3
Everything posted by porcupine73
Hi. I'm preparing to do this on a '96 brighton. My research seemed to indicate the hubs and spindles are the same part # drum or disc. As you said the backing plate is different though. Plus then you need all the parking brake stuff, shoes, springs, etc. Of course need the caliper brackets/mounts too. I'm not sure if the parking brake cable will be different; seems like it was the same part # drum or disc.
I used the little red packs of niglube that came with the oem pads for the rears and permatex high temp silicone lube for the fronts from amazon. Trying to see which holds up better. I've heard others say on nasioc that Neo HP 800 wheel bearing grease is 'da bomb as a replacement for the molykote (but not necessarily for the red niglube). I got a pound can in a couple days from stockcarproducts.com Others were saying to buy from bakerprecision.com which I did order from a couple months ago but I never received anything and they didn't return my phone calls.
TSB is technical service bulletin. Generally they call for Dexron III or thereabouts. I'm running amsoil syn atf. Yes if you go with that '00obw you want to be sure the magical mystery Subaru coolant additive (rebadged holts radweld from the U.K.) has been added under recall. That way you get I think it's 8 years 100k miles warranty on the HG's if they get that external leak. Definitely check for torque bind and make sure the FWD fuse is not installed and all tire match etc. I initially had anti-torque bind in my '00obw; that is it didn't put much power the to the rear wheels. I think the transfer clutches were glazed. It was fixed after some long stop and go driving on sheer ice where I kept hitting the throttle enough to get the wheels to spin.
I have an '00obw and the trans has been great so far (owned it for about 20k miles now). There are a couple potential issues I know of. First, some owners have experienced issues with delayed engagement to drive. Like it takes a few seconds to shift into drive. So you might want to check that out before purchase. It's some internal pump seal that 'prevents the rapid buildup of pressure'. I think there's a TSB out about it. Second, though this isn't much of an issue, there is a TSB out about an rpm flare up on the first second to third upshift after a cold night. I have experienced this, but it's very minor and I think the TSB is just to let people know why it happens and that it's not 'malfunctioning'. (Some hydraulic circuit drains and takes a moment to refill).
Thanks wtdash! I'll have to look into it. The main reason I ask is I see a sets of new KYB GR-2 struts on sale for the '92-'94 Legacys for $200 which seems like a good price. But if I can fit Outback or other higher struts I'd like to do that. The KYB catalog shows the same part no for pretty much all front strut mounts, but different nos in may cases for the rear strut mounts.
Something I read listed three keys for subaru's: the master, submaster, and valet. The master and submaster seemed to have the same function - everything, but the valet was just door and ignition or someting. Hm...that would probably explain why the '94 Legacy I just bought came with a key cut on a Nissan blank.
Hm wow that's quite a story! Good deal on the locks. I think what amsoil says is that if you use an oem or equivalent filter, that you must change the filter (only) at the oem specified intervals. Yes you would need top up oil to replace that lost from the filter change. But the oil itself is still good for the rated miles. Anyway if you think you're going to order amsoil regularly check out the preferred customer program that'll save you some $. And there's other great synthetic oils out there too included redline, neo, torco, mobil1, etc.
I've tried some various mixtures; my favorite is about 1:1:1 acetone, xylene, toluene. You'll hear thoughts both for and against. I'm not sure I've noticed much difference with any of this acetone, xylene, toluene mixes. edit: though these can be the good makings of a nice diy octane booster/cleaner. If you look at many non-chlorinated brake cleaners, they tend to have at least acetone xylene and toluene.
When you say stinky do you mean significantly different from new ATF? Is it blackish? What brand/type fluid was put in? The most likely reason for stinky/back ATF fluid is overheating, says above 200 deg. F regularly. You could put in an ATF temp gauge if desired. Was the in-radiator cooler flushed too? If it's plugged with shrapnel maybe it's not circulating too well.
You can't rely on the low fuel light. You need to measure the gallons filled into the vehicle with the same grade at the same gas station at the same pump for at least several fills under reasonably the same driving conditions including ambient temp to get a good comparison for fuel mileage. For the fuel filter, if it's been on for more than a year or 10,000 miles and you're suspecting it, just replace it, it's only like $20 for an OEM. Vac gauge if you want one just get something such as a autometer from summit. You can tie it in just about anywhere in the manifold vacuum system, there's several places. If you want I can post a pic of where I tied in.
Mirrors-do these have an autoreset thermal circuit breaker somewhere in the system like power windows sometimes do? Rear defrost-not sure; I've heard it's bad, some say it's not bad. Keys-I would imagine the dealer would want to see the title or at least registration or some proof of ownership. I mean you wouldn't want someone to just be able to write down your VIN and then go get a key made for your vehicle. Amsoil-I'm running all amsoil lubricants. The 25k interval or 35k interval depends on what oil you're running. There are other factors too. Do you make a lot of short trips? You probably need a shorter drain interval because of water and fuel dilution. I do mainly 30+ mile trips, ran the amsoil hdd 5w-30 about 20,000 miles last time and the used oil analysis was good. I do use a bypass filter too though so that helps. There are a lot of other factors involved too of course. My favorite thing is not having to worry about changing the oil every month or two.
