Everything posted by porcupine73
Coolant Leaking from bleeder screw?!
porcupine73 replied to Bmm001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should be able to just replace the bleed screw if the rad threads aren't damaged. You'll have to get the nipple out of the rad if it is stuck in there. A small ez out used carefully will probably remove it.
porcupine73 replied to Bmm001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRight, it might just not be tight enough. With engine cold I would remove it with a large phillips screwdriver and inspect it. Make sure the little rubber gasket is in good shape, there isn't any debris under it or anything, etc.
2.2 engine question
porcupine73 replied to bratsrus1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXARP makes a head bolt or stud kit I believe for Subaru engines; I've seen it on summitracing.com The torque procedure was revised for some engines; I've seen articles on endwrench.com about it.
Air Bag Warning Light
porcupine73 replied to Attempt6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's just coincidence. You probably want to read the airbag codes and see what problem it is experiencing. I believe this article has the instructions for reading the code: Subaru Supplemental Restraint System Service
2.2 engine question
porcupine73 replied to bratsrus1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe service manual does not say the head bolts have to be replaced. I believe they can be reused because it is aluminum head and aluminum block so the bolts do not stretch to yield like they would on cast iron.
front diff question
porcupine73 replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRight, typically the entire transaxle (AT and front diff) would be replaced. It is possible to service/rebuild the front diff though if that is the desired route. Here's where someone did that: http://www.subaruoutback.org/forums/showthread.php?s=&threadid=8718
Code 13 and car wont ignite...
porcupine73 replied to kellen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh ok I didn't see the '95 or '96 restriction. I guess that means Subaru considers the 'useful life of the vehicle' to be maybe about 13 years? That's pretty reasonable I guess; I think many manuf's aim for a 10 year lifespan.
porcupine73 replied to kellen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice finds! In another recent thread, someone contacted Subaru about a seatbelt issue and got it all fixed for free, as Subaru said something like 'Subaru seatbelts are warranted for the useful life of the vehicle'.
porcupine73 replied to kellen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlright that's good news! Congrats. Well hey that's still a pretty good batting average! When I pulled my first oil pump I didn't notice one of the bolts and bent the pump case whilst prying like crazy... :-\
CV Axel Nut Removal--Grrrrrrrr....
porcupine73 replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUh..d00d your age says 22! haha. Yes the 4 ft pipe is not a tool in itself necessarily, but it does help hand tools to work better! Like those old BASF commercials....
Transplanted EJ22 Overheating - HELP
porcupine73 replied to PATCO's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCongratulations! Thanks for posting back with results.
Spring Pin???
porcupine73 replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhaha, well yes I do take pictures of every job I do. I always intend to do a writeup for it but I never get around to it. But then when someone asks a question I remember that I have pics so I figure might as well post 'em at least.
Spring Pin???
porcupine73 replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's just one of the issues I have with the haynes and such manuals; for a lot of things they use some generic description without pictures of how to perform a task if it is close enough. I just did this axle job on '00 obw. It took me a while to think of putting the punch in a socket like that. Tried to punch it out from the bottom, nope that wasn't going to work. Not enough clearance down in there to really swing a hammer, as least not without hitting other things.... Here's where the bearing housing dropped out of the strut to free the axle; others do it different ways:
Ssupension/Shocks
porcupine73 replied to NCH's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi. KYB GR-2 is one option; Bilstein's are nice but they only make them for a few Subaru's.
Spring Pin???
porcupine73 replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi. IIRC you drive the pin out from the non-beveled side and drive it in from the beveled side. I put some penetrating oil on the pin before trying to drive it out. It took a bit of force to get it to come out. I used this pin punch, but I forget what size it was (edit: I think it is 7/32", not sure): What I hear is you definitely do not want to use too small of a punch as it can mushroom the roll pin head and jam it firmly in place so it won't come out, and possibly jam the pin punch in the hole as well. From this pin punch set (just saw one of these for not too much on eBay; auction might still be on): This is how I drove it out since like you said access is limited. I pounded on the top of the end of the socket extensions, inside of which was the pin punch: New oem roll pin/spring pin:
porcupine73 replied to kellen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes good pic of the failed bearing. Typically the toothed/geared one seems to be the most common to fail. No damage would have been done to the engine since that one is non interference.
90 legacy eninge into 96 outback?
porcupine73 replied to SubaruJawn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes that would be a nice find. I see Subex location says international. So maybe s/he does not have to deal with the ODBII issue? Is that pretty much a U.S. emissions thing, or do other region spec vehicles use ODBII as well?
porcupine73 replied to SubaruJawn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes your '96 Outback presently have a 2.2L (I think the MT's had the 2.2L)...
porcupine73 replied to SubaruJawn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA main issue may be the '96 is ODBII and the '90 is not.
Scan Gauge II
porcupine73 replied to rlsimpso's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks good. I think what happens is, ODBII protocol allows a value to be requested, such as fuel pressure. If the ECU does not support that value, it has the option of somehow returning a zero or null value or something; or not responding or returning anything at all, which seems to be what happens in the case you mentioned, since the SG just kind of hangs. I had that issue on my SGI with my '96, but fortunately for some strange reason I read some parts of the manual before using it and noted the different setting for that era Subaru. I did not in my '00obw it works with the setting on 'all'; it doesn't have to just be 'supported'.
ABS/Wheel Sensor
porcupine73 replied to jcniest5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can just ground one pin on the ABS diagnostic harness and it will start flashing out the code on the ABS light. It gives a good idea of where to look.
Pearly Baja????
porcupine73 replied to Hocrest's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDidn't see anything like that for 2003 or 2006. Cars101.com shows: For 2005 there was a "Satin White Pearl with brilliant Silver metallic accent" available with the turbo. For 2004 there was a "White Frost pearl with Silverstone lower accent" available with the turbo.
Looking for Legacy FSM info
porcupine73 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure if these are what you're looking for, but they are for a 1996 Legacy 2.2L: The images are kind of big so you might have to save them and open them in an image editor/viewer to zoom in.
Vehicle Dynamic Control availability?
porcupine73 replied to gcleeton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes additional things keep becoming required. Not sure about VDC's requirement. Is ABS currently a requirement? I think in the upcoming EndWrench Subaru noted that TPMS is required on all U.S. vehicles beginning in '08.
porcupine73 replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOr autozone or similar place may have them available for free loan. Esentially in those cases you buy the tool and if you return it within the prescribed time they will refund your money.
