3
Everything posted by porcupine73
Good question on the wiper arm springs. I need a rear one. I can't remember for sure but it seems I asked about it and was told it is available only with a whole new wiper arm. I was thinking about trying to just find something similar at Ace Hardware. On my 'ol 88 lincoln I just paralleled some springs along side the original springs using coat hanger wire. Worked great.
Thanks for the info theflystyle. Yes I had a siezed caliper guide pin on the rear and the wheel got hoootttt so I'm checking over all the brakes now. That's what made me think about upgrading flex lines. For the '00obw I ordered stoptech front and rear lines since I was ordering rear rotors anyway. For the '96 I might try the goodridge when I do the rear drum to disc changeover.
Hi carnutbill and welcome! You really should just a OE Service Manual or at least a Haynes manual - that will show the step by step procedure with pictures. It's kind of long to list out in detail. If you've done it on some other vehicle it should be doable no problem. I'd suggest against installing any aftermarket half shaft. Either replace both boots yourself or maybe send it to the places that works with ccrengines.com to rebuild it for you. Another factor is - how long has the boot been ripped? If grit has gotten in there, you may need to replace more than just the boot and grease. If you replace just the boot, get a kit from a Subaru dealer. It includes the boot, bands, grease, and maybe a new circlip depending on the joint type. And might as well replace both while you've got the thing out, although I forget the details but it is possible to replace one boot without totally removing the half shaft from the vehicle but that means working under the car while doing it.
Maybe you could have them put it on only the second click instead of all the way on? I'm not sure but I think those pumps click off under a certain amount of backpressure. I didn't know there were places that don't let you pump their own gas. Many times these laws are the result of someone getting hurt at some point. It also might be that AFAIK the area around gasoline pumps is a 'classified area' as per NFPA, though I don't recall the group/div rating off hand.
Tell the 'autozoner' to humor you and give it a try. The '00obw is ODBII so and ODBII reader will read the codes. That's pretty much the whole point of ODBII - to have the same standard for all vehicles sold in the U.S. I don't know about his thing about the 'airbags might go off'. There are some ~'96's I think that sometimes have an issue with airbag deployment for no apparent reason so maybe that's what they're thinking of. If it is front O2 sensor, note there was a recall for some '00obws on this sensor (for cracking), and get an OEM sensor for the front. Autozone not wanting to read the codes reminds of when I went to Carquest looking for a code reader. They told me it was illegal to sell them anymore. Went down the road to Pepboys and they had many models.
Sounds good nipper; I think I'll just replace everything. The fronts probably need to be looked at too. So what's the type/brand of pads and rotors to use? Stick with OEM? Or something aftermarket? I've heard some people say they like brembo rotors. Regular? Slotted? Drilled? Drilled&slotted? How's about EBC pads. But green or red? Phew too many choices. I wonder if I should replace those rusty backing plates too? Though I assume I have to pull the hub to do it.
starter
porcupine73 replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You can get the starter contacts from the dealer. I got mine from http://www.subaru-parts-dealer.com for abour $7 I think. There some other make's contacts, maybe Nissan but I can't remember, that also will fit. Someone had a nice post recently with good pictures of an actual starter taken apart showing the old pitted contacts. -
Well I got both sides apart today. One of the guide pins on the caliper on the hot wheel was frozen. All the others moved pretty freely, but one was stuck. Also the pads were pretty frozen in the caliper mounts. There is rust on everything in the braking system, which isn't too surprising since this area uses rock salt. All pad thickness is still good, all at least .499". Rotor thickness is good, about .393". Rotor runout is about .003" on both rotors. Rotors have no deep groves, but they're kind of rusty. So I guess I can just clean everything up and reassemble. Or should I just replace everything with new (which I am always tempted to do) and rebuild the calipers? Here's some pics to show the condition of the existing parts:
Thanks for the info guys. Nipper that Permatex looks like a good product. I'll have to see if napa has that. Or I'll see if I can find this similar Permatex 'hi temp' product. sea#3, that looks good too. Did you buy that retail somewhere or is it an internet order item? I think the Niglube is maybe sold only in Japan. I found some sites with info but they had Japanese text on them.
starter
Oh depending on the issue, the contacts are known to sometimes go bad. -
starter
I'd have to say yes. Subarupartsforyou.com lists the following (varies based on MT or AT, but same part # for 1990-2004 Legacy. 23300AA220R1 Legacy 1990-2004 Engine, Starter STARTER OEM REMAN FOR MANUAL TRANSMISSION LEGACYS ALL 1990-2004 (We will buy back the core in the box for 30 dollars after the job is done, contact us by email and we will arrange) 23300AA230R1 Legacy 1990-2004 Engine, Starter STARTER OEM REMAN FOR 1990-2004 LEGACYS WITH AUTO TRANSMISSIONS ALL (We will buy back the core in the box for 30 dollars after the job is done, contact us by email and we will arrange) -
This NIGLUBE RX-2 (Part No.003606000) is the grease specified for lubricating some parts of the brake system including the disc caliper mount guide pins. Anyone know of an alternative to this lube? A google search only returns a couple of hits. I think this is the red grease that comes with the OE Subaru caliper rebuild kits. There are alternatives to the Molykote AS880N (Part No. 26298AC000) for other parts of the brake system such as where the pads meet the pad clip. One I saw was a Neo grease, maybe my local race shop would have that.
