				Posts5252
				Days Won3
Everything posted by porcupine73
	Sweet cannonball! I have a '00 OBW also. I'm working on it right now actually and am planning to put in that Subaru coolant conditioner, which is actually relabelled something else, forget the name, it's in other threads. It's kind of goopy, but it should seal the leaks. My understanding is that the leaks for this model (i'm so very much hoping anyway!!) are external leaks, not leaking into the oil or anything else. Some people I think have claimed that the goop has plugged up heater cores, etc., but maybe they had other leaks too; I'm going to put in the goop.
	Howdy, planning to do a turnaround on my '96 legacy brighton 2.2L AT 105k miles. Wondering if I should preemtively replace all four wheel bearings and the inner and outer cv joint boots and repack with redline cv-2 on all four shafts; not really noticing any issues other than boots have little crack marks on them but aren't torn. Would probably pick up a hubtamer if I do it. Also wondering if there's anything else I should just do at this time in addition to what I'm already planning to do: replace timing belt (includes check oil pump back plate screws and reseal and o-ring, replace cam and crank seals, replace water pump) replace brake rotors (warped), brake pads, rebuild capliers (have oe kit), replace strut&spring assemblies with outback components for lift for winter and trailing, change coolant and oil. Thanks! edit: oh forgot tires are cupping on inside edge so also checking ball joints, suspension shake down, and alignment, hopefully at alignment specialist or dealer, after complete.
	Did you mean to post a link for the additive? Additives that say 'water pump lube' are basically useless; the water pump has a sealed bearing anyway. Anti-rust, etc., well that's what the additives in the coolant you use are for! I wouldn't run any additive except maybe the leak preventer goop Subaru recommends for those 'external head gasket leak' issues. Use distilled or reverse osmosis water in the coolant if possible. I like a G-05 coolant, has some silicates for immediate corrosion protection, plus a OAT for a nice long term protective coating. Conventional high silicate antifreezes can tend to precipitate the silicates out if left in too long leaving a kind of sandy stuff in the cooling system. Cooling system cleaners aren't really suggested either. Still, ethylene glycol based coolants are mostly ~97% or so ethylene glycol, 1-2% water, so that's only a few percent at most of additives.
	Hi dmanaenk! '96 legacy brighton here too, sweet rides no doubt! anyway i get some good rattling just above idle which is loose heat shields. Sometimes but not always at idle it sounds like something is knocking once per engine rev, never figured out what it is, sounds like something hitting around the flex plate or whatever that is between the engine and AT that the starter engages to.
	D1driver, sounds like a plan on replacing the timing belt! Highly suggest going OE on that belt. Also check for loose/leaking idlers. Might want to replace crank and cam seals while you're in there. NOTE: you must lock the cams on the DOHC before removing the belt or you could smash the valves into each other if the cams turn.
	A cheap actron reader from pepboys reads the codes on my '96 legacy with no problem, '96 actually has to be ODBII per federal requirements I believe. I've climbed steep winding grades with this '96 with no issues but with a full tank of gas, maybe if there's not much in the tank it can run the pickup dry?
	Well if you're concerned about differences in gas prices between different octanes, then just calculate the cost over how long you plan to keep the car, like if premium is 30 cents more per gallon than regular and you plan to keep the car 150,000 miles if you get 24 mpg then the cost is $1875 which is actually less than that because of inflation and you pay it over the time you have the car when you buy gas.
	Well basically if you have a particular level in your overflow tank and you see it going down over time then of course the coolant is going somewhere. Usually when cold I fill to the line on the tank. Just after changing the coolant I usually fill it up a few inches more since it usually gets sucked in eventually and even if the overflow overflows it just spills out, maybe not environmentally friendly but it will work.
	If it's just low i'd doubt flushing would make any difference, though it's never a bad idea to keep the coolant fresh esp. if you're using conventional high silicate 'green'. You definitely want to make sure all air bubbles/pockets are out correctly; there are other threads on how to do this. Just pouring in the new coolant til it won't take any more almost guarantees there will be air pockets.
	You need to make sure all the marks line up. It should still start if you're only one or maybe even two teeth off but more than that who knows. You need to verify what marks you're looking at, i.e. _not_ the arrows on the cam sprockets but rather the hash marks, etc. The marks on the belt will not line up on every revolution.
	Pretty sure the requirement is 87 octane, I don't think it's a 'high' compression engine or anything, unless you have a spec b or something then it might have 10.7:1 and be able to use 95. Plus your knock sensor might help if there's any real issues. edit: i stand corrected; cars101.com says for the LLBean it's 91 octane.
	Sweet sounds like there's codes to read. I don't know how to read codes on the pre odb2 models. There's probably some connectors under the dash to plug together or something. I'm sure it's in other threads on here. The front oil leak should be the easier of the leaks to fix as you don't have to pull the engine to remove the timing belt and do the cam seals and front crank seal (which is on the oil pump actually). The timing sounds about right, that's what I see in my '96 2.2 at idle anyway. About the #3 cylinder, how about if you disconnect the plug wire to some other cylinder, do you still not notice a difference or is it just with #3?
	Hi and welcome! Is the #3 plug wire in good shape where the connector pops onto the plug? Basically the thing sparks the two opposite cylinders at the same time so if #4 is firing then it almost has to be plug wire or maybe coil pack since you already changed the spark plug. Oil leak from the inside the timing cover is most likely oil pump o-ring or has come unsealed from block, not sure if this early a year had the thing where the screws on the rear oil pump cover that holds in the rotors tended to back out thus forcing oil out the crank seal. and/or could be the cam seals. Should be pretty obvious if you get the timing belt cover off. Oil leak at the drive end might be from the rear main seal, i think from other threads maybe the thing is plastic that holds the seal and should be replaced with an updated metal one, bad thing being engine has to come out to do it. I have a '96 legacy and it shifts hard from 1-2 also though I changed the fluid and everything it still does it, not sure why, but doesn't seem to be causing any issues.
	I got mine online from a Subaru dealer for $71 plus shipping. I don't know which ones you were look at on ebay, like this one looks similar to the one I got from online Subaru dealer. This pic shows my new pump on the left and old pump on the right which will at least show what a recent OE pump looks like. There used to be cast impellers now apparantley Subaru has switched to all stamped impellers. The main difference I notice is the one on eBay has less fins on the impeller, it might not be the high velocity version. edit: Oh the other difference I notice with the eBay one is that the pulley is a shiny metal wheras on the ones I bought it was black. edit2: Oh the one on eBay doesn't seem to have the rubber strip in the little groove either.
