3
Everything posted by porcupine73
The info about the TCU learning parameters there was from '96 Legacy (4eat phase I). I didn't yet find that same statement for '00OBW (4eat phase II). True, we need to know whether we need to source or sink current for the duty c. I suppose using a microcontroller in this application would have other advantages, such as to allow for future expansion and other functionality.
Alright thanks for the input 99obw! Do you know of any chips that can, with a minimum of external circuits, handle the variable duty cycle from 0-100%? Such a chip probably wouldn't handle the amount of current we need, so what would we use for current gain? Maybe on of those honking TO-3 case transistors? A FET? Based on an other post about the 'buzzing' sound I'm going to guess the frequency may be as low as 200Hz. Initially I thought it might be like 20kHz or about to prevent humans from hearing any sound from it. Probably not critical at this phase, but do we know if the power to rear is linear with the duty cycle? We know 0% duty cycle=50% power to rear, and 100% duty cycle = 0% power to rear. But does 50% duty cycle = 25% power to rear, or is this a non-linear relationship? Any other thoughts on making sure we don't drive the duty c if it isn't supposed to be driven at the time? Hm, I just found a caveat in the service manual. Operating this circuit under wheel slippage conditions could cause the TCU to learn odd torque parameters thus causing strange operation in the future when in 'auto'. It says For example, suppose the circuit is operating at a fixed duty cycle and rear wheel slippage occurs. Unless the shifter is in '1' or something, the TCU probably starts outputting a higher and higher duty cycle to reduce power to the rear to stop slippage. However the TCU's duty cycle action has no impact because the circuit is operating. Thus the TCU may learn an improper duty cycle value for the condition.
that's true, if they're brand new bulbs they should be fine. if the '97 is anything like my '96, fuse 6 (15A) in the fuse panel located under the dashboard is for the front fog lights. do you hear a relay click or anything when pressing the fog light button? fuse 6 is the sixth fuse from the upper left hand corner of the fuse panel.
Hi Richard, wow that's a sweet line up of cars. Yes, I found out you can get the FSM's on CD on techinfo.subaru.com. I believe it is about $200. I have reviewed the alldatadiy.com info and it is identical everywhere I have looked to the FSM including the pictures and descriptions (for '00OBW). I got the printed OE manuals on eBay for $150.
Hi Richard, based on your other posts you don't strike me as a man to cut corners. I'd buy the OE Subaru service manuals either on CD or in print. I picked up a print set on eBay, but that was before I knew I could have gotten it on CD. A completely acceptable alternative is to just get an alldatadiy subscription. It gives you access to OE material at much less up front cash outlay. If you're not going to be getting into any involved work, the haynes/chilton will probably work. I've seen too many errors in them to trust them for important work though.
Hi, whether or not it is a state or local issue, it probably violates some federal law. If at all possible you probably want to keep the front O2 sensor intact. This sensor is used for air/fuel ratio control in closed loop operation. You need to know whether all emissions devices need to be intact for inspection (if you have an inspection). In NY they are required and there can be no disabled/removed components. If you ever decide to sell the car, I would make sure to intimate that fact to the buyer.
For a solar panel to really make enough juice it really needs to be as much in direct sunlight as possible. On the dash would probably work. I'd get the biggest meanest solar panel you can find; otherwise it probably just won't be enough power to keep the battery charged. Harbor Freight had a monster 45-watt unit on sale recently.
Yes, any suby's I've seen have the cigarette lighter powered only with key in acc or run. Two potential workarounds: Chop the hot wire to the existing socket and wire it directly to the battery + (with a fuse) Add a second aftermarket accessory outlet wired directly to battery + (with fuse at battery terminal)
Another option, if you can work it, might be a battery quick disconnect. This disconnect replaces one (or both) of your battery terminals. It has a lever you flip and you can pop that terminal off the battery. If you disconnect it when you park the car for a period of time it should prevent the drain. Of course it could cause other issues, such as loss of radio station presets, possible alarm going off upon reconnection, loss of ECU&TCU learned parameters, etc. What brand/type/size battery is installed? Maybe if you make only a short trip after starting the vehicle the battery may not be fully recharging.
Possibly, but I would suspect in that case the dial knob is an input to the TCU rather than instrument directly driving the duty c. I suppose another risk of this project would be energizing the duty c when it is not supposed to be energized (i.e. duty b energized)? We'd have to review the charts in the service manual.
Hello, anyone want to design and build a do-it-yourself DCCD (driver controlled center differential)? It would be for AT vehicles only obviously. This circuit would be a build on the manually controlled locking center diff. We'd need to find out the waveform the frequency at which the TCU drives the duty c. It could be measured using an oscilloscope on the duty c drive wire. We'd need a variable duty cycle (via potentiometer) circuit oscillating at the proper frequency with the proper waveform capable of outputting at least the required current to drive the duty c. In 'auto' mode, we'd just leave the TCU output to duty c connected as is. Anyway this may be a crazy idea but what do you guys think?
The vehicle should be able to sit easily for more than a month without the battery going dead. As the car is parked on the street I'm guessing running an extension cord to a trickle charger won't be feasible. The portable jump starters should work just fine. With a unit that plugs into the cigarette lighter, you might have to wait a few minutes for it to charge the battery a bit before starting. This results from a max of say 10 or 15A being transferred from the portable charger, which is not enough by itself to start the engine. If the portable charger uses alligator clips to connect directly to the battery terminals it should start instantly. Depending on how much you're looking to spend, I'd suggest trying an Optima yellow top (or blue top) battery. They're pricey, but they're deep cycle and might handle whatever is going on with the vehicle. You could use a remote starter to start it for a few minutes every couple weeks. I don't recommend it though as starting for a few minutes without the engine oil reaching operating temperature will only result in fuel dilution and water condensation building up in the oil.
Hi, for all 4 shipped it was $313.64 from eBay vendor performancepeddler. Their auctions state whether the item is available for immediate shipment or what the wait will be before shipment. This was for all 4 KYB-GR2 struts for '96 outback (part #'s as per KYB's web site PDF catalog). I go by the part # KYB lists, not necessarily what various vendors state as the part # for a given application. These struts are for my '96 legacy to '96 outback strut&spring conversion next week.
Your '01 should have the 4eat phase II. I'm not sure why the mechanic would say the pan needs to be dropped. The phase II 4eat's have the external filter on the side of the ATF (or in the fender area on the H6's). From the diagrams in the service manual it does appear there is also an internal screen filter but never says anything about replacing it (and it shouldn't need to be replaced if the filter on the AT discharge to cooler catches all the shreddings). The phase I 4eat's have the replaceable screen filter inside; I changed mine and like gary said there wasn't anything on it. But it made me remove a cooler line to get it out and that's when another gallon or so of ATF dripped out. Another way to get more fluid out without removing the pan is to do the 'pump and dump' unhook cooler line method.
I just ordered front and rear KYB GR-2's for a '96 Outback from performancepeddler on eBay. Prices seemed OK (included shipping), and I got them all in a few days. I've had excellent results from tirerack and summitracing previously. I didn't order from them because both were out of stock on at least one of the struts at the time. I looked at replacementshocks.com I think it was, but they didn't show stock. When I called them it was a call center in India and they were out of stock on two of the struts.
