3
Everything posted by porcupine73
I'm new and need some help
porcupine73 replied to MSsub22's topic in Meet n' Greet. Your USMB Welcome Center
Hello and welcome to the board! Can you give a few more details, such as what kinds of mods you are looking for? Such as a 6" lift and super swampers, we can probably hook you up with that. Or in general for mods one can do a lot with a chop saw and steel tube and channel. -
New to Subaru. Have ea81 NO SPARK
porcupine73 replied to SubaBoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ok. I'm not real familiar with that engine. But there are a lot of experienced members who are that will probably have ideas of other things to check. I'm assuming she also has cam position and crank position sensors, are those good and hooked up? Unless it had a distributor in that engine..... -
Hello and welcome to the board. The Vanagons are cool. How's the timing belt? Did it fail or any idlers fail etc? -
I'm pretty sure '98 outback had dual piston front calipers. Both pistons should come out. But if you are pressing the pedal without the pistons touching the rotor, only the piston with the least resistance may start coming out. If you put a piece of 2x4 or some other wood in there so that it blocks the piston that is coming out, then the other piston should start coming out when the first is blocked. CAUTION - don't let the pistons come out very far. Without wood or something there if you press the pedal enough times the piston will come out of the caliper body. But it is possible that the other piston is siezed. If any water gets behind that boot it starts rusting and then eventually the piston gets stuck in the seal with its rust and won't move anymore, or will come out but won't go back in. All contact points between the brake pads and the caliper brackets., clips, etc., except the brake pad friction material itself of course, is supposed to have brake grease on it.
Well, I"m pretty sure the '96 2.2L did not have platinum plugs as original equipment. In the owners manual it lists an NGK and a Champion option iirc. Genuine Subaru wires are the way to go, they work and don't cause misfires and such like many aftermarket wires for soobs do. Sure some poeple are able to use aftermarket wires but at the same time there are cases where they misfire and such and when replaced with genuine wires then the problem goes away.
Getting the code flashes on that era can be tricky. I don't think it means you have to start it in that one step. I know somewhere on here someone had a good thread about how to get it to flash out the codes. Almost like there was a mistake in that manual or there was a slightly easier way to get it to flash them out. The 16 flashes means it found some kind of fault; often it is a solenoid it is detecting problems with, and that can certainly cause some bad shifting.
Hello and welcome to the board. That first item with the flashing parking lights sounds like the security system. it will do that if the battery gets replaced or goes dead, etc. If you have the remote just use the door unlock button. Otherwise I think you can cycle the key from off to run three times quickly to reset it but that might have been only on later years. See if you can get more details about what module the mechanic replaced. There could be lots of reasons for it running poorly. Does it have a check engine light on at all and if so what are the codes?
Hello and welcome to the board. I'm sure members will have some ideas to try. I know I was just reading something about intermittent misfires on endwrench.com but I can't remember the details. Maybe I'll see if I can find the article again. I see you didn't try the ignitor, but that really shouldn't be it since it also drives the opposite cylinder at the same time.
You might be noticing more power with a leaky exhaust, I had noticed that too on '00obw when the donut was gone out. Because then there is less restriction on the exhaust gases which means the engine spends less power pumping out the exhaust, which leaves that power for driving the transmission vroom. You could put in those side exhaust cutouts like the muscle cars. Then when they want to do a fast take off the open the cutouts, then once you're cruising they close them again so it's quiet.
I got this one exhaust patch goop somewhere, I think it was at napa, that seems to work pretty good on smaller leaks. It has sodium silicate and a bunch of warnings all over it. But for a bigger leak some kind of wrap would be needed as well. Fortunately the exhaust isn't going to be quite as hot way back that way as it would be further upstream in the exhaust system. So in the way back I have had good luck with JB Weld or the similar epoxy products bridging even 1/2" holes or so if you wait for it to harden a little bit before smoping it on. Or you can get some wire mesh mixed in there like hardware cloth or something to help support it while it hardens.
I think the gearing for the 4 cyls is selected pretty ideally. So yes ok maybe when you get up to 80 mph the revs seem kind of high but at that point you're in top gear and moving at a pretty good clip. These 4 cyls have ok power but they're not some torque monster V8 that has the power at low revs to turn like 2000 rpm at 80 mph either. I switched my '96 Legacy 2.2L to Outback struts and tires and I do not at all like the gearing now. It shifts too early and for any amount of get up and go or encountering a hill I have to downshift to 3 or 2 manually or it feels like the engine is lugging. I don't mind shifting it like that, I like doing it, but to have the gearing be 'taller' in these things in my mind just wouldn't work out for a production passenger car.
New to board, just picked up a GL!
porcupine73 replied to js3000's topic in Meet n' Greet. Your USMB Welcome Center
Hey welcome to the board! Nice soob. I like that color too. She looks to be in good shape. She will serve you well. -
92 loyale smoke from under transaxel
porcupine73 replied to analog.anarchy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well one additional thing to say, is if after a proper ATF change the transmission has issues, the fact of the matter is the transmission had problems before the fluid was changed too, they were just being masked by all the crap built up in the trans. Now I did have this happen too on a '91 Escort with a garbage transmission. So there is going to be people who have experiences both ways. Ultimately you'll have to make the decision as to whether to change it or not. The common failures modes are described above. If your fluid is burnt, you may want to flush the radiator ATF cooler at the minimum, since if that's plugged or restricted, even if you change the oil the trans is still going to be running hot. Otherwise someone could say, yah I've seen this one guy who changed his engine oil and then his engine threw a rod two days later, so I'm never going to change my engine oil again. -
I don't think an engine oil leak would necessarily cause those symptoms, unless perhaps you ran it low enough that the oil pump sucked air for a period of time. Is your front diff gear oil level correct? Maybe there is an issue there or somewhere else in the drive line. Chances are it is the oil access cover, and not the rear main seal that is leaking. They are close to each other so often people assume it is the RMS. Members who work on soobs regularly have reported that the RMS doesn't usually leak. The oil separator on many engines in that era was plastic. To fix the leak, an upgrade to a metal separator with new screws is required.
I don't know for sure but it seems from the ones I've messed with that on some models the switch is normally open and on some it is normally closed. If you leave the wire unhooked, does the oil light stay on. And when you ground the wire does it go off? Or the other way around?
