3
Everything posted by porcupine73
Hi. Yes I just did a 2.2L timing belt and noticed a similar thing on the LH cam pulley. It looked to be a little too far cw to the indent on the timing belt cover. However, the marks on the timing belt were perfectly aligned with the dashes on the sprockets. When I pulled the tensioner, the LH cam moved slightly ccw and then it was right on. So basically I think you start with the cams aligned to the points on the timing cover, then hang the new belt and make sure the teeth counts/marks on the belt are correct with the hashes on the cam sprockets and you're good. And the crank sprocket too of course. The tooth counts are the important thing. edit: also are you using an OEM belt? Those marks seem to be dead on; not sure about aftermarket belt marks.
Yes many of the items call for inspection only, but if you look at the 'footnotes', there are exceptions for various items for 'severe duty' including towing, cold weather operation, dusty conditions, short trips, etc. You can view the sched. at http://www.subaru.com and click 'owners' from the top menu. For fuel injector cleaners I like Lucas UCL with some RedLine SI~1 mix. I add a little bit at EVERY fillup. The detergent pack of even 'top tier' fuels is lacking.
Yes it's kind of like a toggle switch. Make hard left esp over railroad tracks, then happily drive vehicle above 60mph no shimmy, can start/stop, sit overnight etc., but curse the time I make a sharp right, then go over 60mph, shimy is there, until I can find opportunity to make sharp hard left again.
One place to look is at the exhaust gasket donut after the rear cat before the resonator. Those can rust out and start leaking. If that's it, you can get a Subaru kit to fix it that includes the donut gasket, bolts, nuts, and springs (as all those will be fairly rusty too, and the bolts will probably snap when you try to remove the nuts). Some pics from my job for this on '00obw:
Good call on going OEM reman alt vs parts store. Yes slow charge battery overnight so it is completely charged when you leave. If you don't run the headlights, heater, a/c, defrost, etc., you can get a few hours runtime if you have a good batt. Yes definitely unhook a battery cable before starting work; the large gauge wires to the alt are always hot. Not sure if it is the same for your vehicle, but here is belt tension for '00obw:
There's some good articles on http://www.endwrench.com about how the VDC system works; it looks pretty neat. I looked at '06 baja's on http://www.cars101.com; it said the turbo adds "Optional SportShift automatic transmission with VTD awd system"; the turbo with leather package had "Automatic SportShift transmission with VTD all wheel drive". I didn't see VDC.
For the rear diffs, a 1/2" drive breaker bar or such will work. I use a 1/2" pipe plug socket. It's probably actually metric like 13mm or something but 1/2" seems to work. Transmission drain plug might be 17mm; I have all autos. Common soob fasteners are headed 8mm, 10mm, 12mm, 14mm, 17mm, 19mm, 22mm Newer soobs use a T70 torx for the transmission items to hopefully keep the iffy lube type places from draining it when intending to drain the engine oil.
