Everything posted by porcupine73
Engine pull questions
porcupine73 replied to Sirlono's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi. If you scroll down some on this guy's web page to the head gasket project, he has a number of pictures and description about R&R'ing the engine. This guy appears to like Subaru's, is he a member on here? http://www.staff.uaf.edu/fnjwt/subaru.html
Forester 2001 not starting, sometimes, please help
porcupine73 replied to rude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes it does make sense that the fans would come on as that is the failsafe. I'm just glad I didn't have my hand or any tools down in there or anything at the time. This was with just putting the key to run, not start or with engine running.
porcupine73 replied to rude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso just a comment about the engine coolant temp sensor, to be a little cautious if you put the key to run with that sensor unhooked. When I did that, both the main and sub radiator fans came on, which I was not expecting.
adding to Subaru family-which one?
porcupine73 replied to wnysubob99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK cool Batavia yes that's not far. You could also check out http://www.psrautosales.com They're in Akron, sort of near Darien Lake 6 flags. I bought my '00obw from Pete there a couple years ago. Seems like a good place and Pete was really friendly. They always have maybe a dozen Subaru's in stock.
porcupine73 replied to rude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you mean it would crank, but not start? Or would it not even crank?
porcupine73 replied to wnysubob99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi wnysubob99 and welcome! Yes..which one! Both have the opportunity to be great cars. If you're not already familiar with some of the particulars of Subaru's, might want to check out torque bind and head gaskets, just so you know a few things to check out when looking at those vehicles. edit: oh I see one of them sold already. Another source for leads would be buffalo.craigslist.org Also autotrader.com has some listings. Yes another western new yorker....excellent...soon they will allll be assimilated.
Inner CV boot
porcupine73 replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYah that should be alright. I drove for a couple weeks on mine when it ripped. You probably won't want to just replace the boot on yours if you do drive it in the rain and stuff. MWE axles remanufactured are pretty well respected on the boards. http://www.ccrengines.com/mwe/index.html Yes you can get remans less expensive at autozone, napa, etc., some people use those types fine; others have issues. Some people are having good results with GCK is it all new axles from the autoparts store.
What is this?
porcupine73 replied to Hondasucks's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh good call. Wait..this isn't another WRX with an automatic transmission is it....
96 Outback 2.2 no compression
porcupine73 replied to davcoz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds good and way to help a fellow out! Say...you need any help with that 2008?
Carfax Needed
porcupine73 replied to Suzam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes the 5EAT's are available in newer Subaru's. Those are the ones that require the special Subaru/Idemitsu HP ATF. They might be made by http://www.jatco.co.jp but not really sure.
Struts or Steering Rack?
porcupine73 replied to RallyKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you bounce the front end by hand/foot does it bounce more than once or twice? Maybe the suspension needs a good shakedown for loose/worn components. Also, some the Legacies from ~96 had a recall for poor quality steel in the springs, so make sure those aren't broken either.
A/C Evap Thermoswitch questions
porcupine73 replied to danbennett2u's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpg 2 of this article shows a diagram for an impreza Evaporator Icing Countermeasure
What is this?
porcupine73 replied to Hondasucks's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXConnector for speaker maybe?
Black comedy of errors:ECU/sensor problem
porcupine73 replied to DTL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got trans cooler hose by the foot before from autozone. They have it in like 25' boxes and will sell you the length you want. Pretty sure Parts America will do the same thing. I lost track of what year your vehicle is, but if it is ~90-92 then it is probably the filter that was added under the TSB. Does it look roughly like a fuel filter? There were a few different kinds. Also some H6's have the ATF filter in this area too.
Spark Plug ?
porcupine73 replied to jon38iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is pretty typical for these seals to leak over time. They compress as you can see in the pic and let oil past them and down into the spark plug hole. It's not overly difficult to replace. Also replacing the valve cover gaskets and bolt hole grommet seals is a good idea if taking them off. I think subarupartsforyou.com lists a 'kit' with all the part #'s for doing this with enough supplies to do both sides. Then you see this, the spark plug tubes of course are the two mortar launcher looking things in the pic.
Got two new subies today
porcupine73 replied to zyewdall's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRegarding the availability of MT's in the Outback, check out cars101.com 2008 Outback page. It depends on the trim level; some are available with MT some are not; some have the sportshift autos.
Spark Plug ?
porcupine73 replied to jon38iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre these the bad boys you replaced last year?
'00 OBS P0302 - I have clues but no answer
porcupine73 replied to swiftt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXExcellent fix! It's nice when it's fixed. I believe so, but I believe it is 12V, not 5V. This is why the ECU grounds many circuits for control. It uses an NPN transistor so the ECU can use it's internal 5V on the base as a signal and ground the circuit being controlled through the collector. This 'open collector' method is common in lots of devices; then the device can use a low voltage, as low as 1V even, to control a circuit running a higher voltage such as 24VDC (common in industrial/control systems). When the transistor is not forward biased the collector is esentially unhooked from the emitter, at least for DC. It is proportional, except each injector fires once per two turns of the crank. The ECU controls the injector on-time. It does vary. This is how it controls A/F ratio for the amount of air being drawn in and other parameters. The longer the injector is open at a given pressure the more fuel that is injected. The fuel pressure regulator increases the fuel pressure as the vacuum decreases (and engine load increases), so the same injector on-time at lower vacuum would inject more fuel. The RC network idea could work, but you'd need a diode involved too. The inexpensive analog meter is easy.
P0420 OBD-II code
porcupine73 replied to srs_49's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you order two front sensors then? Good call on using the oem part. I would think maybe extreme cold weather could cause a problem but hot weather should be better. P0420 is probably one of those codes that requires three consecutive trips with fault so it might be happening one trip or two trips, then not the next, etc.
99 outback low idle speed
porcupine73 replied to NOMAD327's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is not odd. There are numerous posts about vehicles deveoping this odd vibration when stopped in drive after replacing axle half shafts with aftermarket units. The proper idle speed range should be listed on an underhood sticker.
exhaust Flange and gasket part numbers?
porcupine73 replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmmmm...yes let's see I posted it in a thread some time back let me see if I can find it...yes this thread. let's see...total for exhaust parts $21.40: exhaust gasket $6.16; two flange bolts ttl $4.40; two nuts ttl $3.66; two springs ttl $7.18. I also got two cam cap o-rings $6.12 ttl and starter contact set $5.31. Add on $9.95 shipping (their minimum shipping charge or 10% of order) for total $42.78.
porcupine73 replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe donut part # is below. I would highly suggest the new shoulder bolts too as mine were really rusted and broke during removal. Note of course this is for a 2000 2.5L Outback which might be different than yours. If you're ordering from a Subaru dealer I'd just order by description; that's what I did and got all the correct parts:
porcupine73 replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi. I might not be understanding exactly where your exhaust issue is, but I had a leak on my '00obw that these parts fixed:
help with 99 outback charging issue/dash warning light issue
porcupine73 replied to XSNRG's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMany of the warning lights get their ground through the alternator field circuit, so if the alternator or wiring to it is messed up that could cause problems. You should not disconnect the battery while the engine is running to check the alternator. It could damage the ECM as well.
P0183 Fuel temperature sensor A circuit high input
porcupine73 replied to akafriday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy guess is maybe the ECU uses the fuel temperature in A/F ratio control. I saw a post with this code on subaruforester.org not sure if s/he ever fixed it. The manual lists a whole bunch of wiring and resistance checks.
