Richard1296
Everything posted by Richard1296
The purge solenoid is under the intake runners on the passenger side mounted to the intake. Its easy to see if you stand on your head. It has a two wire connector the connector is blue if I remember right. Finding a good used solenoid isn't easy as they are a common item to fail. Cut the solenoids wires at the solenoid and replace it with a 100 ohm 1 watt resistor. It will fool the computer and allow the CEL light to be reset. Plug the two hoses that connect to the solenoid. I didn't see and problems when I did this to my 90. I did finally find a good used one. Richard
Actually I had no problem removing the fuse box. It was suprisingly easy. And the fuse box comes apart to reveal replaceable contacts that just plug onto the board.Replacing them would be easy if I could find them. Local parts stores can't find them, and the same small fuse is used in almost every car made. I thought maybe the removable contacts would be the same for other makes of cars (wrong again). My local (sort of) Subaru dealer could not find the contacts and wanted to sell me a complete fuse box...I didn't ask the price. Looks like the hard part will be finding the contacts. I need to find a junker to get the parts from. A salvage yard would want to sell the whole fuse box and I hate to pay too much when all I want is the contacts. Anyone got a late model Subaru that uses the real small fuses and would sell the fuse box (or contacts) reasonably priced. Richard
My 90 Legacy's owners manual calls for Dexron II. Dexron II is no longer available and has been replaced by Dexron III and Mercon/Dexron compatible types. I use plain old Mercon/Dexron in my 90 Legacy and the 2000 OBS. If ever I was to repair or replace either transmission I would use a synthetic though. And I'd add a small transmission cooler to supplement the factory cooling. Richard
There should be a harness that comes onto the right side of the engine from inside the car. It should branch off for the purge solenoid and coolant temp sensor. Near there should be another 4 pin connector for the O2 sensor. If I had the car here I could tell you more. Its been a year since I was under the hood of it. But since I had to replace the O2 sensor and purge solenoid I am pretty sure of the locations of most connectors on that side of the engine. The locations are the same on my 2000 OBS, though the connectors are different. Look on any 2.2 engine for the O2 sensor harness. It will be in the same location on the engine. Richard
My son has the car right now, no idea when I'll see either of them. It's a square grey four pin connector. The connector on the wiring harness should be a female connector. The connector should be near the right rear, under the edge of the intake. I'm thinking it has BLUE, WHITE, and two BLACK wires. I've also learned not all Subaru's of the same year are the same. Richard
The retailer where I bought my tires rotates them for free every 5000 miles. Seems a little excessive but its their suggestion and it is free. Of course they also suggest rebalancing at every rotation and "of course" they charge for the balancing. I suppose if I don't let them rotate and rebalance, then if I complain about tire life they will blame it on my maintenance, or lack of. Richard
Whats the OE plug for my 2000 Impreza Outback Sport. And what is a good replacement. The "Zone" lists a lot of Bosch plugs and they do fine in the wife's Hyundai. Seems I remember seeing here (or somewhere) that Subaru's don't like Bosch. I'd like to put in a set that will last the next 50K or so. No Idea whats in the car or how long they been in it. It runs fine but I usually change all the filters, fluids, and plugs when the previous history isn't clear. Generally I keep a car amost forever. And to all HAPPY HOLIDAYS...please make the season a safe one Richard
Mine is a factory service manual for a 1990 Subaru. And it makes reference to a fold out....I don't see one anywhere in book 6. If you have the electrical schematics the pin out of all the connectors appear to be there. No idea why my book liste the foldout but does not have it. My books when purchased were clean and pure as if they had never been touched. Sorry I don't have a copy. Post a link to it if you find it please. Richard
