap a shop towel around the fuel hose before pulling it off. Some fuel will spray out but not a ton. Wearing chemical splash goggles is always a good idea. Here's a connector that can be undone if desired (this is how Haynes says to do it) then crank a few times: Fuel filter:
hm...good diagnostic work. You can probably ignore my long shot hunch since you have codes to work with. There's a good articles on endwrench.com for the 4eat phase I. Yes those early 2.2L Legacies are pretty quick, maybe it was before the ODBII emissions requirements or something. Make it a turbo and fllllyyyyyy
Also maybe double check the thermostat for full opening in nearly boiling water. I turned my old stant thermostat into a 'blank' for testing purposes. The gasket still stays in place to prevent leaks between the water pump and thermostat housing. If you do this to your old thermostat, and run that, and still get the overheating, then you can rule out the thermostat.
Hi. Hm, interesting. That seems backwards from the way they describe it working in the service manual. It's supposed to be more prone to hold top gear with the cruise on to improve fuel economy. Factory service manual can be had on CD for about $200 from techinfo.subaru.com or there are other subscriptions available like 72 hours where you can download the portions you really want/need. If you want print manuals often the OEM manuals can be found on eBay for maybe $200/set. Or alldatadiy.com has subaru oem service info on a subscription basis. Of course there are the $5 ebay cd's.
Hi Rev. I could be waayyy out on a limb on this one but I think possibly a bad/dirty TPS could cause this issue. The power light comes on when the TCU switches to 'power mode', which basically happens when you press down on the throttle fast enough (rate of change). So if you're cruising along at say 20% throttle and that happens to be bad spot on the TPS and say then the TPS tells the TCU you're now running at 60% throttle that might be enough to make it go to power mode and downshift for a split second. Anway there are excellent detailed articles about how it all works for the phase I 4eat on http://www.endwrench.com just click archives and search for 4eat.
