3
Everything posted by porcupine73
Hi pdxsuby! Maybe you didn't tighten it enough, you have a bad crush washer, you have gouges on one of the mating surfaces. I've seen it leak a little from the engine oil drain plug on my '00OBW too when I didn't have a sealing washer on it. Started using 20mm crush washers from parts america and it doesn't leak anymore.
I think two of those wires are for power for the heated wire and the other two are for the sensor wire. The ECU knows the intake air temp and stuff and then can tell the mass of air passing by reading the sensor wire. With a meter I don't know if the user could tell whether the output signal is correct though.
Hi Seamarshal and :welcome: ! Does it have a separate indication for each door and the hatch (if so which one is illuminated?) or just one general indication? Those door switches as you've already said you replaced the driver's door one I've found can get a little fussy with corrosion and stuff over time. Does this issue make your dome lamp stay on (provided it's switch is set to come on when a door is open)?
I had that happen on 4eat phase I also, dropped the pan and in order to remove the filter it seemed this pipe/tube had to come out, which when removed another gallon or more of ATF came out over the next few minutes. I don't know if that was the purpose of having that removable tube run over the filter but I thought it was pretty slick to sort of make sure it all comes out when changing the filter. In subsequent changes when not doing the filter I just used the pump and dump method. I've tried that lucas AT fix goop too, man that stuff was so thick it was hard to get it down the dipstick/fill hole. Didn't seem to make any difference and haven't used it since. I agree unless it's a last ditch effort I probably wouldn't use anything like that as good fresh ATF has cleaning properties anyway.
If the knock sensor is gone, like to the point where the check engine light comes on because of it, you almost certainly will not get knock because the ECU pulls maximum timing as a 'failsafe' but you lose power. If it's just getting overly sensitive or it's cracked then again you probably won't get knock either because it's output signal may start looking like knock all the time so ECU pulls timing in this case too.
If that O2 sensor was replaced previously it may have gotten messed up then or overtightened or galled or no antisieze or something. Like any service industry the dealer is under constant pressure to do more in less time and rather than spend time trying to free the thing up they may have just really laid on it with a breaker bar or impact wrench or something and whoops!
Thanks for the info nipper. I'm not really sure how this venom gadget works then. Yah those gadgets on eBay are interesting, especially the 'voltage stabilizer' for more engine power, I think my favorite is the 12V squirrel cage blower 'turbo'. That wiki article is interesting, I saw it says "in Naturally Aspirated engines maximum power is frequently reached at AFR's ranging from 12.5 - 13.3:1"
Hi all, had another low beam blow out on my '00OBW the other day, I think it was the low beam but I can't remember, it was the H1 (smaller) bulb. When I took out the old one, I noticed this brownish gunk around the seat between the bulb and headlamp case. It had this gunk the last time I replaced the bulb and I cleaned it all up at that time and now it's back. Actually last time the bulb wasn't even blown out it just didn't have a good connection on that springy thing that holds the bulb in place. The white plastic gadget has the gasket in place and everything and I don't see corrosion elsewhere in there. Also, I just learned it's best to replace the H1 bulbs with the engine off and key out of the ignition. I tried to it with engine running and accidentally touched the hot wire for the H1 bulb to ground and then heard the engine load up a bit and popped the headlamp fuse. Then I couldn't find any replacement fuse but noticed in the manual it said there were extras in the engine compartment fuse box cover (which i had just removed) and indeed there was!
I've been swapping my ScanGauge between my '96 Legacy 2.2L AT NA and my '00OBW 2.5L NA and watching the IGN parameter. I note on the '96 2.2L it will go as high as 50, but on the '00OBW 2.5L it goes no higher than 40, and on the '00OBW 2.5L it seems to be a little lower overall. I'm wondering if the units are different between the ECU's, or what, I'm assuming the higher number is more optimal for power although of course that's what the timing map is for I'm guessing. I heard most production cars today come with conservative timing maps because it helps keep emissions lower. Anyone see any performance chips or anything for regular (i.e. non spec B or C or Sti)?
Hi, I was wondering if anyone has tried the 'VENOM 400 Performance Control Module'. I see Summit has them for various Subaru's. The instructions say the connections needed are power, TPS signal wire, and MAP or MAF signal wire. My guess is that when the thing detects you're really getting on the throttle, it manipulates the MAP or MAF signal to trick the ECU into running a little richer temporarily. Any thoughts? I might like to give it a try but it's nearly $300 so I'd like to know if anyone has had success with it first. Heck for that much you could nearly slip in a 50 shot of NOS.
That '04 maint schedule does show to inspect a lot of things, but the items to actually do such as replace coolant, engine oil, fuel filter (why does the wrx sti have double the replacement interval for fuel filter), air cleaner, brake fluid, rotate tires seems pretty straight forward. ATF and gear oil replacement are suggested under 'severe service' which some drivers will qualify for based on their description.
Yah I think the 105k mi belts have Kevlar or something in them that makes them so durable. From what I've seen on endwrench it seems the vehicle will probably start if anything is one tooth off but there will be power loss; two teeth off it probably won't start and that drops compression pressure quite a bit.
Maybe change coolant/antifreeze. What does your manual show for spark plug replacement interval? Probably just depends if you have long life plugs (such as platinum or iridium) in it. Is this an MT or AT? If AT you could add front diff gear oil to the list (assuming on the '04 AT's the front diff still doesn't share oil with the ATF). Could also consider changing PS fluid.
If you're considering a rebuilt engine I hear in other posts the CCR I think it is top notch. The only time you'll see coolant out the water pump weep hole is if the bearing is loose/worn. All the fins could break off the impeller for some reason and there might not be anything coming out the weep hole. The water pump is a pretty simple device.
