3
Everything posted by porcupine73
hehe ok yes I'll check out the dealer locator. Ah there it is, I didn't see it the first time because it says 'franchisee locator'. Hm it gives me Branch Name: Greater NY Telephone: 1-888-773-0331. I'll have to give a call. Hm a google search shows snap-on is looking for franchisees in Buffalo on careerbuilder.com maybe I don't have a dealer The risk in going into the tool truck will be getting all pie eyed and coming out with a bunch of great tools but a light wallet.
Right on, many '96 soobs have been granted exemption from the inspection readiness monitors (I/M's) because they reset to 'not tested' or 'not ready' every time ingnition is turned off. I checked my '96 legacy before just prior to NYS inspection, and many of the readiness I/M's were not ready or not tested, yet it passed no problem. There is an article on endwrench about this issue; can look up if desired. In NYS, as I suspect in many areas, the ODBII is connected to the test equipment, making it a little trickier to 'fake it out'.
hehe there's a good article on endwrench.com about egr code issues, maybe there's a pic of the filter in there. It also says sometimes some of the low points in the metal tubes rust out....ok over to endwrench to see if there's a pic. wow putting that part #22663AA010 into google only turns up two hits, one a japanese site with the part # mentioned in some pic of a turbo engine of some sort.
Most hardware stores will have the NPT pipe taps. Harbor freight even sells them. The pipe plugs would be in the plumbing section. You can get them with a square head for turning with a wrench, or with a recessed hex (though hardware stores don't usually have that style). I don't know what material plug you want, but the typical hardware store materials will be black pipe, galvanized, or brass. I would use a thread sealant since the tapered thread can have a spiral leak path. mcmaster has some info on pipe thread types and such http://www.mcmaster.com/param/html/MetalConnections/ i.e.
Hello and to the board! Most common soob misfire causes. a. non-NGK spark plugs b. non-OEM or Magnecor spark plug wires c. old/aged/in need of replacement spark plugs or wires d. coil pack cracking/carbon tracing e. oil collecting in spark plug tube (for soob engines where the spark plug tubes penetrate the valve cover). less common but can be e. one or more valves not closing completely (i.e. valve lash in need of adjustment - post '96 engines only as prior to that hydraulic lash adjusters HLA's were used). Can also happen if cylinder heads are severely carboned up. f. timing off/jumped tooth/etc of course there are other things too. You asked about knock sensor. It is fairly easy to replace.
Yes welcome to the board! Here are the most common Subaru oil leak locations with pics: Front cam seals (especially the earlier black colored seals; the newer brownish colored ones hold up better) (pics from an EJ22): Front crank seal (esp the mid 90's 2.2L's and some others where the screws on the rear case of the oil pump tended to loosen, letting oil out the front crank seal and sometimes even pushing the seal right out) Also there is an o-ring between the oil pump discharge and block The valve cover gaskets, and for engines where the spark plug tubes penetrate the valve cover, the spark plug hole seals. EJ22's also have an o-ring at the LH rear and RH front of the cam's: Also rear main seal, especially if the vehicle had a plastic rear main seal retainer/oil separator (an OEM upgrade to a metal retainer is available).
