3
Everything posted by porcupine73
The part #'s are different, unless the '91 happens to be a turbo. I think the # of splines will be different. SOA925H500R1 AXLE ASSMBLY LEFT or RIGHT FRONT REMAN from SUBARU FOR 1990-1994 LEGACY (ALL FWD MODELS non-turbo) SOA966H900R1 AXLE ASSEMBLY LEFT or RIGHT FRONT ASSEMBLY REMAN from SUBARU FOR 1990-1994 LEGACY TURBO ONLY SOA966H900R1 AXLE ASSEMBLY LEFT or RIGHT FRONT ASSEMBLY REMAN from SUBARU FOR 1995-1999 LEGACY ALL (for cars with ABS)
Hi. Typically reduce by 1/3 for antisieze or threadlock is what I hear. Esp for smaller fasteners going into aluminum which kind strip somewhat easily. Note that you must know what the torque spec is for. Typically unless it's stated otherwise, the torque is for clean dry threads as you stated. However some fasteners such as the crank pulley bolt are for oiled threads. So in that case I would not reduce the torque. It is not uncommon to hear of that bolt especially coming loose later. On the oil pump screws you could even go red threadlock. I mean the only reason you would ever remove those screws later would be to check the rotor clearances or to replace the rotor pair; in those cases people usally just replace the whole pump. When I tried to get the screws out of my oil pump's rear case, a few were already loose, a couple were tight but I could get them out, and one I stripped (whoops) and those are weird screws you won't find at the hardware store. I used green thread lock (the wicking kind) on the new pump screws; it soaks down in there so you don't have to remove the fastener to apply it.
I think those might be GT wheels. Maybe someone can decode the VIN positions to determine the package. Cars101.com will show you the various packages available for the '94. Carfax will also list the trim package, but I'm not sure how accurate it is. For my '94s VIN it says it's an alpine but I see no evidence it actually is. Here is my '94 Legacy L wagon with option group 2:
If the ATF was changed periodically it would be a great benefit. If it still has the original ATF that is not ideal. Make sure on a cool morning start after firing up the engine it shifts into drive in a second or two. Some of the '99 and '00 phase II 4eats developed some slow to engage to drive issue. Of course torque bind checking wouuld be a good idea. Phase II 2.5L also could have the external HG peeping leak.
AFIAK '96 2.2L is non-interference. All 2.5L's are interference. I think the AT is the same basic design but various parts had been upgraded to hardened versions etc over the years. If you search for 4eat in the archives on endwrench.com there are lots of detailed articles. The starters for MT and AT have different part #'s I believe. They might be different speeds/torque outputs/drive gears?
my.subaru.com is a handy site. It will show you all dealer service history. It won't show you work done at non-dealer facilities, unless the owner entered the info into the system. It wil show you any open recalls and any recall work already performed. If you just bought the vehicle, be prepared to fax Subaru a copy of the transferred title or registration or some proof that you now own the vehicle as they will probably tell you they couldn't verify your ownership.
brake sliders
porcupine73 replied to rox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Ok, maybe brake cleaner isn't the best for the rubber parts. I cleaned some of those rubber boots out with chlorinated brake cleaner and a nylon brush before and it didn't seem to do any damage to them, but I ended up using new ones from a reseal kit anyway. The label does say to protect all rubber parts from the overspray. Any grease for the rubber should not be petroleum based as it could make them swell. -
If it's an auto, when the vehicle is cold sitting overnight, start it up and put it right into drive and make sure it engages within a say 2 seconds. Some AT's from this year and '00 had some slow to engage into drive issue. Also check for torque bind. Definitely check the overflow tank for oily milky nasty residue (though if the coolant was just changed to cover it up you won't know). Can check for those little nibs on the HG's to see if maybe they were already replaced with the new MLS style. Of course if the timing belt hasn't been done it's overdue. It can be tough to tell by looking at the belt how old it is. If everything checks out, the price doesn't seem too bad.
brake sliders
Yes you can lubricate those sliders. You just need to get the pins out of there, then clean out the rubber boots and everything with brake cleaner (or use new rubber boots from a reseal kit). The Subaru specified grease is the red niglube that comes with the caliper reseal kits. Other greases often used include syl-glyde, permatex makes a couple varieties, a hi-temp silicone based formula and some other one, Neo HP800 (my favorite). -
20-22mpg seems low but there are so many variables involved it could be driving style etc; there could be a number of reasons for poor economy. If it's outside your spending limit, you could look around for other Subaru's then, like craigslist etc. An earlier 90's 2.2L Legacy could be easily had for that much and they are very reliable too. Just make sure it's AWD if you want AWD. Or if you get an FWD or maybe an earlier 1.8L Impreza FWD those are pretty economical. But you live in a snow area so maybe you want AWD, but on other vehicles such as the T*yot@ you wouldn't have AWD anyway...
Where is it hitting? You may have to get on your knees and watch the hood close to try to see where the contact points are. I put one on '00obw; it was a little tricky because the directions were pictures only with weird arrows and stuff that were kind of ambigious...I didn't remove the nuts it showed for the grill because they were siezed.
Definitely check the coolant overflow tank for any oily milkyness. That would have been the 2.5L dohc phase I which could get the blow exhaust into coolant issue. It's possible the HG's were already replaced, hopefully with the new MLS type. And any AWD Subaru you want to check for torque bind before buying.
Not trying to scare you off, just mention some of the more common problems seen so you can check before you buy, not necessarily that you will experience them. Many other makes wouldn't even make it to 150k much less still be reliable. The Subaru's are pretty easy to work on, esp since the engine isn't transverse mounted. One the 2.5L dohc the spark plugs can be a little bit of challenge but all the accessories ps pump, etc are all right there on top of the engine. For a daily driver if you live where there's snow you'll love the Subaru.
