Everything posted by porcupine73
Lift Kit - progress report
porcupine73 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice...I'll bet Blu is happy to be back home. Sounds like there are a few items left to 'tweak'. I really like the side view pic that shows off the lift. Blu does look meaner!
Does Subaru offer manufacturing tours??
porcupine73 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes no doubt it would make a great trip. Make sure you wear a Subaru t-shirt or something. Or how about a usmb t-shirt! Sweet. I've been thinking about taking some vacation time to drive down for that tour since it does sound nice.
porcupine73 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSchweet! Looking forward to the photos. Did you get the eBay intake? I take it the shifter cable is fixed.
How much oil to use with a used A/C compressor?
porcupine73 replied to RodA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHello RodA and welcome! From the factory service manual: If the compressor is replaced (after stabilization): Drain and measure the oil from the original compressor. Drain the oil from the replacement compressor and refill with the same amount that was drained from the original [20 ml (0.7 US fl oz, 0.7 Imp fl oz) minimum]. Always use ZXL100PG for the replacement oil. (You might want to verify your system's specified oil; I can look it up for you if needed).
2008 Legacy Integrated Key's
porcupine73 replied to beautofawd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes there's lots of good content on cars101.com The site comes up #6 in a google search for 'Subaru' and has a good PageRank, so must be doing something right!
Help me find a wiper stalk on Ebay- don't know whatelse to call it
porcupine73 replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMan I wish I had some of these wiper stalks to sell!
porcupine73 replied to beautofawd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure if they would work or not. Joe has a ton of Subaru key info at http://www.cars101.com/subaru/keyless.html Does have pics of the '08 and earlier keys and remotes, doesn't specifically say if '08 key will work on '07.
porcupine73 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.subaru-sia.com/community/tour_inter.htm Subaru of Indiana Automotive, Inc. Conducts public tours, at no cost, on Monday, Tuesday, Wednesday, and Friday at 9:30 a.m. Click HERE to receive a tour request form. This form must be faxed to 765.772.7178 within 24hrs of your requested tour date. You can also email HERE and request a tour. You can expect to walk 1 mile on our elevated catwalk tour. A guide will lead you through the plant where you will see production of body panels in Stamping, welding of the vehicles in Body Assembly, finished paint in our Paint section, final assembly in Trim & Final, and testing in our Tester Line. You are encouraged to wear closed-toe shoes and be ready to negotiate the catwalk to include 90 up-and-down steps while walking through the plant. We can accommodate up to 7 persons at a time that may experience difficulty with the walk by using a golf cart.
Is XT6.net ever coming back? (eom)
porcupine73 replied to bulwnkl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat happened to it? According to http://whois.domaintools.com/xt6.net the registration hasn't changed or anything. But now it has one of those stupid ad landing pages. domaintools has a snapshot from June. It shows it's registered to some guy in Gainesville FL.
porcupine73 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes they do. If you go to the Subaru Indiana Web site, there is a link to the tours somewhere in there. It has the days and times they run tours. You have to apply in advance I believe, at least 24 hrs (like you can't just show up). I think that's for security. If you just google Subaru Indiana you will find the site.
Torque Wrench Recommendation Anyone?
porcupine73 replied to stevetone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI forgot to read what you planned to do with the torque wrenches. For the job you mentioned (timing belt, water pump, etc), ideally you need all three ranges, or at the minimum the 0-150 ft*lb and a low range such as 0-250 in*lb (0-20.8 ft*lb). Crank pulley bolt you will need the 0-150 ft*lb Idler pulley bolts and crank sprocket bolts you could probably use the 0-150, but 0-75 ft*lb would be better. For the water pump and oil pump, you need a low range, such as the 0-250 in*lb, you do not want to strip out those bolts. edit: also you could check out other torque wrench styles such as beam and strain gauge. Harbor Freight has cheap torque wrenches esp when they're on sale. Also note of course that the torque specs are typically for clean dry threads, unless otherwise noted (such as for the crank pulley bolt). So if you put antisieze or loctite on the threads the torque typically should be reduced.
porcupine73 replied to stevetone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes I bought three of those Craftsman click style wrenches, one of each range they had, about a year ago. They seem to work OK so far. Clickers can go out of calibration and are supposed to be calibrated periodically. The biggest thing you can do is when you're done using it, turn the torque setting back down to very low. Don't leave it sitting dialed in at some torque. And right on, you want to use a torque wrench where the target torque falls between say 20% to 80% of the range. I try to go 40% to 80% of the range. So forget about trying to torque valve cover bolts or even spark plugs with a 150 ft*lb unit. I also have the beam types from Craftsman and those work pretty well. It is harder to read the scale when doing higher torques, so they may be accurate but it depends how well you can read it while applying torque.
Drive Cycle and CEL
porcupine73 replied to nickb21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is different for each code. Some codes illuminate the CEL/MIL immediately at fault recognition. Some require two or three or more consecutive trips to make throw a code. Until then it is a 'pending code' which will not illuminate the CEL/MIL. Right and then if it doesn't see the problem for a certain number of trips or however that code is setup then the CEL/MIL may go out by itself. Some codes get stored in history, so even if the CEL/MIL isn't on now, it may be possible to get it with a code reader by going to 'code history'.
0743 OBD2 code...what to check for?
porcupine73 replied to biglittledog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru description is DTC P0743 - TORQUE CONVERTER CLUTCH SYSTEM (LOCK-UP DUTY SOLENOID) ELECTRICAL DTC DETECTING CONDITION: Two consecutive driving cycles with fault TROUBLE SYMPTOM: No lock-up (after engine warm-up) NOTE: Check lock-up duty solenoid circuit. Maybe you can reseat the connectors if everything else looks good. Could just be the solenoid is bad though. No lockup means your fuel economy will suffer and the ATF may run a little hotter than normal.
Checked knock sensor;now starts but won't run
porcupine73 replied to brighton98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRight on, any of those 316 hoses on the intake tubing like to come off. If you had the throttle open when spraying that cleaner in there, it might take some running for it to clear it out. If it is just the cleaner in the intake, running for a while at 1/4 throttle will help clear it out. Usually they sputter and stall if you just try to let them idle after spraying cleaner in the intake.
Electronic Key
porcupine73 replied to guidance1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm...are the contacts for the battery clean and tight? There is an article on endwrench.com about that. I just replaced battery in remote for 00obw and it seemed like I had to press lock and unlock at the same time before it would work again. haha yes actually I am from evans, just south of derby. I have eaten at hoaks before but not recently. Actually I work in Tonawanda.
Electronic Key
porcupine73 replied to guidance1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you sure this vehicle is equipped with the remote keyless entry? It wasn't standard on all models and sometimes it was incorporated with the security system package.
Piston slap
porcupine73 replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor the '96, it might just be the TCU applying the clutches and such to do the shift. It doesn't just slam the solenoids from off to on, it goes from 0% to 100% duty cycle at 50Hz and this can cause a brief audible buzz. For the '99, Engine Noise When ColdThe Subaru Technical Support Line has received several reports from the field of an engine noise that could be mistaken for an internal engine noise on 1999-2000 Impreza, Legacy and Forester models equipped with 2.2 and 2.5 liter engines. The noise sounds like it is coming from the front of the engine and could be mistaken for failed bearings. This noise is heard after a cold start and will gradually go away as the engine warms up. It may therefore be difficult to reproduce the noise unless the vehicle is left overnight. It has been found that the timing belt tensioner on these vehicles may be weak, allowing the timing belt to move and hit the inside of the timing belt cover. The tensioner bearing itself could also be at fault. It is essential that you listen to the actual noise before reaching a diagnosis. If you suspect the belt tensioner, remove the front cover and look for evidence of rubbing or chaffing. As the vast majority of these vehicles will still be covered by the manufacturer’s powertrain warranty, any vehicle exhibiting these symptoms should be returned to an authorized Subaru dealer for service.
No crank sometimes '00obw AT - neutral safety switch?
porcupine73 replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK thanks I'll have to take a looksee and figure this out eventually or wait for it to get worse.
Electronic Key
porcupine73 replied to guidance1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWas this working before you changed the battery in the remote?
Cylinder Numbering on 2.2L?
porcupine73 replied to 95LEGOBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks good. Also if you look on the top of the coil pack where the spark plug wires connect, it has the cylinders numbered there as a handy reminder.
Uncracked knock sensor=OK??
porcupine73 replied to brighton98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust because the knock sensor is not cracked does not mean it is functioning properly. You only get the knock sensor CEL code if the ECU detects a problem with the circuit. You will not get a CEL if the knock sensor is simply overly sensitive. If the ECU thinks it is seeing knock, it will retard the timing until it thinks it stops seeing knock. Also the mating point of the sensor to the block must be clean and free of corrosion and the mounting bolt torque must be correct.
Electronic Key
porcupine73 replied to guidance1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck your owner's manual, or check out cars101.com
porcupine73 replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI haven't done anything about it yet. It only does it once every few weeks. I'm not yet sure if it's the starter contacts or the neutral/park switch. The last time it did it, I just kept bumping the key to run about 8 times and then it cranked. Next time it does it, I plan to be ready at the shifter to try moving it a little or getting it into neutral to see if that makes it crank immediately. I have noticed and don't know if it's related that once in a while every few weeks, I can't get it out of park. That solenoid jobby does not pull in for some reason. I have to mess around with the shifter a little to get it going. At that time it is not even energizing the solenoid. I know because I have the trim around the shift console off right now and I can push the solenoid manually to get it out of park but it has no pulling force at all. Most of the time the solenoid clicks just fine.
Replacement O2 Sensor, 1993 Impreza
Ok, well I wouldn't worry about it too much, what part # did you get? Should be 22690AA190
