3
Everything posted by porcupine73
No spark
porcupine73 replied to aberti's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Well, not sure if this helps but since many common things seem to be covered already (article from endwrench): Legacy and Impreza Engines with No Injection Pulse #1 Cylinder Built into the fuel injection control unit is logic that will shut off the #1 injector if the computer believes that it can no longer control the Idle Air Control valve. Remember this while trying to diagnose a “hard” code for the Idle Air Control Valve or a dead miss in number one cylinder due to no injection at idle. A problem in the Idle Air Control valve circuit can be responsible. (Component testing shows that it is usually not the valve itself.) Another unusual computer response is if the computer is deprived of its “back up power supply.” If deprived of this power, some computers will generate a false code for the Idle Air Control valve and kill the injector for cylinder #1. The pin location of this power supply can be found in the Control Unit Module I/O Signal pages of the appropriate service manual. 1 End Wrench The insider info. -
Yes P0nnn codes are the generic ODBII codes, P1nnn and P2nnn codes are manufacturer/model specific. Let's see, endwrench has a note about P1507.... here: Diagnostic Trouble Code P1507 http://endwrench.com/images/pdfs/DiagTroubSum04.pdf Hm....seems this note applies only for manual trans: "If you are diagnosing a manual transmission equipped vehicle with a DTC P1507 and can find nothing wrong after following the trouble tree in the appropriate service manual, inspect the Neutral Switch Circuit before replacing any parts. The Neutral Switch Circuit may cause this code to set. This could falsely indicate to the ECM that the transmission is in neutral when, in fact, it is actually in gear. This can cause the MIL to illuminate and set Code P1507. Keep in mind that the problem can be intermittent and it may be necessary to pin test the connection and to shift into and out of Neutral many times before the switch shows any problems."
If it ran before the water pump work, and any wiring/sensors that may have been disconnected during the work have been reconnected, then the timing being off is a good possibility I would think. Generally two or more teeth off and it will not start. He may have used the arrows on the crank sprockets rather than the hash marks, that would definitely make it a no start. Fortunately that engine is non-interference. Also I am assuming by no start, you mean it does crank whir whir whir whir but won't start. Check out : http://endwrench.com/images/pdfs/2.2SingleOverWin01.pdf
Maybe there is an issue with the position switch on the side of the auto trans? I think it only fires the solenoid to release the shifter if the shifter is in park. If it thinks the shifter is in reverse, maybe the reverse lights will be on, plus the solenoid wouldn't energize when you step on the brake to let it out of park? Here's some interlock override info:
Ticking Noise
porcupine73 replied to ltk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Hi ltk and welcome! Here's a good soob article about the noise: http://endwrench.com/images/pdfs/EngineNoiseSum04.pdf excerpt: "Subaru models from the 2000 model year and later, equipped with 2.2 and 2.5 liter engines" ,"A light engine knock, after cold start, that gradually dissipates as the engine warms up and is virtually undetectable (from inside the vehicle) once the engine has reached operating temperature, is a normal characteristic of these engines." -
Now I just need to start saving up for an STI!
The plastic part often referred to is the oil separator, that is plastic on certain soob engines and the upgrade is a metal part. It has nothing to do with the oil pump. Metal one with new screws Goes here: The oil pump rotor cover screws sometimes backed out, letting oil leak out the front crank seal and sometimes even pushing the seal out. If you have the older black colored cam and crank seals, those are more likely to leak. The newer brownish ones hold up better.
None of those are necessarily related. If the lamp blew out once and you replaced and it has been ok. The speaker could be a poor connection or faulty speaker; sometimes when poeple put in different radios they don't solder the connections so they can work loose with time. Horn could be a poor ground or connection again,etc.
You need to see where the play is. When you shake where the outer tie rod end is thread on to the inner tie rod, do you see any play at that junction? Like maybe get one hand on the outer tie rod end and the other on the inner and see if you spot any play at that junction there where the jam nut is. If you don't see any play there, then it may be the inner tie rod where it meets the rack. I just discovered this play on the left front on my '96 and '00. I could hear the play when I shook it but it took a while to figure out it was coming from the inner tie rod ends. At first I thought it was normal, but the front right are dead solid, no clicking or freeplay at all when shaking them.
Hi. Does it have an auto trans? If so, it sounds like the shaft seal that separates the front diff gear oil from the auto trans fluid may be bad, allowing the fluids to mix. ATF isn't good for the front diff because it does not have enough extreme pressure EP additives for the hypoid style diff. Gear oil is bad for the auto trans because the sulfur and such EP additives can corrode parts in the auto trans.
Thanks for the tie rod tool info! I ordered that set from HF and it has arrived! Now I just need to get enough Subaru bucks to get the tie rod ends. I think I saw the method of blocking the rotor with a small pry bar in the service manual. It worked very well, the bar slides right down in the rotor vanes and the caliper bracket is more than stout enough to take the abuse. Actually that is a HF pry bar, and the top snapped off it the first time I tried this. It is a brittle steel that looks weird when it fractures.
Hi. Yes KYB GR-2 do seem to be valved a little stiffer than the Subaru OEM KYB's. Add on King Springs/scorpion lift springs and that will definitely firm up the ride quite a bit, at least it has on my soobs. The King Springs you can get in a lowering, stock, or lift style. They have a catalog at http://www.kingsprings.com The lift spring style would give you a firmer ride because they have a higher rate (which is why they lift), probably like 350lb/in to 400lb/in. You can get King Springs directly from King Springs and they ship from Australia. Shipping costs almost as much as the springs themselves, but actually the price is still about the same as when renickmotorsports used to sell them. Important note about King Springs, if these are for your 2000 Legacy, you may need Forester upper spring seats for the front as the King Springs are made for Aus. spec vehicles. There are some other makers of lift springs for soobs, one from Canada I think, but I forget the names.
Yes, I would just order from King Springs directly. I got a few sets of Scorpion/King Springs from renickmotorsports.com in the past but they don't seem to offer them anymore. The shipping direct from King Springs may seem high, but actually it is about what Renick charged overall anyway. Just a note, you need to verify the upper spring seat diameter vs. the spring. For '96 outback springs I didn't have an issue, but for '00obw, the king springs were quite a smaller diameter at the top than the OEM. That's because Aus. spec soobs use a spring with a smaller diameter at the top. In that case a Forester upper spring seat typically would solve the issue.
