ocei77
    7
Everything posted by ocei77
  1. yes that hose. It varies in method of attachment and size in various years.
  2. IIRC up to 2012. Diiferences are 06 heads up have VVT, but you are not using them anyway. Impreza engines will work, but you need to use your old oil pan. Your 03 manifold stays. You will have to work around the PCV valve arrangement as i am sure the manifold to air box is diffent. Surely someone else will chime in. O.
  3. AFAIK from 90-94 are mostly the same. Look here: www.main.experiencetherave.com - /subaru_manual_scans/ Osei
  4. When was the timing belt last changed? I assume this a two piece tensioner. Still has tension? Any codes?
  5. Are the fans coming on? Are you getting bubbles in the overflow tank? Did you recently do something with the cooling system? If so, did you fill the block first and then the radiator or just the radiator?
  6. Keep everything. The 25D headbolts are a different length than the 2.2. Also the mounting point and the dip stick length are different. The ect may be different and depending on the year may be in a different location on the crossover pipe (ie: front or back). More power to you
  7. I hear you. For awhile I went the other way. 2.2 block with 25D heads as noted by DOHC22E. Dohc ej22e - Second Generation Legacy (1994 - 1998) - LegacyGT.com Fun, but sadly non engine issues killed it.
  8. once the bolts are removed they'll come right up. Watch the torque on install if you want to keep the heads. They are INCH pounds not foot lbs. O.
  9. Yes.. Index of /Auto/Japan/Subaru (jdmfsm.info) www.main.experiencetherave.com - /subaru_manual_scans/
  10. tiresize.com/ comparison According to this site the diameter is 1.8" larger. The width being the same , you should have room to clear the perch. Check
  11. you are going to have a problem with your differentials eventually. The computer will see the wheels rotating at different speeds and try to correct the imbalance. the center differential will suffer. AWD systems in general should not be run intentionally with different tire sizes.
  12. Check compression. Sounds like rings to me. What is your oil consumption?
  13. Did someone remove the radio? The vent housing may not have been reinstalled correctly.
  14. When is the last time you tried to pull a cam sensor that has been in there a while? Not hating just asking. They tend to be seized. Insofar as where, i have tried to stay with Aisin metal parts , Misuboshi belts are good but its hard to find them in a kit. Do you have the one or two piece tensioner? You can change the two to a one by replacing the mounting bracket, but if it is good leave it. O.
  15. You will have to check to see if all the timing marks still line up. If not, redo and when you take the belt off, check to make sure there is no slop with the crank keyway.
  16. AFAIK. There is a diameter std of being within 5/32 circumference of the tires. Mixing of tire tread patterns will have some effect on tracking, but again AFAIK not detrimental to the differential. I am sure someone will chime in, but I pray it is with empirical data. Not heresay. O.
  17. Needle nose pliers should work w/o removing anything. That picture only shows the source of one hose, There is one more from the bypass tube from the water pump that sits alongside the crossover, The tubes have a tendency to rust at the bends. http://static.opposedforces.com/epc_img/371494803501.pngSee: Subaru IMPREZA — Subaru parts catalog (opposedforces.com)
  18. Update. Looked at everything with the Maxisys. No change. Am getting ready for a trip so I wanted to put my BT Kenwood in until I get my car. Turned the key to set the functions. NO clicks!. Tried it again, no clicks. Don't know the whys or wherefores, but I am a happy camper. The Subaru radio has an Aux jack and a ground lug. Everything goes through the connector on the Kenwood.
  19. Jack that side up as high as your stand will allow. Clean the area, use an old blanket to lay on. Use flashlight and have someone start the car. Watch your face! The 97 Outback has the EJ25D DOHC engine unless someone swapped it with an EJ22.
