Everything posted by porcupine73
hello first time user need help 98 outback legacy
porcupine73 replied to kc reale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHm...question, on a H4 Subaru are the pairs of spark plugs connected in series or in parallel? if you unplug one of the plug wires, does the opposite cylinder stop firing as well? Like if you unplug #3 wire, does #4 plug not fire? Also welcome surfsubbe, do you have a Subaru?
porcupine73 replied to kc reale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi kc reale and welcome! If the problem is not the plugs, wires, or coil pack, the next step up in the system is the ignitor (which drives the coil pack), and next step up the system after that is the ECU output driving the ignitor. Cylinders 1 and 2 spark at the same time, and cylinders 3 and 4 spark at the same time. Could be a poor connection somewhere along that line.
I cleaned engine, now missing (2.2L Legacy)
porcupine73 replied to 95LEGOBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you want to try the wd40, coat the plug wires themselves from end to end, like wipe it on with a cloth, and saturate the coil pack with it. I don't know if whatever is in wd40 has enough dielectric strength to stop the arcing. Silicone spray works good, but you don't want that getting into your intake as it can damage the oxygen sensor.
porcupine73 replied to 95LEGOBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe washing probably didn't cause the damage. But it may have washed off dirt and grease which may have been acting as an insulator and/or sometimes when things are borderline working the slightest disturbance will make them start acting up.
porcupine73 replied to 95LEGOBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably needs new OEM plug wires. Coil pack might also have cracks or carbon traces. One test can be with it idling, mist down the coil pack and plug wires with a spray bottle in a dimly lit area and look for any arcing. Also if you can read the codes that might be helpful. Based on your description it is probably the P0301-03 series of cylinder misfire codes.
Air Intake
porcupine73 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think those dead spaces may be to silence intake noise and/or tune the intake somewhat for Helmholtz resonance. The stock intake tubing does reduce intake noise it would seem. When I routed that flex hose into the fender, sheesh the thing sounded like it had one of those ricer mufflers on it. Routed into that plastic intake scoop thing is better but still noisier than the stock intake tubing.
ECU says I need a camshaft sensor
porcupine73 replied to salewit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTypically the more expensive cats have more catalyst in them, platinum or palladium or whatever it is, hence the higher cost and hopefully longer life.
Outstanding Brake Pads!
porcupine73 replied to Bluestone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow's their initial grip when getting on the pedal cold?
Air Intake
porcupine73 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi nipper, did you figure out what to do for the intake yet? I found the pics of the tubing stuff I used from mcmaster.com. Not sure if this is useful or not but here it is:
Fuel System Problem, or...?
porcupine73 replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi. Yes the first step is to get the code(s) read. Every ODBII scanner I've seen shows the Pnnn code and many show the generic ODBII description. The code number is what you want, but if for some reason it only gives the description that may be sufficient. It is possible to make guesses as to what the issue is, but knowing the code(s) would be much more efficient.
96 Legacy
porcupine73 replied to guidance1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's a number of kits available to help with this issue. Generally they include something to sand or buff out the haziness, then some sort of sealer that is supposed to prevent the haziness from returning. I haven't used any such kit yet so I'm not sure which ones are good.
What are these donkywongles?
porcupine73 replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSome manufacturers use such donkeywongles to tune the intake for Helmholtz resonance. So as mentioned it may help low end performance at the expense of a little high end power.
impreza caliper change from 01 to 02
porcupine73 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCouldn't find a whole lot either. From the part #'s it looks like 02-06 shared the same calipers for all non-turbo/non-wrx impezas, whereas previously the RS had it's own different number. cars101.com: 2002: Front: 10.7" vented twin-caliper piston. Rear: 10.3" solid disc 4 channel, 4 sensor ABS (anti-lock) 2001: Front: 10.7" vented disc with dual caliper pistons, Rear:10.5" solid disc 4 channel ABS
Foglight button dash light: tried to replace now none work!
porcupine73 replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHm...perhaps a bulb in the dash is worth two in the blister package.
porcupine73 replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFirst thing I would check, if possible, is the voltage at the terminals where the bulb connects when it is supposed to be illuminated.
Where to buy headgaskets?
porcupine73 replied to legacyak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet the HG's from a Subaru dealer who sells parts online; there are many such dealers. Though I see your location says international so that may be more difficult. Get the new multilayer steel type, not 'new old stock'.
99 OBS Brake Question
Hm, well according to cars101.com info, it came with: 15" Alloy 205/60R 15 Front: 10.1" vented, rear:9.0" drum 4 channel ABS (same as other '99 Imprezas except for the ABS). The only '99 Impreza with anything larger is the RS, which came with 16" Alloy, 205 / 55R 16 89HFront: 10.7" vented disc with dual caliper pistons, rear:10.5" solid disc 4 channel ABS
seatbelt swap...
People who do this I believe use the seatbelts from a similar Canadian spec model.
DIY flush?
porcupine73 replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSome people only consider a tranny flush when they start experiencing problems with the AT. Sometimes mechanical damage has already set in and then a flush either makes the problem worse or seems to make the problem worse when the unit was already doomed anyway. Another diy tranny flush method involves pulling one of the lines off the radiator in-tank ATF cooler and then doing the pump and dump method. For radiator/cooling system flushing, there are articles on EndWrench about having it done. If a machine is used, the unit cannot have been used on other vehicle makes that have copper or brass components in the cooling system. I made a homemade flusher last year with a dirty water pump from Harbor Freight, some PVC fittings, and some hose; it seemed to work ok. Chemical flushes are not recommended. Ones like the prestone will leave a soapy residue in the system for many coolant changes to come.
timing belt
porcupine73 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell that is good news indeed! Otherwise the job gets expensive fast.
timing belt
porcupine73 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe mechanic might be thinking there is no risk of the intake and exhaust valves colliding on the sohc, which is true, but on Subaru 2.5L's and any interference type 2.2L's (97/98+?) there is risk of valve to piston collision.
Looking for an opinion.
porcupine73 replied to JayDM56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi. Check for the usual. Torque bind, tires matching, etc. Might be near time for a timing belt. With that kind of 'body mileage' check everything, wheel bearings, cv joint boots, hoses, etc. Make sure it really is an AWD vehicle, not an FWD. Anything you find just makes a good case for getting the price down. Not sure if the price is good; I'm not good with prices.
Replacement Battery Suggestions
porcupine73 replied to howards11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSize 34 will fit into Subaru, at least they do in my 2000 Outback. Pics are in post #3. However, the + terminal needs to be extended by a few inches to reach. Some size 34 batteries might be available with reversed terminals, then no extension would be needed.
porcupine73 replied to howards11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere's the Odyssey web site in case there's any interest http://www.odysseybatteries.com/ Says they use "Absorbent glass mat (AGM) technology", not sure what that means. The largest odyssey that will fit the Subaru is the PC1500T (with extending + cable a few inches). It's a group 34. SummitRacing has the PC1500DT, it has both side and top posts. Don't need the side posts for Subaru of course.
Code PO440 Help needed
porcupine73 replied to pulloff's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can find the NYS inspection requirements on the NYS DMV web site, just do a google search. Then go to the nys inspection program for dealers and it lists the requirements in detail. I print this out and check everything myself before going in that way I know its good to go. Bulbs are an easy thing for a shop to find and make a few bucks on replacing. After you reset the cel, you will need to make enough trips to get all the readiness monitors set. Oh actually I think that might include the test where you can't have more than 9.6 gallons gas so maybe thatt won't work. You really need an odbii code reader so you can tell if all the readiness monitors are set otherwise you will notbpass NYS inspection.
