3
Everything posted by porcupine73
The Justy is back! In Europe anyway.... The Justy still holds a world land speed record at the salt flats for the 1.0 Production Class. Fuji Heavy Industries Introduces the New Subaru Justy in Europe Frankfurt, September 11, 2007 – Fuji Heavy Industries Ltd. (FHI), the maker of Subaru automobiles, announced that it will unveil its new Subaru Justy at the 62nd Frankfurt International Motor Show (IAA) and it will go on sale in Europe immediately following the Frankfurt Motor Show. The new Justy is positioned as an entry-level car in Subaru’s lineup. While offering nimble maneuverability and cabin roominess, the new Justy boasts exceptional fuel economy and low emission levels, thanks to the compact 1.0-litre engine. Two versions will be available in the European market: the sporty 1.0S, and the practical city-driving 1.0E. Both versions are front-wheel drive with 5MT. The new Justy will be supplied by Daihatsu Motor Co., Ltd., under an original equipment manufacturing (OEM) agreement with FHI. Subaru Justy 1.0S Major Features of the New Justy • Overall length 3,610mm, Overall width 1,665mm, Overall height 1,550mm • 1.0-litre DOHC 12-valve inline 3-cylinder gasoline engine Max. output (DIN): 51 kW / 6,000 rpm Max. torque (DIN): 94 Nm / 3,600 rpm • Front-wheel drive with 5MT • 155/80R13 Tires with full wheel caps (1.0E) 175/65R14 Tires with aluminum alloy wheels (1.0S) • SRS* front airbags and front side airbags (for driver and front passenger) • SRS* curtain airbags (front and rear, both sides) (1.0S) • Body colored electric door mirrors • Chrome accented gearshift knob (1.0S) • Manual seat lifter (driver’s seat only) (1.0S) • ABS with EBD (Electronic brake force distribution) * SRS: Supplemental Restraint System. Effective when used in conjunction with seatbelts. About Fuji Heavy Industries Ltd. Fuji Heavy Industries Ltd. (FHI), the maker of Subaru automobiles, is a leading manufacturer in Japan with a long history of technological innovations that dates back to its origin as an aircraft company. While the automotive business is a main business pillar, FHI’s Aerospace, Industrial Products and Eco Technologies divisions offer a diverse range of products from general-purpose engines, power generators, and sanitation trucks to small airplanes, crucial components for passenger aircrafts, and wind-powered electricity generating systems. Recognized internationally for its AWD (all-wheel drive) technology and Horizontally-Opposed engines in Subaru, FHI is also spearheading the development of environmentally friendly products and is committed to contributing to global environmental preservation. Now here was a Justy: http://www.driveperformancesubaru.com/version4_1/atticpart2.asp #440 Justy currently holds the land speed record for its class.
Simple propane or mapp is nice for fasteners. Mapp burns a little hotter as it has some propodiene or something added to the propane. The kind with the rubber hose is nice because it is easier to manipulate the torch end, although it is easy to tip the cylinder over. For cutting you'd need like oxygen+acetylene or maybe oxygen+mapp.
Hi. If you're not noticing any issues and there are no vacuum leaks, I wouldn't worry about the reading being below what the Haynes manual says. I didn't see a spec for that value off hand in the factory service manual. Here's an article from EndWrench about Subaru MAF's: http://endwrench.com/images/pdfs/EWMAFAug05.pdf Another possibility is if you can locate another MAF somehow, junkyard, etc., and compare to see what it reads, or maybe hook up your reader to another similar Subaru and see what it is reading. Those plastic contraptions (someone has called them donkywongles in a recent thread about it) on the intake are to tune the intake to reduce intake noise and possibly induce Helmholtz resonance.
oil leak
porcupine73 replied to Bserk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The fix could hold. JB weld type stuff works great in cool static applications. It can work in warm/hot situations with vibration if the load on it isn't too strong. It sounds like you prepped the area well. You might go over the epoxy with some copper rtv or ultragrey or something like that as an added layer of protection. -
Ok sounds like lack of maintenance isn't the issue. The issues I've had so far on '00obw is a fractured front sway bar (has happened on many '00 outbacks) and a torn inner RH cv joint boot and the exhaust donut before the resonator rusted out. It's got 117k miles on it, but I've only had it since 96k miles. I bought it about 2-1/2 years ago. No signs of HG issue yet and they haven't yet been replaced. The trans does take a second to go to drive when it's cold out, that's another not uncommon issue on some '99 and '00s.
Well the HG thing is a known potential issue on these years so that failure is understandable. Not sure about the clearcoat issue though I think I have heard of that a few times. Haven't heard of many steering racks failing so that one is kind of odd. I'm sure you already know the common causes of torque bind.
I think they would still replace it under the recall. IIRC that was a NHTSA recall as it could result in the vehicle dying while driving, something about some brush or wire coming loose at high rpm operation, so they don't have much choice. They might give a little grief about not having the original OEM core to return though.
If you specifically got #2 and #4 misfire codes, which I think would be P0302 and P0304, then maybe try NGK spark plugs with OEM spark plug wires (not plug wires from an auto parts store). Yes, these are probably the emissions/inspection monitors. There are about 7 of these systems. The longest to set seems to be the evap system. It can take a number of trips over a number of miles to get them all to set to 'ready'. When you get or clear a CEL/MIL or disconnect the battery, the monitors all go back to not ready. There's some info on endwrench.com about it. If you have a reasonable scan tool, it will tell you the status of each I/M. Also if the CEL/MIL is presently on you will probably not pass inspection either, at least that's how it is in NY.
Depends what you're looking for. Top of the line would be something like a rebuild from ccrengines Used/non already rebuilt maybe $50 on up. Depends what mileage, condition, etc, you want. If you get it locally from a salvage you pull it yard would probably be cheapest. You can also get them on eBay, car-part.com, etc, but then shipping adds to the cost. For the '96MY you might be able to pick up an entire vehicle or front clip for not too much.
