Everything posted by porcupine73
Vehicle Dynamic Control availability?
porcupine73 replied to gcleeton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrom cars101.com, discussing the 2007 Outback lineup: There are a lot of variables in an insurance rate, so even if VDC got some discount, it might be more expensive to insure because the Soobs with VDC are generally more expensive.
CV Axel Nut Removal--Grrrrrrrr....
porcupine73 replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes as mentioned make sure the axle nut is 'unstaked', else it won't budge. Penetrating oil and heat can make it easier. I've used a 3/4" breaker bar from Sears and a 32mm 6pt Armstrong socket from mcmaster.com A small compressor can operate an air impact wrench in short bursts.
97 2.5 valve adjustment
porcupine73 replied to scotte6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSure. I like that article. I found it accidentally when looking for something else one time. Unfortunately they mis-spelled 'valve' as 'vlave' in the title so it doesn't come up in a search for 'valve'.
Code 13 and car wont ignite...
porcupine73 replied to kellen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhoops! Fortunately that is a non-interference engine so no damage was done. If it's a manual trans, put it in 5th and set the parking brake that should be sufficient. Prybar inserted into the bellhousing works well and is fairly easy to do. On my 2.2L, if you look kind of along the plane of the starter near the top of the engine, you will see a black plastic/rubber plug. If you pull that out then you can shove something in there like a big screwdriver, socket extension, prybar etc to hold the crank still. I have a picture of it at home if needed. Be careful not to damage the TPS or anything that may be nearby. Chain wrench holds the crank pulley fairly well. Harbor Freight is the only place I could find locally that had a chain wrench with a chain big enough to fit around the crank pulley. Wrapped the pulley with some old accessory drive belt to protect it from the biting of the chain. I found the prybar method above to be easier to do though:
porcupine73 replied to scotte6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2.5 Liter Twin Cam Engine Vlave Adjustment
EJ22 Timing Belt changed No start
porcupine73 replied to Tedder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGlad you got it straightened! The arrow denotes piston position for checking valve clearances, though on models with HLA's this isn't used as oft. Fortunately you had a non-interference 2.2L; anything else would have bent valves.
It's time to bring backthe justy ... or similar.
porcupine73 replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSheesh if Scion's are popular in the U.S., Subaru should definitely be able to sell that thing!
porcupine73 replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTop speed was 123.224mph. Check out the article: http://www.driveperformancesubaru.com/version4_1/atticpart2.asp
porcupine73 replied to kellen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh ok thanks. Well it must be since it did turn out to be the timing belt! Yes check the oil pump rear case cover screws for backing out if it hasn't been checked previously, as this did happen on earlier 2.2L's. If your front cam and crank seals are still the older black style (that tended to leak) might as well update them with the newer brownish style.
Engines
porcupine73 replied to NewKens1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOr if you want to pull out all the stops, http://www.ccrengines.com you could even stay with a 2.5L then reliably if desired.
2.2 Oil Leak Passenger Side. What to look for?
porcupine73 replied to jonfit04's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, that kit sounds like it has all the gaskets and seals you need to R&R the valve covers. Those are the seals that go over the valve cover bolts to prevent oil from leaking out through the bolt holes. They look similar to the washers in my first pic above.
Carman?
porcupine73 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI haven't used it, but it looks pretty neat. I've seen a somewhat similar device but it only works on CAN bus vehicles.
porcupine73 replied to jonfit04's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo it is not necessary to drain the engine oil before removing the valve cover gaskets. You will get a little bit of oil coming out but not much. Draining the engine oil will make no difference. Obviously do not start or crank the engine with the valve covers off or then you will get oil spilling out. I forgot to mention, optionally wash/spray the areas around the valve covers, and definitely blow out with compressed air, before removing the valve covers. Otherwise all kinds of little pieces of grit and stuff will get in there when you take the valve covers off. If you're changing the oil, I would do it after the job is completed. Subaru dealer who sells parts online; there are many - example: http://www.subarupartsforyou.com/cp_partdetail.php?partid=3497
porcupine73 replied to kellen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWould you get code 13 if the timing belt broke?
porcupine73 replied to kellen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi. Focus on the code 13 first. The vehicle will start and run without the o2 sensor, but not without the cam angle sensor. Check the cam angle sensor. It is located at the back of the LH (driver side) cam cover. Make sure it is firmly mounted and the connector is on and looks good. If those look good maybe take the sensor out, tap it some, etc., put it back in and see if it works. There are some tests you can do for the sensor with an analog voltmeter. I can post more details if desired. Here is where the cam angle sensor is. This pic has the timing covers off and some other parts removed, but should give you a general idea of where to look. It's near the engine oil filler cap.
porcupine73 replied to jonfit04's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor tools, an assortment of 10mm stuff can be helfpul; like socket, ratcheting wrench with flex head, flex head socket, etc. When you reassemble, do not overtighten the valve cover bolts - they will strip. Tighten each one a little bit until they are the desired torque. Don't tighten the first one down all the way, then the next, etc. Valve cover bolt hole washers for a '96 2.2L: Valve cover gaskets for a '96 2.2L: Spark plug hole seals for a '00 2.5L (sohc). Note: On my '96 2.2L, the spark plug holes/tubes do NOT penetrate the valve cover so it does not use these seals.
porcupine73 replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat's those cars with 3 wheels called? Has that single wheel in the front for steering...those are kind of freaky. I saw some of those on the main highways in England which seemed insane!
porcupine73 replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell there are foreign auto importers if the desire is strong enough
New Multi-Layer Steel Head Gasket Questions
porcupine73 replied to mnwolftrack's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, for Subaru and many other manufacturers, alldatadiy has the OEM factory service manuals, with all updates and service bulletins.
porcupine73 replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Justy is back! In Europe anyway.... The Justy still holds a world land speed record at the salt flats for the 1.0 Production Class. Fuji Heavy Industries Introduces the New Subaru Justy in Europe Frankfurt, September 11, 2007 – Fuji Heavy Industries Ltd. (FHI), the maker of Subaru automobiles, announced that it will unveil its new Subaru Justy at the 62nd Frankfurt International Motor Show (IAA) and it will go on sale in Europe immediately following the Frankfurt Motor Show. The new Justy is positioned as an entry-level car in Subaru’s lineup. While offering nimble maneuverability and cabin roominess, the new Justy boasts exceptional fuel economy and low emission levels, thanks to the compact 1.0-litre engine. Two versions will be available in the European market: the sporty 1.0S, and the practical city-driving 1.0E. Both versions are front-wheel drive with 5MT. The new Justy will be supplied by Daihatsu Motor Co., Ltd., under an original equipment manufacturing (OEM) agreement with FHI. Subaru Justy 1.0S Major Features of the New Justy • Overall length 3,610mm, Overall width 1,665mm, Overall height 1,550mm • 1.0-litre DOHC 12-valve inline 3-cylinder gasoline engine Max. output (DIN): 51 kW / 6,000 rpm Max. torque (DIN): 94 Nm / 3,600 rpm • Front-wheel drive with 5MT • 155/80R13 Tires with full wheel caps (1.0E) 175/65R14 Tires with aluminum alloy wheels (1.0S) • SRS* front airbags and front side airbags (for driver and front passenger) • SRS* curtain airbags (front and rear, both sides) (1.0S) • Body colored electric door mirrors • Chrome accented gearshift knob (1.0S) • Manual seat lifter (driver’s seat only) (1.0S) • ABS with EBD (Electronic brake force distribution) * SRS: Supplemental Restraint System. Effective when used in conjunction with seatbelts. About Fuji Heavy Industries Ltd. Fuji Heavy Industries Ltd. (FHI), the maker of Subaru automobiles, is a leading manufacturer in Japan with a long history of technological innovations that dates back to its origin as an aircraft company. While the automotive business is a main business pillar, FHI’s Aerospace, Industrial Products and Eco Technologies divisions offer a diverse range of products from general-purpose engines, power generators, and sanitation trucks to small airplanes, crucial components for passenger aircrafts, and wind-powered electricity generating systems. Recognized internationally for its AWD (all-wheel drive) technology and Horizontally-Opposed engines in Subaru, FHI is also spearheading the development of environmentally friendly products and is committed to contributing to global environmental preservation. Now here was a Justy: http://www.driveperformancesubaru.com/version4_1/atticpart2.asp #440 Justy currently holds the land speed record for its class.
Trouble with auto shift lever
porcupine73 replied to northguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes it seem like it is that solenoid thingy that pulls in when you step on the brake? That interlock doesn't have a lot of force capability, so maybe if you can clean it up if it's grimy and use some graphite or other lube that won't attract dirt maybe that would help.
porcupine73 replied to jonfit04's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd those sealing washer things that go over the valve cover bolts.
ABS/Wheel Sensor
porcupine73 replied to jcniest5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOr one from a salvage yard or car-part.com if you want to go the used route.
porcupine73 replied to jonfit04's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSome potential leak points are rear main seal retainer, valve covers, front cam seals, front crank seal.
Gotta turbo legacy! **PICS**
porcupine73 replied to Hondasucks's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYah maybe the earlier models info isn't correct. It doesn't have as much detail on early models as it does for later modlels. I'm sure Joe would appreciate knowing any corrections. edit: okay I was reading the site wrong. '0' means 'optional'; I thought it meant not available.
