3
Everything posted by porcupine73
Ah ok 140psi is not bad for a '92 engine. I was thinking of later engines for the 180psi. Here's some info from the '94 manual for compression: When checking compression pressures, ensure engine is at normal operating temperature and battery is completely charged. Remove all spark plugs and open throttle fully. Remove ignition coil harness, then install a suitable compression gauge. Crank engine and note compression gauge reading when gauge pointer is steady. Perform at least two measurements per cylinder to ensure compression readings are correct. The maximum compression difference between cylinders is 14 psi. Compression pressures should be 135-156 psi at 300 RPM. Trying to say how long it would last is not easy, I mean you don't know the maintenance history of the engine and it is now probably at least 18 years old. At 170k the water pump is probably pretty tired and it might have many oil leaks and things timing belt/ etc that should be addressed before installing to give a good life.
Do not use the arrows for timing!!!!!!! It is the hash marks. The tensioner must be compressed vvvvverrryyy slowly like taking 10 minutes ie in a vise on the earlier style that have if you have a '93, but you said 'upwards' whcih wsould be the later tensioner sytle. If so it must be compressed vertically (not in a vise) again veryyyyyy slowly or you will kill it.
Personally I would go with the genuine o-rings from Subaru. Only for this reason, I had my injectors serviced by Witch Hunter some years back, and on some of the injectors I used the o-rings WH sent, and on some I used new genuine rings. They looked the same to me, but the o-rings sent by WH leaked air and I had a sucking sound around those injectors. If your local dealer is ripping you off find a Subaru dealer selling parts online.
Consumers probably don't want to pay for such an elaborate AWD setup. Many AWD auto makers have similar requirements to Subaru's 1/4" circumference rule. Tirerack has a pretty good list. I don't know, I figure you pay to play. How often do you really get an unrepairable flat tire. I've had maybe three in my lifetime. One a couple months ago and yes I did have to get four new tires but hey what are you going to do.
All tires ideally should match within 1/4" circumference at most. Get the same brand and model replacement tire. If the new tire doesn't meet the 1/4" requirement or is even close to it, look for someplace like a race shop that will shave the tire down for you. If it doesn't meet specs and it is an AT run the FWD fuse until that is done.
I think they can fail so that they simply won't hold prime. Also turning the crank too much while doing the timing belt supposedly can make them bleed down. Some notes on endwrench imply that after the engine idles for like a half hour or somethign they would reprime themselves. I haven't had any issues with them on my '96 2.2L but it only has about 125k miles.
it wasn't a bad scratch but you know drill bits a mind of their own when close to a nice smooth surface they just can't resist but be attracted to it. I polished off the scratch as best I could hopefully it won't eat up the seal lip. Can you tell a little more about the napa green goop, I want to pick some of that up.
It would give you a little extra height. The cv's seem to be able to tolerate the bit of extra angle just fine. I mean the Outback's tolerate the angle though they do also have that body spacer. What year legacy are you doing this on? Basically '96-'99 (mcpherson) should be compatible, and then '00 to maybe '04 (that is rear multilink).
For the fronts I don't think you need backing plates or anything, just the calipers and brackets and if rotor diameter is different then the rotors. 543 pages hehe I'll take your word for it. Thanks for the info. I imagine if the vehicle has abs risk is even lower since the front wheels can't lock up then anyway. How about for a '96 brighton, do you think it would be okay to leave the rear drums (just a bit more involved than I want to get right now), but put on the dual pot front calipers (since I already have them and that's a quick swap)? Thanks.
