ocei77
7
Everything posted by ocei77
95 2.2
ocei77 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You don't use a gasket on the oil pump, just sealant. Your choice, I use anaerobic. O. -
The 05 is made the same. There are two circlips. The first is just inside the fat housing. Once the boot is removed and you clean it some in gas, you will see it. A screwdriver will suffice to pry it out. Once that is removed, when you align the trunions with the cutouts, the cup will come off, allowing you to remove the circlip on the end of the axle and then the trunion. Now you can replace the boot. Only use CV joint grease on refill. Here is link to 2005 fsm : http://jdmfsm.info/Auto/Japan/Subaru/Legacy%20Outback/ O.
I don't have complete info, but I have had to do some of the same. Perhaps one who does this a lot will chime in. Meanwhile, the bottom pieces of trim on the quarters will pop off, as does the trailing edge trim.The top trim is secured by 8mm nuts from the inside. You'll need a deep socket here. The access trim will just pop off. Don't pry on the glass with anything hard. You can heat the metal of the body inside the car with a heat gun or hair dryer to soften the adhesive, then push the wire through from the inside. I used a tire plug tool. You can then saw the wire to separate the glass from the adhesive. You have to make a way to secure the inside while doing this or a 2nd person. O.
As far as I can see there was no 97 Forester, not even in Europe. However, the Forester is just a wagon built on an Impreza flatform and I would start there. There are too many options for me to even think about answering. If you will go to a previous post started by grossgary on opposed forces website, there is a link there to this site that will guide you that should answer your question. Find your engine and drive configuration and click on the part number. Then click on usage info, this will give all the models that use the same part. O.
97 Legacy wagon
ocei77 replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
WalMart. Goodyear Viva 3 . 16" sizes now $69, + balancing( not sure of their price). Quiet ,good tread life and good in all seasons. O. -
Can I do it?
ocei77 replied to Smurfsack's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If he has to pull no 3 he would have to pull the engine. The access is via the oil separator plate. Prayerfully it is as Adventure says. I would never go this deep into an engine w/o pulling it first. Smurfsack get a fsm from online and check out some youtube videos. You can do it. O. -
Rack and Pinions
ocei77 replied to Msp90's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Go to car-part.com. Input your info and it will give parts that are compatible. If it was me, I'd either just put more lube in there and close up the ends, or replace the boots. Latter will probably require an alignment afterwards. O. -
Get the t belt and idlers/water pump kit first. sometimes they come with the metal gasket. The passenger side stays put unless you hit it. The drivers side intake is under tension, where you just go slow until you're on point. A spring clip would help here until you go around the exhaust sprocket. The cam bolts are 17mm. If you break the tension on the crank bolt first, then just line up your timing marks, they won't move much if you just give a sharp rap to the breaker to unloosen the crank bolt again. For a FSM go to New Gen FAQ. Second page under my name is a link. Rotate the crank by hand a few revolutions after you pull the tensioner pin. This to make sure all is well and that the timing marks align again. The marks on the belt will not. Welcome. O.
