3
Everything posted by porcupine73
Ditto on the split flange. I am having this exact same issue, in fact, on a '96 Legacy as well. I bought two size split flanges, one is 1-3/4" to 2" (this size seems to be hard to find, but autozone has them). I think this is the right size as it measures at about 1-7/8" from what I can see. The other size is 2" to 2-1/4" but I think that may be too big. You probably also need a new donut gasket. If you unhook the two rubber bumper things that hold the exhaust up, it will pivot down at the supports at the muffler making it easier to get at the stuff. On mine anyway, the weld spot or flared spot on the back of the rear cat is still there, and I am thinking that will be very helpful in keeping the split flange from coming off.
http://www.cars101.com/subaru/tiresandwheels.html says Subaru LEGACY Tires and Wheels 2010; all with Tire Pressure Monitoring 3.6R (all)- 17" alloy wheel 17.0j offset 48 (1.89), PCD 100mm (3.94") Doesn't say a width but it seems like it probably falls in that range you mentioned; that's a pretty good range.
hm high idling ideas....vacuum leaks, misadjusted throttle and/or cruise control cables (so throttle doesn't close all the way), You mentioned neutral switch, I was thinking about that one, it may need to be checked for adjustment. If the MT is in neutral but the ecu thinks it is in gear it can cause weird things to happen. There were some notes with that switch on the MT soobs of that era.
Ive been thinking about getting some of those industrial type traps where they go into it and can't get back out. I have more trouble with mice in/around the house and basement than the garages. It's a mid 1800's house so it has a lot of spots mice can get in. One time under the kitchen sink I caught seven mice in one day in the same trap hahaha. Somewhere I have a pic of a mouse that got caught in two traps, by the leg in the first one then ran along the wall and got nailed on the head by a second trap.
I have trouble with mice in the garages too, in the cars, lawn equipment, etc. I put out poison but they just take it and store it under the hood. Traps work the best it seems. I have had good results with one of these electronic pest repellers I got somewhere. Supposedly they hate fabric dryer sheets and stuffing a few of those under the hood keeps them away but I haven't tried it.
The crankshaft pulley bolt was wet with fuel? That is a bit odd. It may have oil on it, since the service manual says to oil the threads before installing it. If you reinstalled that bolt make sure you tightened it enough, if that baby loosens up you are in trouble. If you have oil in the spark plug tubes that could cause the misfire. Also if those cylinders aren't firing sometimes you are dumping raw fuel into the exhaust and maybe some of it is getting into the oil especially if you make a lot of short trips.
If you have the crasman clicker types, pop the cap off the end and put some green loctite on the lock nut in there. The reason those clickers get such bad reviews is that nut loosens up over time and eventually comes off then you can't adjust the torque, and you would need a verryryyy thin wall socket to get that nut back in place. The green loctite should seep into the threads and keep that nut from loosening up.
Not if you put it on just the air/fan setting. Then you could run it off an inverter.
If you're talking about those little squirrel cage motors on ebay forget it. Those things probably can't even flow the CFM the engine needs under full throttle to begin with much less give any 'boost'. Just consider the power required to give say 14 psi boost at 350CFM, this is much more than some little gadget can make. Even a 220V garage air compressor might have trouble keeping up. Now I have seen an 'electric supercharger' setup that did give that kind of boost, but it could only do it for a couple minutes at a time I think it was and it was large heavy and had several batteries associated with it.
