ocei77
7
Everything posted by ocei77
Atf temp light
ocei77 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Any codes? Pull the dipstick and see if it stops. Speedometer working? O. -
When you look into the tranny you will see the tabs that mate with the notches on the TC. Insert TC, lift an rotate. keep upward pressure as you rotate. It will catch. Keep rotating pushing inwards. It will jump @ two more times. It is fully seated when the outside mounting tabs are about 3/8 of an inch from the tranny block looking from above Before mounting the engine. Give it a few insurance turns to make sure it is fully seated. O.
The only time this happened to me (not with a Subaru), was indeed related to heat. The solenoid was getting heat soaked and would not work until it cooled. I put a wet rag on it to help cool it and immediate start.. Worth a try.. Replace the contacts and plunger(($10-15 on E Bay) rather than buy a complete starter. O.
Yea, that is what happened to my steel terminal. Seemed like the battery post was too small in diameter. Tighten the clamp as much as I could some time ago, but ran out of room to tighten any further. Clamp had not been real tight for some time. Common issue with oem cables and third party batteries. I have used a length of solid copper wire, breaking it off after tightening and the prong from an appliance plug to fill in the gap. O.
First you don't need to remove the strut bolts to do an axle. Turn axle so the bevel side faces you. Punch the pin out. Don't turn the wheel. 3/16 punch. 32mm for the axle nut. Good breaker bar (forget the harbor freight one for this), plus a cheater pipe.(that axle nut is REALLY on there) Remove the sway bar bolt. Remove cotter pin from lower ball joint and unscrew the castle nut (19mm). Pry the control arm down( you're not trying to remove the ball joint, so don't remove the bolt that secures it). Now you can swing the hub assembly out. Just pull and it will come out of the tranny and tap the axle side out. New axle bevel has to face the same way. Roll pin into bevel side. Axle side in. If the roll pin won't go all the way through ,the splines are off 180 deg. The control arm up, it will stay in place. Tighten all nuts. Torque the axle nut (@140 ft lbs) then stake it. Before removing the strut bolts at any time (especially the upper) use a chisel to mark the nut and the bolt, this way they can go back the way they came out, saving you a realignment. If no impact gun, a 19mm to hold one side while you wrench on the other. 6 pt sockets and 1/2" drive are best. You need a penetrant of some type. The fsm is available in the sticky above, 2nd page under my name. O.
EGR code
ocei77 replied to sub96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
There are other tests to be made. Google Subaru DTC codes and check yours. Make sure the small metal line from the EGR to the solenoid valve is clear also. You can test the solenoid by connecting the green plugs under the dash and turning switch on. Listen for the clicking to confirm operation. Don't forget to unplug afterwards. In the future please start with more specifics.ie Engine, mileage. O. -
jack it up and remove the heat shield bolts (you'll probably have to cut them off). This way you can raise the shield enough to get an open end onto the bung and another on the sensor itself. If you don't a good 19mm open end, a small pipe wrench will work also. Spray with PB and try to tighten a bit to break the tension. Then unloosen. O.
You have the marks correct. Is the tooth count on the belt correct? 44 from crank mark to passenger cam and 40.5 to driver cam. If this is correct then something is unplugged. Check crank , cam sensors and IAC hose to intake. O.
- 8 replies
- 1
- SOHC 2.5
- timing belt
- (and 5 more)
Use emery boards to clean the contacts. Unfortunately I left my diagram of pins for the harness where I won't get back to for a few days. In either case looking at the back of the connector #1 is Br, 2 is LG, 3 is LR and 4 is YL. Check resistance and see if one/more are much higher than the others. This may help you to narrow down if only one or two pulsing low. O.
