Everything posted by porcupine73
RPM's ??/
porcupine73 replied to robs5788's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe stuck in 2nd gear would be it going into limp home mode. If the TCU detects a problem where it doesn't think it can correctly operate the transmission anymore it just locks it into 2nd so that the vehicle can at least still be driven and not just leave you stranded. Be careful with transmission repair shops, many of them seem shady at best and many times they just make the problem worse or don't even end up fixing it at all. Or they 'rebuild' the trans and then it has other issues afterwards. Also if you do ready your codes and it does turn out to be the torque converter lockup solenoid you could conceivably just drive it like that if it doesn't bother you too much. Your mileage might suffer a bit but it is not really a mission critical solenoid.
bleeding brakes
porcupine73 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat should be plenty. To think of it in reverse, when using the vacuum method, if you are pulling a strong vacuum then atmospheric pressure of about 14psia is pushing the fluid out the bleeder. So using 10-15psig to pressure bleed seems reasonable.
'98 Outback Legacy - no start after maint.
porcupine73 replied to BigRing's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe dohc is a little tricky to get all the marks lined up. If you are more than one tooth off, supposedly it will not start. Subaru mentions doing a compression test in this case. The old belt didn't break right (you are just doing this as maintenance)?
RPM's ??/
porcupine73 replied to robs5788's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should read the codes out of the TCU. You can do this yourself, you just have to find the procedure on how to do it for that year/model. Then you can see what problem it is detecting, quite possibly is the torque converter lockup solenoid from what you describe.
New York State Inspection.
If Calif. is doing it, you can bet NY wants to do it too. I think we in NY are trying to outdo Calif. laws like some twisted version of keeping up with the Jonses.
Engine fast idle after HG replacement?
porcupine73 replied to JulianH's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGlad you got it working! Hey what's this I hear about you having problems with your TPS reports man? The other seven bosses will make sure you get another copy of that memo, m k? yah. If the TPS has problems and it wants to increase fuel to increase rpm, it is going to have to also increase the airflow in order to keep the A/F ratio correct. And the only way it can do that is through the IACV.
RPM's ??/
porcupine73 replied to robs5788's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThose rpms sound about right for crusing at that speed in top gear. How you say about the rpm's fluctuating sounds like maybe the torque converter is not locking up, but in that case you should be getting a flashing AT light telling you it has detected a problem with the lockup duty solenoid.
And if there are any problems with it passing the tailpipe sniff test there are a lot of tricks out there, such as running a number of bottles of isopropyl drygas in say 1/8 tank of gasoline since the alcohol burns cleaner, make sure vehicle is fully warmed up before arriving at the shop and leave it running while waiting for the test, etc.
Hi nipper. Pre 96 I think you don't need the high enhanced emissions test. But since you're near NYC they often have stricter requirements than the rest of the state. Let me look up the link that explains it based on your city/county, I know I've seen it before. If you scroll down about half way on this link it talks about it: http://www.nydmv.state.ny.us/broch/c-50.htm
Quick Cat Coverter Question
porcupine73 replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRight, if I had to guess, I would guess the cali spec converters, if different, have more catalyst to reduce emissions, and the ECU might have tighter tolerances for triggering emissions codes (and also if the o2 sensors are different).
bleeding brakes
porcupine73 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXParts coming from Buffalo hm that is interesting. That's one thing I didn't like about rockauto. If you order any number of parts it ends up shipping from like 5 different locations which really bumps the shipping cost up.
Half SHaft Supplier
porcupine73 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLast I knew cardone does remanufacture the axles for Subaru (in the EndWrench magazine they often have parts ads and they list who remanufactures the part for Subaru). But of course it does not necessarily mean that the rebuilt axle cardone sells to autozone is reman'd to the same spec as the ones they do for Subaru. Was the axle put on the front, or on the rear? I haven't heard people complaining about axles on the rear, it's usually the ones on the front that cause the vibration issues.
power steering problem 1999 Subaru Legacy Outback
porcupine73 replied to AWDfreak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso if the full lock wasn't used very often the end of the rack might have had a little rust or grime on it and damaged the seal (if it seems to be leaking out the boot). The PS pump internal pressure relief is around 800-1000psi iirc.
porcupine73 replied to JulianH's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure, I mean if the throttle isn't completely closed of course that would cause fast idle. But if it is closed and there are no vacuum leaks then the only source of air for the engine when idling is through the idle air control valve, which the ECU will modulate to keep the desired idle rpm. I'm not aware of any reasons the ECU would open the IACV enough to make it idle around 3500 rpm. But if the throttle is not completely closed or there are vacuum leaks, that would do it.
bleeding brakes
porcupine73 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes HD is going to beat Ace prices most of the time. For one HD is a huge conglomerate with corporate owned stores whereas most Ace stores are privately owned. I have noticed most things are cheaper at Lowes and HD than at Ace, but the Ace is closer to my house so it's more convenient for weekend runs.
porcupine73 replied to JulianH's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you sure all vacuum lines are reconnected and there are no vacuum leaks anywhere? I know you said you hooked up the gauge but it doesn't take too much vacuum leak to really start letting the idle climb. Plus to idle that high it has to be getting enough air to run at that rpm so the vacuum reading almost doesn't matter. There may be other issues in addition considering the flashing ATF light (need to read out the codes), etc.
Coolant flow diagram?
porcupine73 replied to Speedbuggy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhaha that sounds like NY. In NY I'm not sure that could even be registered for on-road use since it has no emissions equipment. But NY is funny like that. We in NY are trying to outdo Calif. from what I can tell. I'll bet that BOV sounds really cool when she lets loose.
Best place to buy new floor mats for 95 Legacy?
porcupine73 replied to 95LEGOBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh then I think you want 1stsubaruparts.com or a site like that. I believe they are on the left coast.
porcupine73 replied to Speedbuggy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds good. Say do you have any video of her running, that would be neat to see. That's odd they would have not connected the plumbing for the turbo coolant. Maybe they figured it would not be in boost very much so it wouldn't need to be connected. Surely wouldn't want the turbo to melt down during spirited runs. Or maybe they figure it gets a fair amount of airflow over it where it's at.
Thermostat for EJ25
porcupine73 replied to Speedbuggy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think the genuine thermostat starts to crack open around 172F or 176F or something like that is pretty much fully open above 182F or so if I remember correctly. I don't think they have any temperature options in the genuine thermostat, unless maybe the STi's or spec. C's might have a different temperature. As long as you have a sufficient bypass flow through the heater core, etc., having the thermostat should be ok, since the coolant can just then run through the bypass when the thermostat is closed. You could also put in the Subaru block heater, those are only like $25, and then plug that in a couple hours before leaving home to help it get up to temp faster as well and warm the engine oil, etc. So what kind of transmission does she have in there?
porcupine73 replied to Speedbuggy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the turbo have connections for cooling water? That is one nice looking sandrail! It looks like it belongs in car shows moreso than being beaten on out on the dunes. But it must be fun. I am guessing that is one loud sweet sounding puppy how the exhaust just goes straight out of the turbo like that!
porcupine73 replied to Speedbuggy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen the thermostat is closed, there is still flow through the heater core and throttle body/idle air control bypasses. There is always flow through these channels. When the thermostat opens, then it also allows flow through the radiator. Yes deadheading the water pump is very bad as it will usually lead to cavitation from the pump operating well outside its curve. Now on a sandrail you probably have no heater core I am guessing, and they may not have the coolant flowing through the throttle body either since you really only need that for cool weather operation. So if it has these bypasses plugged, then you do not want to put in a thermostat.
bleeding brakes
porcupine73 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's not too messy. I just wear the harbor freight nitrile gloves while I'm doing it and just wipe the bleeder with a rag when I'm done. With the vacuum bleeding then you have only one hose to monkey around with. If pressure bleeding, you still need to put a hose on the bleeder anyway. Or what I did on one of the soobs was put speed bleeders in. On that one I don't have to mess with the silicone grease. I put them in before I built the vacuum bleeder.
bleeding brakes
porcupine73 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes depending on your bleeder it may suck a bit of air around the threads. I put silicone grease around the bleeder while bleeding and smoosh it around a bit until the bubbles stop. It is sufficient to keep air from getting in around the threads.
Thermostat for EJ25
porcupine73 replied to Speedbuggy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt will go closed loop above around 150F, provided all the required sensors and such were hooked up. I mean the thing may not have the o2 sensors and such wired in anyway. I think the idea in not running a thermostat is that a sandrail is going to be running at high load, possibly quite near full throttle, for extended periods of time in hot weather. And in that case the thermostat is just going to be full open anyway, so you can avoid the restriction of having the thermostat in the system by just eliminating it.
