3
Everything posted by porcupine73
Hi GP33. Any chance they will cover this under warranty? i.e. it would be nice to get an alignment and new tires out of it; not sure if they would do it? I would maybe get the alignment, but not do any adjusting of my own. Camber you can set pretty close to zero yourself with a level, but do it yourself toe you'd have to use the strings method or something like that.
Not sure if this is helpful, but the basic description is below: The EGR system aims at reduction of NOx by lowering the combustion temperature through re- circulation of a part of exhaust gas into cylinders via the intake manifold. This system consists of the EGR valve, EGR solenoid valve, and BPT (Back pressure transducer): The EGR valve is operated by the vacuum via a BPT from the throttle body and controls the exhaust gas flow from the exhaust manifold to the intake manifold. The EGR solenoid valve is controlled by the ECM according to the engine driving condition and opens/closes the vacuum line from the BPT to the EGR valve diaphragm. The BPT controls vacuum in order for the amount of the EGR that corresponds to the engine load to be obtained. EGR VALVE The EGR valve is situated between the exhaust manifold and collector. After opening EGR solenoid valve, EGR valve is opened for receiving throttle port pressure on diaphragm. Then, part of the exhaust gas is recirculated into collector chamber. EGR SOLENOID VALVE The EGR solenoid valve is situated between the BPT and EGR valve. EGR solenoid valve is opened by a signal emitted from the ECM. Therefore, throttle port pressure is transmitted to diaphragm of EGR valve via a BPT. BPT The BPT is installed between the throttle body and the EGR solenoid valve. The BPT, varying the throttle port vacuum that acts on the EGR valve according to the throttle opening angle and exhaust gas pressure, controls the rate of exhaust gas flow to the EGR valve.
If the dealers you are searching are using trademotion (which most do) it may not be listed. I hate the trademotion package. One that does not use trademotion you could check and actually lists the OEM part #'s is subarupartsforyou.com Also renickmotorsports.com has some aftermarket polyurethane bushings available I believe.
Thanks for the help guys. The endwrench articles are very interesting. I think it's fixed now. It was the ground connection. I was following to service manual troubleshooting procedure. It said check some resistances between the connector on the hydraulic unit controller thing there and chassis ground, saying they should be 0.5 ohms or less. I was getting about 7 ohms. I looked for nearby ground connections and there was one at the base of the bracket for the power steering reservoir. I took out the bolt and yep it was the correct ground. The bolt was pretty rusty and the connector dirty, so I cleaned it all up, put in a new bolt, coated the whole deal with kopr-shield. Then the resistance was like 0.2 ohms. I think the bolt hole might be stripped, so maybe this was a problem before. I don't remember messing with this connection in the past but maybe I did as the bolt had the copper stuff on it that I usually use. Then I did the test sequence mode and I could hear all sorts of grring and whirring (no dong dong or gong gong or anything like that - maybe it's the translation from Japanese). I cleared the codes and went for a test drive and the light stayed off.
Ok, thanks nipper. I'll remove the connector and see if it's corroded or anything and check some things the procedure says like power and ground but if that's all good I'll see what parts I can find used. I saw this section about noting any sounds the unit is making. I'm not hearing any sounds yet, so I'll check the 'does not produce' box for now. I can live with a buzz or maybe a knock but if I hear the gong gong buzz I'm going to be upset.
Any common causes of ABS code 52 for 2000 Outback? I noticed the ABS light came on this morning. Just went out at lunch and read code 52. The manual says "DTC 52 - Abnormal Motor and/or Motor Relay" Faulty motor, Faulty motor relay, and/or Faulty harness connector I tried wiggling the connector and tapping the motor a little bit and then reset the codes to see if it comes back. I see it also says "Trouble Symptom - ABS does not operate." Actually maybe that is better. I heard others say the system is fairly sensitive. Last week I was making a fairly sharp right turn while braking and hit a medium sized pothole. The ABS kicked and phew that was not good. I was not expecting it and it reduced my slowing down for a second at a critical moment.
There's a lot of games that are played on eBay. One I see on most car listings is the lowering of the reserve price at the last moment eBay will allow it. Like maybe the reserve is $5000 and someone bids $4000, maybe they will bid higher trying to meet the reserve, but if not the seller could lower the reserve later to make that person high bidder. Also a lot of the listings in the fine print show some 'dealer documentation fee' which can be $100's.
Hi. That should be a solid Subaru you have picked up. That model year with 2.2L is pretty solid. Yes replace the water pump and gasket if they're original and might was well put in a new thermostat and gasket too. The idlers should at least be checked, esp the geared toothed one near the water pump. Definitely reseal the oil pump and replace front crank seal. Make sure the screws are not backing out of the rear case cover. There is a o-ring type item between the oil pump discharge and the block as well. Yes good to pass that one up. That's the front wheel drive indicator. Sometimes when people are trying to sell a Subaru that has some torque binding issues they install the FWD fuse.
Subaru has determined the rounded cogs generate less heat. Subaru timing belts are pretty reliable; don't hear of many breaking or having issues before their time. There have been failed tensioners and idler pulleys and the crank pulley bolt backing out, but these are typically because either the idlers should have been checked when timing belt was replaced or crank pulley bolt was not retorqued correctly.
You could also put a switch on the lead to the starter solenoid, or just pull off the wire; it comes off pretty easily. That would prevent cranking. The fuel pump ground could work as another switch. Then even if the cranking is re-enabled it won't start or won't run very long. You can access the connector under the access panel beneath the carpeting behind the right rear seat. Another could be the put a switch in terminal 3 on the ignitor. This would remove the ground path for coil so the spark plugs could not fire. Another could be to unhook the cam position sensor. Also if there is a tree or light pole or something near by, you could chain the vehicle to that object to help prevent towing.
ABS Light
porcupine73 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
It can also mean your alternator is getting ready to give up the magic smoke. -
The bolt is tight but it will come loose. When you reinstall the bolt you need to use the proper torque also as it is not pretty when the crank pulley bolt loosens up later. The timing belt uses an automatic tensioner, so if the belt is 'loose' the tensioner may be weak or damaged. When you put it in gear, put it in 5th gear so as to give your wrenching on the crank the least torque at the wheels. That should hold it still. When I broke loose the crank pulley bolt on '00obw I estimate it took a good 400 ft lb to break it loose.
Ok...where to start. The fuse is the FWD fuse for the automatic transmissions. Installing the fuse puts it in FWD mode. Normally the FWD fuse is not installed. MT's may have an FWD fuse position but it doesn't do anything. The main point is that all tires must match within 1/4" circumference, as measured with a narrow tape measure. The blowing of the transfer case is actually the development of torque bind. When running the donut spare, for AT's the FWD fuse should be installed.
