ocei77
7
Everything posted by ocei77
IIRC up to 2012. Diiferences are 06 heads up have VVT, but you are not using them anyway. Impreza engines will work, but you need to use your old oil pan. Your 03 manifold stays. You will have to work around the PCV valve arrangement as i am sure the manifold to air box is diffent. Surely someone else will chime in. O.
When is the last time you tried to pull a cam sensor that has been in there a while? Not hating just asking. They tend to be seized. Insofar as where, i have tried to stay with Aisin metal parts , Misuboshi belts are good but its hard to find them in a kit. Do you have the one or two piece tensioner? You can change the two to a one by replacing the mounting bracket, but if it is good leave it. O.
Needle nose pliers should work w/o removing anything. That picture only shows the source of one hose, There is one more from the bypass tube from the water pump that sits alongside the crossover, The tubes have a tendency to rust at the bends. http://static.opposedforces.com/epc_img/371494803501.pngSee: Subaru IMPREZA — Subaru parts catalog (opposedforces.com)
Lost !!!!!
ocei77 replied to ocei77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Update. Looked at everything with the Maxisys. No change. Am getting ready for a trip so I wanted to put my BT Kenwood in until I get my car. Turned the key to set the functions. NO clicks!. Tried it again, no clicks. Don't know the whys or wherefores, but I am a happy camper. The Subaru radio has an Aux jack and a ground lug. Everything goes through the connector on the Kenwood.
