3
Everything posted by porcupine73
Sure man, why just the other day this cat was telling me he was taking apart a '91 and they came out tie dye. haha just kidding. I don't think they changed color like that. Mine look like they were white but they oxidized and maybe got some rust color on them. They're not quite as dark as yours. It's like when something white is exposed to cigarette smoke long enough it turns brownish, that's sort of what it seems like happened to them.====================================================== Yes. My fronts are doing that. The struts even when new don't exert a ton of force upward. Because that is not their purpose. The spring is to hold the weight of the vehicle; the strut is simply to dampen movement.====================================================== There are marks on the bolts on the front, but that is for camber. And if you're changing height they aren't going to be the same setting afterward anyway. Toe you shouldn't have to worry about if everything is the same height. Even raising or lowering a little toe doesn't have to be a big issue, but it can change because of suspension geometry. I.e. the wheel moving up and down doesn't always move up and down in a perfect arc.
Thanks for the info. I had some 3/8" grade 8's. They are the right diameter but they're too long. So I'll pick up a shorter one and hopefully be good to go. Maybe I should leave it out though.....it just feels like if I put a bolt in there something will happen shortly thereafter requiring me to remove it (and a lot of other stuff)..........
Actually yes the bumpers i believe are originally white. I was disassembling my '94 and was surprised to see bumpers that same color. But I think it's just because they are oxidized and deteriorated. So I ordered the KYB bellows kits. Which I think I need anyway because the Outback struts are longer.
It is often cheaper to replace the axle than to replace the boots BUT BUT BUT you must tread very carefully here, especially with front axles on an automatic trans. Many of the parts store axles end up causing odd vibrations. Not just on Subaru's; it's just the nature of the axles for some reason. So if the original axles are salvagable it can be worth saving them.
Thanks for the update. Lots of times the owner can't think of a reason for torque bind, but yet, there it is. Measure your tires, they need to be within 1/4" circumference and yes you are supposed to measure them to check. If it was run on a flat tire too long, towed improperly, got a flat and had just one or two tires replaced, etc., could all have done it. Maybe not by you, but by a previous owner, unless you've owned the thing since day 1.
Yes reading the ATF is tricky on soobs and I am sure there are threads many pages long on the art of it. I always check it cold, and look for three or so consistent pulls on the dipstick. Then I'm looking for where the fluid is solid on the stick front and back. The rest of the fluid is 'noise'. If you add fluid you have to be really patient, like pull the stick three times or so don't even try to read it just wipe it off, because the fluid will be all over in the tube from having just poured it in there. I know Subaru wants it checked with trans at operating temp but I can never get a reasonable reading that way that's why I do it cold. So what did you see that was yellow in the fluid? If it's watery, it's possible there was condensation in it if it isn't coolant or gear oil.
Usually ATF's are dyed red but I suppose they could be dyed any color really or no color at all. If you checked the ATF, you could also be seeing engine coolant mixed in the ATF if the in-tank radiator ATF cooler has breached. Either gear oil or coolant is very bad for the automatic transmission; generally it trashes the clutch materials.
Hello. So I was going through my '94 Legacy wagon and I noticed the bolt between the dogbone and the engine is missing. Is this bolt critical? Can I just get a bolt of the right size and put it in there or is it some special fancy bolt with some kind of setup procedure? I think this soob had a remanufactured Subaru transmission installed at some point based on vehicle history, and the transmission is painted grey, which I see Subaru says they do to their reman'd transmissions. I'm assuming when it was reinstalled the dogbone bolt wasn't put back in. Also I cannot find the FWD fuse on this thing. It is simply not where it is supposed to be, or anywhere for that matter. I'm guessing that has to do with the remanufactured trans as well.
Which tie rod ends are bad? The inners or the outers? And on both sides or just one side? Either way, the entire rack does not need to be replaced. The tie rod ends are replaceable. The outers are pretty easy. The inners are a little more tricky but not hard as long as you have the tool that slips over the inner tie rod end for removal (such as the Harbor Freight tool). That link you posted the rack appears to include the inner tie rod ends (But if your outer tie rod ends are bad you'd need those too).
IIRC there are a few different shift maps in the TCU, would have to maybe read up on those and see if any of them sounds like what you are describing, then see what might be making the TCU go into that particular shift map. The articles are in the archives on endwrench.com somewhere but I haven't erad them in a while. It would be for the 4EAT (not the phase II; they won't specifically say phase I I don't think though that's what we call it now that there has been a later phase).
Hi. Not sure exactly what went wrong with your struts (haven't heard of that happening before), but say a 96, 97, or 98 Outback should fit. I am trying it right now with a '94 Legacy. I suppose the fronts could be done separately of the rear but I would do all four at the same time. Who knows what kind of weird handling there could be from having the front a bit higher than the rear. Probably not much more than loading the rear up with tons of people and gear or towing but having them all match would be better in my mind. The struts do have bump stops in them, on the strut rod. But they do often deteriorate with age and they're not going to stop damge from bottoming out if it's a hard hit. They give a touch more time for deceleration when bottoming out but a hard hit it won't make much difference.
You don't have to make a special trip to the dealer. If you were going to order the NGK wires online, you can order Subaru parts from dealers selling online just as easily. And often it's a lower price than what the local dealer charges unless you have some connections there. Places stating 'OEM' parts are tricky, because it does not necessarily mean it is the genuine original part.
Well I would suspect the issue is other than a loose belt. I have used the belt dressing (Kanolabs dynall) many times on the soobs with no issues. However if you have say a failing bearing in the alternator, the belt dressing isn't going to make any difference with that, and the bearing will eventually fail. It doesn't mean the belt dressing was the problem though. No, the crankshaft pulley should not have any noticeable runout. CAUTION: If you are seeing much wobble on the crankshaft pulley that drives the a/c and alternator/p.s. belts, it is possible the bolt is backing out. This does happen sometimes after a timing belt replacement where the bolt was not tightened correctly afterwards. This info is all for H4 soobs. If by chance yours is an H6, that is a different accessory belt setup (though some did have issues with an idler going bad on there). For the cleaning I'm not sure what I'd use. Possibly non-chorlinated brake cleaner I would try if I were going to try this. But that stuff is highly flammable and I'm not sure it is completely compatible with the belts, though usually they contain things such as xylene, toluene, MEK, mineral spirits, etc.
Why do you not want the genuine Subaru wires which are known to work well on soobs? The aftermarket wires even NGK may be suspect. Magnecor wires seem to be the only ones I've heard are usually ok as well. The genuine wires are SOA430Q119 WIRE SET, IGNITION FOR 2000-2003 LEGACYS (non H6) and Subaru dealers who sell online will sell these for around $40 a set, so it's even a little lower price than the aftermarket options. Subaru genuine parts are not always way out there on price, they are actually often very competitive, plus they in general are good quality parts that work and fit well.
Yes that is mentioned in this thread too, the driveshaft u-joints gg mentioned or the 'propeller shaft' as I called it. Based on your description of the change with the FWD fuse taken out the propeller shaft might be suspect. Because now the transmission is actually driving the propeller shaft rather than turning it by dragging it via rear wheels so it might change the feel. My '94 has this kind of shake around 60mph or above if I let it sit too long and I can feel it under the driver seat somewhat. ATF changes can help if it is the transfer clutch; it did help in my '96 quite a bit too. I think a big part of what happens there is that the old fluid loses its dynamic frictional qualities pretty fast, and many people never even change it at all. So you really don't know what you're getting in a used soob. So a few changes can help clean out the junk and give it back the required frictional characteristics. I wouldn't necessarily call 8-9 quarts a small sump; that's pretty standard for an automatic transmission in a passenger car.
And stuff just sitting around just deteriorates unless you keep it indoors and heated in the winter. Outside it will just rust and rot over the years sitting there anyway.
That doesn't surprise me on the parts markup. I believe the general rule of thumb is to double the price on the part. I doubt that is exclusive to any particular chain. An independent shop might get away with less markup. Also the prices the parts stores were quoting you were probably a little higher than what they charge a repair shop that is buying a volume of parts from them on a regular basis.
Yes a lot of times the parts store alts are basically 'repaired' and not actually remanufactured. My '96 had a napa alt in it when I got it that was making a squeaking sound so it got replaced with the Subaru alt. You might check into the Subaru alt for that, there was a recall on them around that year for some potential issue with the brushes. Though if you already replaced the alt they probably won't do anything for it now.
If you are even a tooth off that can be enough to make it not start. Those oil leaks like cam seals and such really need to be addressed, since it's already getting oil on your new belt which wil shorten its life. Those idlers look like they've seen better days too, many times the idlers, esp that geared/toothed one don't make it to 200k miles. I'm assuming you were not turning the crank before you had the new belt on and lined up? If it hit any valves while you were turning it manually it would have stopped.
