3
Everything posted by porcupine73
Woohoo it's on! Thanks for all the help guys. I was trying this evening with two long reach pliers to yank it on there. It kept almost going but not quite. The I used some silicone spray as nipper suggested on there though I didn't think it would make any difference. Bingo, sschlooaapop is the sound it made as the very next try it popped right on all the way around. Something about that silicone spray just reallyy helps.
Thanks for the idea, I was trying to figure out something like that that might work without ripping the boot.....Hm..I wonder if a stiff coat hanger with the end bent over so it isn't sharp would be of any use. I have been trying some longish pliers with a bent over end just still couldn't quite get that top part to slip on.
Yes! It is that top part. I can get it on just about all the way around but that top end is very little clearance clarence. I have tried only 37 times up to now, so I am glad to hear that within 10 more tries it should go on! I thought about maybe trying to heat the boot up a little bit to make it more flexible not sure. I am using long pliers to kind of pull it onto the lip since you really can't get fingers into all the cranies in there. It is kind of rough on the boot but it's the best I can do. I remember this being a problem the last time and then finally when I just thought there was no possible chance it would go it popped on there so I will have to keep at it. Hm silicone spray, I could try it. I did grease all the areas ahead of time.
So what is the secret to getting the inner tie rod boot on the rack lip? I remember last time I replaced the front left inner tie rod end on '00obw, it was a major pain to get the boot to go on the lip on the rack. I had to tug and tug and horse around with it for a good while before it finally just popped into place. Having same problem this time on '96 Legacy. It starts going on but I can't quite get it to go on all the way around.
Sounds good. Just make sure to check what the required maintenance is. Some of the superbikes require engine teardowns as maintenance.
Those codes don't necessarily sound related to the timing belt work. The knock sensors are known to develop cracks on that era and can cause that code you are getting, but they aren't expensive and are pretty easy to replace. The knock sensor could be related to your stalling issues. When the ECU detects knock sensor issue it starts retarding timing to the edge of the map, and that robs fuel economy and power and can make the vehicle pret near stall. I did some experiments on my '00obw disconnecting the knock sensor while driving and it is interesting what happens, at first it almost seems like the engine dies, then stays running but has very little power and will bog down really bad if stepping on the gas. The P0440 can be a tough one to find, it can be even a little pinhole leak in the fuel tank, filler neck, etc., can cause it. Though checking the gas cap or repalcing it could be a first step since that sometimes causes it.
Yes, the Japanese know how to build bikes like they do cars. Some make both cars and bikes, which isn't seen much if at all anymore in the u.s. market. Porcupine has come to like Honda. So far the only problem he has encountered with the VFR is the cooling fan coolant switch went faulty.
The light flashing means the TCU has code(s) stored. You could read the code(s) and see what they mean. The fact that the FWD fuse does nothing and it has torque bind and the light is flashing could mean the duty c / transfer duty solenoid is done for. If that's the case, driving it too long like that could damage the transfer clutch itself also. The transfer clutch is in the rear extension housing, the duty c is the thing with the wire on it:
Hi nipper. I have had this code one time on '00obw auto. I'm pretty sure at least for me it is/was the neutral switch or whatever that position switch on the trans for the shifter. It is a bit off. Sometimes it doesn't indicate park, like it thinks it is between gears, unless I firmly shove the shifter to park. If it runs very long like that with no indication it throws that code it seems. Not sure if that is helpful to you but it's what I've got. Hope you figure it out!
