3
Everything posted by porcupine73
Did the dealer check to see if there are any reflashes available for your ECU? Reflashes are pretty common for the late model soob, maybe one of them addresses cold weather starting issues? Does it make any difference if you hold the throttle say 1/4 way open or so when you try to start? Hm if it is drive by wire the ECU might override your command anyway...
hehe right they don't last forever. I believe the itnerval is the same as the timing belt, 105k miles or 105 months. Replacing those belts is pretty easy but you need the right sockets and such for the tensioner bolts, plus if you have rusty tensioner bolts you might need to get penetrating oil on for a few days before. Also don't overtighten especially the belt with the p/s or it will start squeaking within a day or two.
If Subaru themselves had so much trouble coming up with reliable headgaskets for these designs, I can't really see how a typical aftermarket parts maker could possibly do any better. Maybe some performance types such as cometic but that is kind of a special application that might be torn down regularly for isnpection.
Or you can try to cut the nut off with a nut splitter or dremel or something. Yes in all applications where a 6pt socket will fit, use a 6pt socket. Esp in a high torque application like this. 12pt sockets can be helpful for certain tasks or obviously on 12pt fasteners but are much more likely to round off a t6pt fastener. If you damage the bolt I would just replace with a new Subaru bolt. Some of the metric JIS fasteners are stronger than grade 8 so replacing with grade 8 might actually be a step down. The strut mount studs will snap pretty easily. Torque wrench is a safe way to go, going by feel have seen some threads where people snapped them.
Right on, you shouldn't tow the auto trans with any wheels on the ground. I wouldn't do it for more than a few hundred feet. There is no ATF circulating with the engine off, yet you are turning parts in the transmission and hence can damage it. Disconnecting drive shaft and towing with front wheels off the ground is an option. Or tow with all wheels off the ground.
Hm...do you have an ripped cv joint boots? Brakes sticking at all or something? Might need to be run on a lift or something to try to isolate source of noise. For hard starting in cold weather, what temperatures are we talking about? Does your country/area switch to a 'winter blend' fuel for easier starting? Otherwise the fuel may not have enough vapor pressure or not be volatile enough to permit easy starting in cold temps.
Hi, I too have an '00 2.5L. The a/c compressor has it's own drive belt, and the power steering and alternator share a separate drive belt. Both these accessory drive belts are run off the crank pulley. (The timing belt is something different). For plugs, the platinum, iridium, etc can give you a longer interval between plug changes. However for performance in that engine even the normal NGK v-power copper plugs do just fine.
Wow this thread has been on the waiting list for a long time! I believe they are for emissions purposes only. The ECU wants the fuel temp to be in a certain range along with some other parameters before doing the fuel system integrity test (which it then uses the pressure sensor in the performance of). There's a good emissions article on endwrench that probably has more info.
1. Best bet is to get out as much as possible, drain plug, pump and dump method, or if you are replacing the internal screen filter, see 2. below 2. Yes you have in internal suction screen filter. These don't really get dirty much since I think they are just filtering the suction to the ATF pump to keep chunks from getting in there. More like a pump suction strainer sort of thing than a 'filter'. But if you remove it (not hard to do, just like a lot of bolts on the pan and a few to remove after that to get the filter out. YOu have to remove a cooler pipe line in the process of getting the filter (easy, like 2 bolts), but the bonus is then a ton more fluid will come out, probably from the torque converter I guess. I think you can get all but maybe 1-2 quarts out this way. (She holds pret nar 10qts). If the Trans-x is helping, it is because of its seal swell properties, probably makes that leaky ring on the drum swell enough to prevent the leaking it does at first preventing rapid buildup of pressure.
I'd stick with NGK plugs as that's what soobs seem to like. V-power's work great. Bosch had some issues for a while with cracking I think. To get the plugs out on the 2.5L phase I dohc is a little tricky because of reduced clearance. There is an article on endwrench.com that shows what sockets and extension lengths, flex pieces etc to do it more easily.
