Everything posted by porcupine73
New to me 1993 Legacy LS station wagon!
porcupine73 replied to starkiller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow that's sharp and clean. The tints look really good on there.
AC question....
porcupine73 replied to badjer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSomeone posted a similar issue a couple months ago and a a/c recharge fixed it. Not sure if the reason it worked ok when moving was higher rpm of compressor made it able to function. But yes, if the fans aren't working, or the condenser is jammed with leaves and stuff, or there is a bunch of leaves or rats nest between the condenser and radiator, etc., it would reduce airflow.
This group rules!!!
porcupine73 replied to axgutt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe recall was for alternator part # 23700AA211F Lot range of 62P to 84W Campaign - Alternator Inspection/Replacement NUMBER: WXX-81 DATE: 10/15/00 APPLICABILITY: 1996MY-1998MY Subaru Legacy SUBJECT: Alternator Subaru of America, Inc. (SOA) has determined that some 1996 through 1998 Subaru Legacy vehicles may experience a loss of alternator charging due to a broken brush wire. On vehicles with higher mileage, an alternator brush wire may become fatigued and eventually break as a result of engine operation at high RPMs. If an alternator brush wire does break, the Charge Warning Light will illuminate steadily while the engine is running thereby providing ample time for the driver to seek repair service (depending on the battery condition, approximately one hour of vehicle operation). However, if the warning is ignored and the vehicle continues to operate under this condition, the battery will eventually lose electrical power and the engine will stop running. The program will involve the inspection of affected vehicles for possible alternator replacement.
Advise...should I finish rear drum to disc swap '96 Legacy brighton?
Hi, just wondering if you guys think I should follow through and finish the rear drum to disc swap on '96 legacy brighton wagon. This will be my DD this winter. Just standard commuting use. I guess I've found the single pot fronts and rear drums to be adequate, but I already bought and painted dual pot front caliper and rear calipers from a '96 Outback I think it was. But I would still need to buy the rest of the parts, backing plates, parking brake kit, springs&cups, rotors, etc. Plus would have to get at least 15" wheels&tires to clear the rotors I assume. However funds are a little tight right now. It needs the front brakes done something fierce. I already have new OEM front rotors, caliper reseal kit, and OEM front pad kit in my supplies for this vehicle that I could just put on rather than using the dual pots I bought... What ya'll think I should do? Thanks zzz
`94 Legacy
porcupine73 replied to romcat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso the shifter bushings tend to wear out over time thus resulting in more difficult shifting.
Quick axle question
porcupine73 replied to madkow007's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow long has the ripped side been ripped? If it's been a while, then I'd replace the torn one thinking it would be the more likely one to be clicking. Sounds of course are weird in cars so it can sound like it's coming from the driver's side but be coming from somewhere else. Maybe you can get a passenger to hang head out the window and listen for the clicking on the pass side to see if you can narrow it down further.
Different Tires and AWD
porcupine73 replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAll tires MUST be within 1/4 inch circumference as measured with a narrow blade tape measure or you are asking for problems. If you have an auto and must run tires outside this spec then install the FWD fuse.
charcoal canister
porcupine73 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEarlier vehicles it was at the front right of the vehicle, near where the ABS hydraulic unit is/would be. Later enhanced evap vehicles it is underneath the vehicle sort of near the fuel filler line.
This look like a 1994 GT wagon 2 U?
porcupine73 replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice GT wagon! Sure rub it in! :-p
99 Legacy 30th anniversary lumberjack edition
porcupine73 replied to fishy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWere you singing it while doing your lumberjacking duties with the Suby? Most people probably know the lumberjack song, but if you don't I notice the video is available on youtube: http://www.youtube.com/watch?v=K7fXBhmL9e0
A/C belt on the 2008 Impreza
porcupine73 replied to zstalker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat is the replacement interval for that belt? I think it's 105k miles, so if the timing belt interval is still 105k miles too then maybe they figure those items will be done at the same time. There must be other automakers that have gone to this style too? Though most vehicles now use the serpentine style like the H6 probably?
Dealer aproved lift kit?
porcupine73 replied to subaruplatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX06-07 is pretty new, but the basic 'lift' used to be to use Outback (for Legacy, not sure about Impreza) or Forester (for Impreza?) struts and springs, or those struts with King Spring (renick calls them Scorpion) springs.
porcupine73 replied to subaruplatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot that I've ever heard of.
abs light question
porcupine73 replied to timintc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVery very good chance your alternator is dying. The ABS light and some other indicator lights get their ground through the alternator field circuit, so if the alternator is going flaky these lights may come on or flicker. This is definitely something to check out right away or otherwise prepare for to avoid being stranded.
Noticeable Engine Surge When Turning on Accessories
porcupine73 replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood question. Nipper has a thread going on for this right now. I have noticed output as low as 12.8V sitting at idle (engine at operating temp) and no accessories on. These cars ('00OBWs) have DRL too so that probably doesn't help.
radiator
porcupine73 replied to Aja1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat year and model Subaru? Is it that style where the top hose enters the radiator at the center of the top? I hear those are more prone to clogging possibly due to flow stagnation in certain areas. Did you run gm dexcool or other OAT antifreeze in there? That stuff will glop up if the system is getting air into it all from any leaks or a bad radiator cap.
porcupine73 replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat year and model Subaru is this? I notice on '00obw at idle it bumps up the idle about .5 seconds before engaging the a/c compressor. I don't notice the engagement much when it cycles while driving. I can feel it cycling on the '96 though. I don't notice it at all on the '94 but that's because the a/c doesn't work on the '94. I wouldn't worry about it too much before going on a trip. I mean if the a/c clunks out or whatever, just remove or cut the belt to the a/c compressor and you're good to go.
porcupine73 replied to fishy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell there are all those Subaru editions, the alpine, sunsport, etc., so you have the lumberjack. I'm a lumberjack and I'm OK, I sleep all night and I work all day.
porcupine73 replied to fishy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSUBARU to the rescue! Cool story. Hey...are any of those logs worth anything? I saw a few shows on TLC or Discovery where they were harvesting these logs and getting up to $40,000 per log harvesting them from the bottom of some lake or river or something by making the rare original growth hardwoods into veneers. I think they found some that was used to make Stradivarius violins?
Legacy alternator in an Impreza?
porcupine73 replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUh oh better strike now! The demand is going up as a result of this thread! And copper cost.
Forgive me if this has been asked... location of TCM? - Now with photos!
porcupine73 replied to classact2575's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell the closest diagram I have is for a '94 Legacy....maybe it's useful?
porcupine73 replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat particular reman alternator is probably so much less expensive because of the WXX-81 campaign for some 1996 through 1998 Subaru Legacy vehicles that may experience a loss of alternator charging due to a broken brush wire. That involved a lot of alternators so the price is less due to the quantity involved.
question about sealants in EJ25 heads
porcupine73 replied to chuckj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI didn't see Threebond 1280B listed in that link though. I did note this in EndWrench previously: Three Bond Sealer 1280B - Subaru of America has located a source this sealer in the U.S. The sealer should be ordered from your Subaru parts department under part number SOA5499100. One tube can be used for approximately seven engines. If you are working on an H-6 that requires this sealer, be sure to use Three Bond 1280B and not Three Bond 1215. A google search for Threebond 1280B does yield some hits, mostly for the threebond website, but there is reference to it as 'GM liquid gasket sealer' as well. One of the Subaru sites I've seen Threebond products listed is here: http://www.subaruparts.com/cart/?pn=SOA5499100 They must not have that page spidered by google because a google search for SOA5499100 yields no hits.
Replacing belts in 02 Outback
porcupine73 replied to ferdy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI forget what the OEM belts say on them...I don't think they say Subaru. The NAPA belts are probably fine. But of course you can't go wrong with OEM. (OEM parts can be had from Subaru dealers who sells parts on the Internet typically for much less than what a local dealer charges). Do you have the H4 or the H6? The H4 is pretty simple. You need some 10mm, 12mm, and 14mm sockets/wrenches. Tightness can be tricky on new belts as they will loosen slightly as the break in. But you don't want them too tight either as that can damage the accessories. There's some good articles on EndWrench.com about belts but the site seems to be down at the moment so I can't get the links.
suspension difference between Legacy & Legacy Outback??
porcupine73 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes the struts and springs are different. Also I have noted in the service diagrams the Outback appears to have some sort of spacer or something between the suspension crossmember and the body. cars101.com is your friend for all Subaru specs and info, especially newer models that don't have much history yet.
