ocei77
9
Everything posted by ocei77
It works, no codes and no drilling needed. Cut the egr tube in half. Rotate to right. Get hose to fit. Get a 3'4" plastic T barb from hardware. Cut IAC hose so that the barb will be facing the firewall. Attach other end of IAC to intake. Now you need piece of hose to go from the barb to the egr line. You also need a fiiting that will go over the small line from egr to the iac hose. Take the egr tube with you so you'll get what you need to fit. I got my pieces from Advance Auto. Clamp the egr connections(hard line, fitting on intermediate hose, and where intermediate goes into the T'd barb). The two sides of the IAC barb don't need clamps as the one piece doesn't use any. Can't take a picture to show the one I did and my drawing skills are non existent. Once you get into it you'll see. O.
Being a DIY, I do not have all the tools that a regular mechanic may have, so I like you try to remove items that may be easier with a specialized tool, but for whatever the reason don't buy. That being said,, I spray with PB a day or two before I start. After removing the pinch bolt ( which sometimes have their own issues), I remove cotter pin from castle nut and unscrew it a little to make sure it moves. Then I remove the sway bar bolt and pry downwards on the control arm. This has worked for me.in all cases but one, in which the ball joint snapped!. I then used a chisel on the ball joint until it broke free of the rust and freely rotated and pried it out. I always run the insides of the socket with 1000 grit or finer paper, clean and anti seize. O.
Don't remove the engine mount bolt entirely on the side you are not working on, this will prevent the possibility of misalignment. Ie :working on driver's side, remove driver side mount, but leave two or three threads caught on passenger side. Do the work, then alternate. O.
- 15 replies
- 1
- spark plug
- oil
(and 1 more)
Tagged with:
I don't quite understand the issue. If you have a Forester engine with oil cooler, everything should be there. The OB body wouldn't make a difference. Are you mixing engine parts? If so follow advice above^. When I get to another place, I have an engine that I put the oil cooler on, so I can take a pic. Will hopefully get there within the next few days. O.
Valve clearance
ocei77 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Intake .20 Exh .25 mm tolereance of +/- .02 O. -
Yes, replace the rotors. Check pads, if worn a lot or scored, might as well do it all at once. Only two extra bolts per side. Depending on the year of car, most bracket bolts are 17mm. An extension and 1/2" ratchet would be best. Spray with PB beforehand if you can. Sometimes the rotors are stuck. Since you are replacing them, a good whack with a BFH will shake them loose, though there are two threaded holes that take an 8x1.25 bolt to push them off. If you have it , wire wheel the outside of the hub that the rotor centers on and a little of the face. I generally put a little anti seize on the circumference of the hub and a little on the face. This to minimize sticking in the future. Anti seize all the bolts before reinstalling. O.
I lost a fuel pump in a 98 Forester two years ago. Rather than just replace the pump since it was less work, I swapped the assembly from a 97 Legacy that had died from other causes. Its still running today. Unless the tank was drained, you don't get oxidation on the copper lines. If necessary a swipe or two with 1000 or finer paper will be all that you need. I've never heard of the float itself going bad. O.
Salvage yard. From as late a model as you can. It only takes about 15 min to remove. Take PB, an 8mm socket, a phillips head screwdriver and a pair of pliers. You'll have to wiggle a little as the float level gets in the way. The nuts will be rusted. On your vehicle tighten a small bit to break the rust, then loosen. O.
The posted workaround works, but there is a simpler way. Cut the egr tube in half, rotate it 90 deg. facing pass side. Take the iac hose and the cut egr to auto store and get a foot of the size that fits it. There is another fitting that will go over it that will make a tight fit into the iac hose.(not sure of size) If you don't have another iac hose around get a foot of 3/4" ID hose of any type. Get a 3/4" T barb. Plastic is fine Hose clamps is all else you need. Lay it out as you install it so that you cut the iac hose in the right places. Will post pics as soon as I get to the car that the mod is on. O.
Rebuilding an engine is time consuming and depending on machine costs expesnsive. If a bearing is gone more likely the crank is shot also. In the lower 48 it's usually cheaper to buy a crank with bearings than to turn the crank, new bearings and polish the rod( hoping that's all it needs). You have to check on freight costs, etc for a new crank, Try northernautoparts,com for cranks and get shipping. For the 25D heads on a 2.2 go to legacygt.com and look for posts by DOHCEJ22E1 . There is a complete build info there and which HG to use. If more info is needed, just post and I'll give you what I can. O.
